[Solved] Mercedes Sprinter 906 - ABS ESP Issues, CAN Errors, Steering Angle Sensor, Wheel Speed Sensors
wary2 47295 7
  • #1 16902954
    wary2
    Help: 6
    Rate: 221
    Hello colleagues, I have a problem with ABS in the above mentioned Sprinter
    He shows me mistakes, after firing and deleting there is nothing. However, when I move, the litany shows up, I don't know where to start looking.
    -4D35 STEERING ACCOUNT SENSOR
    -7266 CAN ESP break time
    -7270 vehicle speed rear axle
    -44A8 speed sensor wheel left rear air gap
    -6800 CAN ESP (maybe it's in diagnostic mode)
    The wheel speeds match.
    I am asking for some tips.
  • #2 16904113
    lugi666
    Help: 17
    Rate: 158
    Supply / ground are?
    jurekk55
    Level 36  
    Help: 182
    Rate: 1579
    Master the error a ....
    will stop appearing.
    Problem with....? Is it difficult to provide a description?
    dulik62
    Help: 7
    Rate: 56
    Hello. Check the rear wheel rotation sensors - set the air gap.
  • #5 16918448
    wary2
    Help: 6
    Rate: 221
    Hello, I ordered the swivel account sensor because the parameters did not see the parameter all the time 0 most likely fallen. I'll start with this. I will write what and how
    Steering wheel sensor sensor self test error (permanent)
  • #6 16937332
    wary2
    Help: 6
    Rate: 221
    After replacing the swivel account sensor, the error is gone. But then the list is terrible. I check the rest in turn.
  • #7 16970449
    wary2
    Help: 6
    Rate: 221
    I cleaned the sensor at the rear wheel and errors on the board no longer shows you can drive normally.
  • #8 17132041
    wary2
    Help: 6
    Rate: 221
    Problem solved, As described above.
The discussion revolves around ABS and ESP issues in a Mercedes Sprinter 906, specifically focusing on error codes related to the steering angle sensor, CAN errors, and wheel speed sensors. The user reports intermittent ABS errors that disappear after clearing but reappear upon movement. Suggested troubleshooting steps include checking the rear wheel rotation sensors and ensuring proper air gap settings. The user replaced the steering angle sensor, which resolved the initial error, and later cleaned the rear wheel sensor, leading to normal operation without further errors. The problem was ultimately resolved by addressing the sensor issues.
