Toshiba LCD 32AV933G: DPS-140SP Power Supply Damage - C910 Capacitor & ZD904 Diode Issues
zolwik5 6990 4
  • #1 16708480
    zolwik5
    Rate: 27
    Hello, I have the equipment in the workshop as in the title with a damaged DPS-140SP power supply. At the moment, the C910 22pF / 1kV capacitor is damaged and the ZD904 diode is shorted (the diode on the device is good). Help is appreciated, thank you in advance, best regards. Possibly, a new DPS-140SP (functional) power supply comes into play, if someone has or a replacement for it, but this is the last resort - I am more inclined to bring it back to life. :)
    • Toshiba LCD 32AV933G: DPS-140SP Power Supply Damage - C910 Capacitor & ZD904 Diode Issues IMG_20170919_193324.jpg (2.36 MB) You must be logged in to download this attachment.
    • Toshiba LCD 32AV933G: DPS-140SP Power Supply Damage - C910 Capacitor & ZD904 Diode Issues IMG_20170919_193402.jpg (2.09 MB) You must be logged in to download this attachment.
  • #3 16708613
    Macosmail
    Help: 227
    Rate: 860
    First of all, check out Buddy, the primary winding of the STBY transformer. It is fragile and often gets damaged.
  • #4 16709883
    zolwik5
    Rate: 27
    Macosmail I will check it, thanks for the advice ? I will have a moment to report what and how.
  • #5 16717536
    zolwik5
    Rate: 27
    Thank you for your help, thank you for all your help.
