Audi A6 C6: Removing Left Fuel Level Sensor - Necessity to Remove Right Sensor & Hose
6777 8
  • #1 16712235
    piotrekwoj1
    Help: 947
    Rate: 3438
    It should come out without removing the pump assembly.
    sulof1601
    Help: 94
    Rate: 281
    Will come out without a problem.
  • #4 16712927
  • #5 16713104
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    Quatro or axle?
  • #6 16713113
  • #7 16713116
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    It comes out without a problem. Like golf 3 :)
  • #8 16713132
  • #9 16713160
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    Bieda z nędzą wrote:
    Baniak probably the same in AWD or FWD
    Two different. Two different constructions. It comes out differently from AWD and different from FWD.
    Added after 57 [seconds]:
    I do not want to drain oil, because I see that the tank is a vessel with two chambers; do you know which one it came from
    You don't have hills? Can't park on a bank? It will overflow itself.
The discussion revolves around the removal of the left fuel level sensor in an Audi A6 C6. Users confirm that it is possible to extract the left sensor without needing to remove the right sensor or the pump assembly. Concerns about working with fuel and the complexity of the task are expressed, particularly regarding the tank's design, which features two chambers. Some users mention the differences in sensor removal between all-wheel drive (AWD) and front-wheel drive (FWD) configurations, indicating that the process may vary based on the vehicle's drivetrain setup.
