Selection of cameras for monitoring a single-family house with a recorder
11111olo 4044 9
How should I choose a four-camera surveillance system for a single-family house with local and remote access, night viewing, and a recorder within a PLN 2,000–3,000 budget?
A good choice is a 4-camera Hikvision-based IP system with an 8-channel NVR, because it fits the budget, is easier to install, and leaves room for expansion; if you want a cheaper wired option, a TurboHD set is the alternative [#16807848][#16808429][#16808016] For IP, one suggested setup was HIKVISION DS-2CD1121-I cameras at about PLN 250 each and either BCS-NVR08015ME-II or DS-7604NI-K1 as the recorder, with the advice to buy an 8-channel recorder now so you do not have to replace it later [#16807848][#16808016] Another recommendation was the cheaper DS-2CD1021-I, or the better DS-2CD2T22WD-I3, and for domes DS-2CD1121-I or DS-2CD2120F-I [#16808016] If you prefer TurboHD, suggested recorders were DS-7104HQHI-F1/N or DS-7204HQHI-F1/N/A, with cameras like DS-2CE56D8T-ITM and DS-2CE16D8T-IT / IT3 / D7T-IT3 [#16808016] For cabling, twisted pair in gutters was recommended for neat installation, and one estimate put a 4-camera set with IR up to 20 m, 2 TB disk, PoE switch and accessories at about PLN 3,000, while another estimate said a usable 4-camera set can come in around PLN 2,000 [#16808352][#16808535][#16809771]
  • #1 16807521
    11111olo
    Rate: 797
    I am standing in front of buying a monitoring system for a single-family house. I have identified the needs:
    - budget 2-3 thousand
    - monitoring of a single-family house
    - four cameras
    - max distance 20m
    - color cameras also for night viewing
    - recording time - I do not know, at most I will put a larger disk :D
    - access to recorded material; remote and local
    - detail (face recognition, license plates, silhouettes, general view)
    - a photo or drawing of the area to be monitored - I will not do this because it is not yet precisely established
    I am asking for help in the selection of equipment and advice on what to pay attention to.
    dawidedziu
    Industrial cameras specialist
    Help: 500
    Rate: 643
    The basic question - what budget? A recommendable, cheap and well-functioning set of 4 FullHD cameras with a disc and a recorder costs ~ 1500.
    pawel.krzyszka
    Hello, I recommend the HIKVISION DS-2CD1121-I 2mpx camera, price for 1 pc. about PLN 250
    for this recorder BCS-NVR08015ME-II IP 8CH up to 8MPx price about 460 PLN.
    It is better to pay extra and take a recorder for 8 channels, in the event of expansion you will not need to replace the recorder. The question of the internet remains. In the case of mobile internet only T-Mobile, it gives a good device and there is no problem with a fixed IP address. I have personally worked on this topic.
  • #4 16807980
    11111olo
    Rate: 797
    It is not about taking cheap but also not for 10,000. 1500 is a price that is not excessive.
    There will be 4 cameras there because more does not make sense.
  • #5 16808016
    dawidedziu
    Help: 500
    Rate: 643
    What I wrote earlier was about TurboHD cameras - on converters. Relatively cheap solution with a good image. Do you want a standard system with converters or rather IP?
    If from the IP system is the DS-7604NI-K1 recorder. The cameras are the cheapest and good DS-2CD1021-I or more expensive and with better parameters DS-2CD2T22WD-I3. When it comes to the domes, the one that my colleague wrote about above, i.e. DS-2CD1121-I or DS-2CD2120F-I.
    Z TurboHD is the DS-7104HQHI-F1 / N or DS-7204HQHI-F1 / N / A recorder (4HD + 1 IP camera). The domes are DS-2CE56D8T-ITM, and the bullets are DS-2CE16D8T-IT, DS-2CE16D8T-IT3 or DS-2CE16D7T-IT3.
    Robstar
    Help: 15
    Rate: 49
    When selecting, the following questions are important:
    1. The cameras will be on the soffit or beheaded?
    2. Color of the cameras?
    3. The building is already finished or at the construction stage what can you put the cable
    RG6 / RG59 or twisted pair?
    I recently launched on Plus with an external dynamic IP and it also works OK.
  • #7 16808399
    11111olo
    Rate: 797
    I do not know what will be better but IP cameras probably.
    The cameras will be on the wall. The color doesn't seem to matter :D The building is finished and the cables have to be pulled "somehow". I didn't wonder how because that's the smallest problem.
    dawidedziu
    Help: 500
    Rate: 643
    No IP cameras are a bit more expensive, but easier to install.
  • #9 16808535
    Robstar
    Help: 15
    Rate: 49
    A good solution is to use gutters, you can practically not see the cabling, gelled twisted pair and the operation is basically guaranteed while maintaining the maximum lengths.
    Equipment baskets from the recent valuation about 3000 PLN and in the set
    4 cameras with ir 20m (also illuminated by nearby lamps)
    Recorder
    2TB disk
    Switch with poe
    Equipment box
    300 m skretch, rj45
    On hikvision hardware.
  • #10 16809771
    11111olo
    Rate: 797
    Robstar wrote:
    Equipment costs from the recent valuation about 3000 PLN
    More like PLN 2,000. I do not know where you buy, but you can buy one camera for about PLN 250 with a recorder below 5 hundred dollars.
    Twisted pair is PLN 1 / m. Up to 100m will come out there.
    I don't know which disk I will buy, but the price is influenced by the capacity.
A user is seeking advice on selecting a monitoring system for a single-family house with a budget of 2,000 to 3,000 PLN. The requirements include four color cameras capable of night viewing, a maximum distance of 20m, and a recorder with remote and local access to recorded material. Recommendations include HIKVISION cameras such as the DS-2CD1121-I and DS-2CD1021-I, along with recorders like BCS-NVR08015ME-II and DS-7604NI-K1. The discussion highlights the advantages of IP cameras for easier installation, the importance of cabling options, and the potential use of gutters for discreet installation. A complete setup with four cameras, a recorder, and necessary accessories is estimated to cost around 3,000 PLN.
