Vaillant EcoTec Plus 612 - Troubleshooting Error V.61, Suggestions & Help Needed
batarcam 13890 13
Why does a Vaillant EcoTec Plus 612 keep showing error F.61/V.61 after temporarily clearing it with the chimney-sweep button?
Error F.61/V.61 is usually a fault in the gas-valve control circuit, and the main board is often the real cause rather than the gas unit itself [#16821841] Check whether about 22 V DC reaches the gas unit from the control board and measure the coil resistance; if the voltage is low or unstable, the board is suspect [#16821841][#18142919] One confirmed fix was replacing two electrolytic capacitors on the main board, 470 uF / 35 V / 105 C, which restored the correct voltage and stopped the fault [#18142919][#19752636] Another user reported that replacing the motherboard made the error disappear completely [#16849092] A service overhaul and checking tarnished contacts were also suggested, but the strongest evidence in the thread points to the electronics on the main board [#16788377][#16821841]
  • #1 16788064
    batarcam
    Hello everyone
    I have such a furnace vaillant ecotec plus 612 and this error V.61 is displayed.
    After pressing the chimney sweep button for a while it is good and then the same error V.61.
    I am asking for any suggestions and help.
  • #2 16788377
    irus.m
    Heating systems specialist
    Help: 122
    Rate: 453
    F 61-Gas valve control fault. Very enigmatic description.
    The reason can be anything from automation to a gas unit, bad connections on tarnished electric contacts, etc.
    When was the solid review done? Maybe all you need is a good overhaul of the boiler ?.
  • #3 16802787
    batarcam
    Thank you for the hint.
    I will do a solid review with the service.
    After I will write what was
  • #4 16821455
    kch70
    I have the same thing with ecoTEC plus VC PL186 / 3-5 - error F.61.
    And what a thorough / decent review helped. Is this something more serious?
    Thanks for the info.
  • #5 16821841
    VPS
    Help: 87
    Rate: 230
    With error f.61 it is necessary to check whether 22V DC voltage is reaching the gas unit from the main board. Then check the coil resistance in the gas assembly.
    Often the reason for the error f.61 is a motherboard failure.
  • #6 16822158
    kch70
    Thank you for the information.
    Is a symptom of a motherboard failure can also be large pressure peaks between the furnace rest and its operation. (during standby 1.2 bar, heating of water in the tank 1.6, and heating operation up to 2.4).
  • #7 16822166
    VPS
    Help: 87
    Rate: 230
    No
    These symptoms may indicate an inadequate pre-pressure in the expansion vessel or an expansion vessel that is too small for the volume of water in the heating system.
    A failure of the pressure sensor itself cannot be excluded.
  • #8 16822175
    kch70
    Thanks. The furnace has been working for 8 years without problems. I will check the diaphragm vessel first.
  • #9 16849092
    kch70
    Thanks for the advice. After replacing the motherboard - turning off the oven ceased (error F.61 disappeared).
  • #10 16929786
    boodles
    did you replace the motherboard in the oven yourself? If so, where did you buy? And how much did it cost you?
    I am asking because I have such a problem.
    B.Art
  • #11 16956925
    kch70
    B.Art
    Hi
    Replacement and purchase of parts (motherboard) I commissioned an authorized service technician (purchase only in the service network). Purchase of the plate approx. PLN 900 plus replacement PLN 100. Costs should close at PLN 1000. A bit is but better than replacing the stove. Mine has been working for almost 10 years.
  • #12 16961955
    boodles
    In the end I did it too. 900 disc and service - 1300PLN. The service technician convinced me that this is better because there is a guarantee. My oven also works 10 years.
    He advised me to apply to the insurer because the board broke due to overvoltage. I have issued an application and I am waiting for a refund.
  • #13 18142919
    Qdlaty78
    Rate: 29
    I hook up the topic with insights. Error f.61, while maintaining the correct operation of the gas unit (after resetting the stove it works several dozen hours) is the fault of the capacitors. For me (Ecotec plus VC186 / 3-5) there were just such symptoms. It works correctly, nicely and in general, until suddenly (often synchronously with the switching of the multi-way valve) the flame goes out and the error f.61 crashes. The band coil had the correct resistance (as I remember correctly 330Ohm). I measured the voltage on the coil during operation - it should be 22V and it was 17V. This caused the valve to open, but any increase in current consumption from the 24V power supply on board or other destabilization, e.g. a fluctuation of the mains voltage, caused the valve to close. I replaced 2 capacitors (470uF / 35V / 105C, I bought identical Epcosy with luck).
    It seems to have helped. The furnace is working properly, the voltages are correct, the family is happy.
    ps This is definitely a repair for someone who has an idea about electronics and the operation of the furnace itself. Prudence and attention are required. The coil may have the correct resistance, but e.g. the valve may have a mechanical fault. The controller will report the same error, because it checks whether after opening the valve and applying the spark a flame is ignited (based on the ionization of the ignition electrode). Rummaging at the gas valve itself is absolutely unacceptable, as are repairs when additionally F.62 appears, which means the ionization current is too high. As long as it results from dirt on the electrode, it is a small matter to be cleaned. However, the same error can mean that the gas valve does not close, which may cause a gas leak and explosion.
    pps but I don't know myself, I'm not a vaillant serviceman ;)
  • Faulty capacitors causing F.61 valve voltage drop
    #14 19752636
    marcinekmm
    Rate: 12
    Qdlaty78 wrote:
    I stick to the topic with observation. Error f.61, while maintaining the correct operation of the gas unit (after resetting the stove, it works for several or several dozen hours) is the fault of the capacitors. I had just such symptoms (Ecotec plus VC186 / 3-5). It works fine, fun and everything, until suddenly (often synchronously with the switching of the multi-way valve) the flame goes out and the error f.61 is triggered. The band coil had the correct resistance (330 Ohm as I remember correctly). I measured the voltage on the coil during operation - it should be 22V and it was 17V. This caused the valve to open, but any increase in current draw from the 24V power supply on the board or other destabilization, e.g. voltage fluctuations in the mains, closed the valve. I replaced 2 capacitors (470uF / 35V / 105C, I bought identical Epcos by luck).
    Looks like it helped. The stove is working properly, the tensions are correct, the family is happy.
    ps This is definitely a repair for someone who has an understanding of electronics and the operation of the furnace itself. Prudence and attention are required. The coil may have the correct resistance, but e.g. the valve may have a mechanical failure. The controller will report the same error, because it checks whether the flame ignites after opening the valve and giving a spark (based on the ionization of the igniting electrode). Fumbling with the gas valve itself is absolutely unacceptable, as are attempts to repair when an additional F.62 appears, which means too high ionization current. As long as it is due to dirt on the electrode, it is a small matter to be cleaned. However, the same error may mean that the gas valve does not close, which may result in gas leakage and explosion.
    pps but I don't know myself, I'm not a vaillant service technician ;)
    I confirm the above diagnosis and the solution to the problem also in my case. The purchase of original capacitors for literally PLN 7 (I paid so much for 10) and their replacement on the stove's main board did the trick. The job is indeed a watchmaker's job, but somehow it worked, and five are flying.
    Thank you for your help in solving the problem.
✨ The discussion revolves around troubleshooting the V.61 error code on the Vaillant EcoTec Plus 612 furnace. Users report that the error may indicate a gas valve control fault, potentially caused by issues such as bad connections, motherboard failure, or inadequate pressure in the expansion vessel. Suggestions include performing a thorough review of the boiler, checking the 22V DC voltage to the gas unit, and inspecting the coil resistance. Several users successfully resolved the issue by replacing the motherboard or capacitors on the main board, with costs for repairs ranging from PLN 900 to PLN 1300. The importance of using original parts and authorized service technicians is emphasized for reliable repairs.
TL;DR: Vaillant ecoTEC Plus F.61/V.61 points to gas‑valve control; target is 22 V DC, and “check whether 22V DC voltage is reaching the gas unit.” For many users, fixes ranged from re-capping the board to replacing the main PCB. [Elektroda, VPS, post #16821841]
Why it matters: This FAQ helps homeowners and technicians diagnose and fix F.61/V.61 on Vaillant ecoTEC Plus boilers safely and cost‑effectively.
What does Vaillant error F.61/V.61 actually mean?
It indicates a gas valve control fault. Root causes include faulty control electronics, bad connections, tarnished contacts, or a defective gas unit. A thorough boiler review is recommended to separate wiring issues from board or valve problems. [Elektroda, irus.m, post #16788377]
How do I quickly diagnose F.61 with a multimeter?
  1. Measure DC voltage from the main board to the gas unit; target about 22 V.
  2. Measure the gas valve coil resistance.
  3. Reseat and clean the electrical connectors to the valve and board. If voltage is missing or unstable, suspect the motherboard. [Elektroda, VPS, post #16821841]
What voltage should I read at the gas valve coil?
You should see around 22 V DC during operation. Users measuring about 17 V reported the flame dropping and F.61 returning. As one expert noted, “It should be 22V.” Stabilize supply first, then reassess ignition and flame. [Elektroda, Qdlaty78, post #18142919]
What coil resistance is normal on the ecoTEC gas valve?
A typical gas valve coil reads about 330 Ω. This aligns with working systems that still showed F.61 when supply voltage sagged. If resistance is wildly off, the coil may be faulty even if wiring looks fine. [Elektroda, Qdlaty78, post #18142919]
Can bad capacitors on the main board cause F.61?
Yes. Multiple users fixed intermittent F.61 by replacing two electrolytics (470 µF, 35 V, 105 °C). One reported parts cost about PLN 7 for ten capacitors. “The job is indeed a watchmaker’s job,” so only attempt if you have electronics skills. [Elektroda, marcinekmm, post #19752636]
Will replacing the motherboard (main PCB) clear F.61 for good?
It often does. After installing a new main board, users reported the boiler stopped shutting down and F.61 disappeared. If voltage to the gas valve was low or unstable, a fresh PCB restored proper control. [Elektroda, kch70, post #16849092]
How much should I budget to replace the Vaillant main board?
Expect roughly PLN 900 for the board and additional labor that brings the total near PLN 1000. Authorized service typically supplies the part and performs the swap, preserving warranty on the repair. [Elektroda, kch70, post #16956925]
Can insurance cover a surge-damaged boiler control board?
It can. A user replaced the board via authorized service (total around PLN 1300) and filed a claim, as overvoltage caused the failure. Check your policy’s electrical surge coverage and save the service report. [Elektroda, boodles, post #16961955]
Are pressure spikes during heating linked to a bad motherboard?
No. Pressure rising from about 1.2 bar at rest to 2.4 bar in heating points to expansion vessel pre‑charge issues, undersized vessel, or a faulty pressure sensor. Address the vessel before chasing electronics. [Elektroda, VPS, post #16822166]
Is it safe to adjust or “tinker” with the gas valve to stop F.61?
No. Do not adjust the gas valve. Edge case: Error F.62 means excessive ionization current and could indicate the valve does not close, risking leakage and explosion. Clean the electrode only; leave valve work to pros. [Elektroda, Qdlaty78, post #18142919]
What does the chimney-sweep button do, and will it clear F.61?
Chimney-sweep mode forces a test run and can temporarily mask F.61 by stabilizing operation. The error returns if the underlying voltage, board, or connection issue persists. Use it only for testing while diagnosing. [Elektroda, batarcam, post #16788064]
After a reset, how long might the boiler run before F.61 returns?
Anecdotally, systems ran several to several dozen hours before the flame dropped and F.61 reappeared. This pattern suggests marginal supply or control stability rather than a hard valve failure. [Elektroda, Qdlaty78, post #18142919]
Should I DIY or call authorized Vaillant service for F.61?
If you lack fine soldering and diagnostic skills, use authorized service. One user commissioned service-only parts and fitting to retain warranty on the repair. DIY can help, but prioritize safety and documentation. [Elektroda, kch70, post #16956925]
