Navara D40 2006 - Airbag Indicator Blinks, Error B1059 After B1049 Driver Airbag Tape Replacement
Marcin_ca1 15687 6
  • #1 16702091
    Marcin_ca1
    Help: 14
    Rate: 278
    Patient Nissan Navara D40 2006
    The problem is with the Flashing AirBag indicator.
    Errors that were:
    B1049 Driver Airbag (tape has been replaced)
    B1059 Airbag system incorrect function
    After replacing the tape, only B1059 and the flashing light remain, how to fix this problem?
    pozdr
  • #2 16703059
    januszx3
    Help: 214
    Rate: 420
    Marcin_ca1 wrote:
    Navara D40 - Airbag indicator is flashing
    Get to know your system better - Restraint System (SRS) "AIR BAG" and "SEAT
    BELT PRE-TENSIONER "used in" Nissan Navara D40 "(see attachment, fragment of service manual).
    PS
    You will see the entire manual at "PW"
    • SRS.pdf (1.44 MB) You must be logged in to download this attachment.
  • #3 16995521
    P-A-W-E-Ł
    Rate: 9
    Hello. I have a problem with my airbag on the Nissan Navara D40, namely the light flashes all the time. I connected it to the computer, but it does not show any error, after deleting the light goes out, but after a few seconds it starts flashing again. I tried to reset the key, but it didn't help either. Thank you in advance for your help.
  • #4 16995610
    genek1000
    Help: 290
    Rate: 1058
    See post above.
    In the SRS.pdf file everything is described, including the diagnostic procedure without the use of a diagnostic computer (by flashing indicator).
    Good luck repairs :D
  • #5 16996622
    Marcin_ca1
    Help: 14
    Rate: 278
    Uploading the software to the controller helped me anew. pozdr
  • #6 16997028
    P-A-W-E-Ł
    Rate: 9
    Marcin_ ca1 could you share the information how much did this event cost you?
    Thanks in advance for your help ;-)
  • #7 16997419
    Marcin_ca1
    Help: 14
    Rate: 278
    An electronics engineer from the city where I live did it for PLN 100 :D
The discussion revolves around a 2006 Nissan Navara D40 experiencing a flashing airbag indicator, specifically error codes B1049 and B1059. After replacing the driver airbag tape, the B1049 error was resolved, but the B1059 error persisted. Users suggested consulting the SRS (Supplemental Restraint System) manual for diagnostic procedures and indicated that uploading software to the controller resolved similar issues. One user shared that the repair cost was approximately PLN 100, performed by a local electronics engineer.
