MERCEDES SPRINTER 313 CDI - Steering Angle Sensor Issue: ESP ABS Lights, Replacement, Grips & Tips
many2999 17769 4
  • #1 16703988
    many2999
    Hello everyone - I need your help, although as mentioned above
    I have a problem with the steering angle sensor in Sprinter 313
    The problem started with replacing the grips - lights and wipers
    after this exchange, when I left the garage, ESP ABS immediately caught fire and something else ...
    Recently, I decided to replace the sensor with a new one because I could not make contact through the computer
    with brakes, abs, etc.
    I bought the sensor, installed it and supr
    the lights went out the full euphoria in my eyes followed
    but not for long ...
    I did about five meters and it all caught fire again
    - I mounted the sensor perfectly - I think so according to the cutouts, etc.
    Question What to do ?? Is the new sensor scrap?
  • #2 16704155
    Cobrat
    Help: 35
    Rate: 501
    Probably the calibration of the sensor itself is still needed ...
  • #3 16707267
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    The sensor when driving straight ahead must show "0"
  • #4 17045185
    kilof_1
    Rate: 11
    Gentlemen, did you solve the problem ??
    I have a similar situation, but I have an ESP error on the board, after reading the errors, the car shows 4d35 Steering wheel angle sensor, self-test error, discontinuous.
    The car had a regenerated steering gear, then the geometry of the steering sensor was set to 0 when driving straight ahead. Where to find a solution to the problem ??
  • #5 17054738
    kakibara
    Help: 202
    Rate: 1284
    You need to calibrate with a computer
