Husqvarna Saw Models: Best Choice for Home & Forest Use (440 vs 445) within 1000-1500 PLN Range
piotruś 123 12162 8
  • #1 16719854
    piotruś 123
    Rate: 121
    Hello, I would like to ask for help . I want to buy a Husqvarna saw. I don't know which model to buy. The money oscillates between 1000 and 1500 PLN. I ask for advice. I will use the saw for housework, but sometimes for cutting thick trees in the forest twice a year. I was thinking about the 440 or 445 and I don't know. I am asking for help and advice.
  • #2 16720881
    piotruś 123
    Rate: 121
    Will anyone help me in choosing?
  • #3 16725896
    p.obelix
    Refrigeration equipment specialist
    Help: 215
    Rate: 563
    I have 445 and I praise myself. It depends for what purposes you need it professionally or 20m3 trees per year to be turned into fuel.
  • #4 16727728
    piotruś 123
    Rate: 121
    I process about 50 m3 of tree a year. Tne trees in the forest with a diameter of 70 cm but smaller. The saw will serve for years. That's why I prefer to add and buy decent equipment.
  • #5 16778486
    draggs
    Rate: 11
    Buy a used ms 250 stihla and it will be git and not some husqvarna ....
  • #6 16778802
    piotruś 123
    Rate: 121
    Hello. I bought a stihl ms 250. New. Works flawlessly until you hear this power. I talked with people repairing saws and everyone advised me not to use husqvarna due to the lack of spare parts, often perishable and expensive to repair. alone has stihla ms 018. It is easy to repair and parts are not that expensive. I also recommend stihl.
  • #7 16780243
    draggs
    Rate: 11
    Husqvarna generally have the impression of not catching up with the present day. Better certainly than quinols, but nevertheless worth having a stihla than husq.
  • #8 16780651
  • #9 16780783
    jerry1960
    Level 37  
    Help: 285
    Rate: 1560
    Search for chainsaws made for the US market. There are such on a well-known portal. Their performance is definitely better. The defect has no warranty.
The discussion revolves around choosing between the Husqvarna 440 and 445 saw models for home and occasional forest use, with a budget of 1000 to 1500 PLN. Users express varying opinions on the Husqvarna brand, with some praising the 445 for its performance, while others recommend Stihl models, particularly the MS 250, citing better reliability, availability of spare parts, and ease of repair. Concerns are raised about Husqvarna's perceived decline in quality and the need for higher investment for professional-grade saws. Additionally, suggestions are made to consider chainsaws designed for the US market for better performance.
