Lenovo K5 Shut Off & Won't Restart: Powerbank Cellularline 7800mAh Charging 2 Phones Issue
Hubert Majewski 2766 2
  • Powerbank overload may have shut down Lenovo K5
    #1 16698305
    Hubert Majewski
    Powerbank Cellularline 7800mah-28.08wh, input: 5v 2a, output (usb1 + usb2): 5v 2.1a max, plugged into the power supply. At the same time, I connected two phones to it: Lenovo K5 and iPhone 7. At some point, the K5 turned off and does not restart. When it is under the charger, the red indicator light is on.
    Is it possible that the fault of this is the powerbank simultaneously charging and charging 2 phones at the same time?
    I am asking for help, thanks.
    automobilklub
    Help: 21
    Rate: 176
    Yes, power banks cannot charge phones and be charged at the same time. Fully charge it, disconnect the charger and then try to connect the phone. Greetings
  • #3 16698783
    Hubert Majewski
    I fully charged Lenovo and it started. I am not going to use the bank that way. Thanks for the help.
