Golf IV 1.9tdi - Right hand brake caliper lever does not reflect.
rsv6 40032 12
How can I fix a rear brake caliper handbrake lever that does not fully return and leaves the right brake dragging?
The usual cause is a seized/corroded handbrake lever shaft inside the caliper, not the cable or the clearance screw, so the caliper needs to be dismantled, cleaned, re-greased and reassembled with new seals/bushes if needed [#16714301][#16715042] After rebuilding, make sure the handbrake cable is adjusted correctly and that the lever and piston mechanism move freely; the piston mechanism should turn with pliers with only slight resistance [#16716717] Optional return springs can be fitted to help pull the lever back, with part numbers 1K0 615 295 (left) and 1K0 615 296 (right) [#16713995] One reply also notes that Mk4 calipers were not factory-fitted with these springs, so their absence is not necessarily a fault [#16714014] If the brake pads or carrier are corroded, check them too, because rust can keep the brake partially applied [#16714569]
  • #1 16713928
    rsv6
    Rate: 285
    I have a problem with my right caliper because the handbrake lever lever does not always reflect me completely.
    At first, the rubber jamming the plunger broke and the clamp was burning. I cut the clamp with the pipe wrench, because it was so burnt that I could not move, I do not know whether the screw canceling the clearance from which the plunger is twisted did not distort me.
    I cleaned the clamp and replaced the piston and gaskets. After folding I noticed that the right cable is about 1.5cm longer because the plunger did not leave. I loosened the hand cable and with the key I pulled back the lever from the manual one and several times until the links were leveled. However, after tightening the hand and releasing the lever does not retract about 30 degrees from the beginning.
    Is it because she does not regress completely, the clearance does not erase on the blocks? After pushing the manual left wheel locks me on the asphalt and the right one even on the grass does not want ...
    I've heard about putting on the lever some additional spring but if the piston will then clear the play completely.
    Does anyone have a schematic of this clamp what is the dependence of pressing the lever so that the plunger is locked in position at the disc itself and has not withdrawn completely? Does the lever have to go back completely? Will the play disappear? Is the screw is a curve and I will not do anything about it.
  • #2 16713995
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Put on optional springs that pull out the manual:
    left side: 1K0 615 295
    right side: 1K0 615 296
  • #4 16714000
    pospiech8
    Rate: 11
    At the back of the clamp should be a spring and it should be enough to undo the clamp and check if the other side of the clamp is not baked on youtube is a movie how to undress step by step enough that you need to make some special pliers to undress everything is on the movie
  • #5 16714014
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    pospiech8 wrote:
    The back of the clamp should be a spring and it should be enough
    In mk4 there were no factory-mounted springs-they fit from the top five ... purging the clamp and adjusting the cables will of course not hurt
  • #6 16714301
    milejow
    Help: 1563
    Rate: 5149
    Sealed / rusty axis of the manual lever in the clamp-standard. The clamp to dismantle, clean and replace all the erasers, fold and it will whisk like new.
    pospiech8 wrote:
    you need to make special pliers
    Such pliers are bought, do not make up.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #7 16714569
    Staszek49
    Help: 228
    Rate: 1140
    Buddy Psilos 1 - I had a VW IV and there were springs at the brake callipers. Clamp dismantle, remove corrosion, lubricate with special grease, fold and work properly. Check if the brake pads are not corroded, because I had so that the corrosion cracked the block, i.e. separated the abrasive from the metal, as a result of which the pads kept "constantly" and the hub was hot. Please note that the brake cables are suspended on the chassis, as this affects the even performance of the handbrake.
  • #8 16714584
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    If it was someone who founded it - they were not assembled in the factory ... even the part code comes from Friday (1K .......) as to the rest of it is the most
  • #9 16714946
    omegolotC30NE
    Help: 51
    Rate: 138
    The factory has come to the conclusion that it should be.
    Btw. In Germany, I drive to a car wash once every three months. In Polsza, one day after washing the car dirty. Conclusions ?
  • #10 16715029
    rsv6
    Rate: 285
    The problem is that it's like blocking in one position 30 degrees from loosening .. And then it normally pops up. The cord is slightly clamped and I changed the piston and seals as I wrote at the top. The only thing I think is that this screw can be included.
    I will buy these additional Coreas alone and maybe I will not buy anything new because it normally blocks the foot. Only this screw probably does not twist automatically because the lever does not come back ..
  • #11 16715042
    milejow
    Help: 1563
    Rate: 5149
    rsv6 wrote:
    I cleaned the clamp and exchanged the piston and seals as I wrote at the top.
    Dismantled the manual mechanism from the inside of the clamp, did you clean the axis of the lever and the brass sleeve cooperating with the shaft? I suppose that you did not just mess up.
    Działalność własna
  • #12 16716717
    gregorius-up4
    Rate: 16
    You can be sure that the mechanism in the piston with the thrust bearing works correctly
    it must be turned with tongs with slight resistance.
  • #13 16717935
    rsv6
    Rate: 285
    Is this nut in the piston working as a clearance clearance? Does it turn one way and not screw it in?
    Added after 3 [hours] 25 [minutes]:
    I put on additional springs and blocks both wheels. And he does not feel any resistance difference with springs.
The discussion revolves around a malfunctioning right-hand brake caliper lever on a Golf IV 1.9 TDI, where the lever does not fully retract, causing issues with the handbrake. The user initially faced problems due to a broken rubber component and a burnt clamp, leading to the replacement of the piston and gaskets. Despite these repairs, the lever still fails to retract completely, remaining stuck at a 30-degree angle. Various responses suggest checking for corrosion, ensuring proper lubrication, and verifying the functionality of the springs and cables. Recommendations include using additional springs for better performance and ensuring that the manual lever mechanism is clean and functioning correctly. The importance of checking the brake pads for corrosion and the proper adjustment of cables is also emphasized.
TL;DR: If your Golf IV 1.9 TDI handbrake lever sticks about 30° and won’t return, the usual culprit is a “sealed/rusty axis… standard.” Add return springs and rebuild/clean the lever shaft to restore snap-back. [Elektroda, milejow, post #16714301]
Why it matters: A dragging rear caliper overheats the hub, wears pads fast, and weakens parking-brake hold. This FAQ is for Mk4 owners troubleshooting a right-rear caliper lever that won’t fully return.
How do I fix a Golf IV rear caliper lever that doesn’t spring back?
Clean and rebuild the handbrake lever shaft. Remove the caliper, extract the lever/shaft, clean corrosion, renew seals, and reassemble. Add optional return springs (Mk5-type) to improve snap-back. Finish with proper cable adjustment. “Sealed/rusty axis… standard.” [Elektroda, milejow, post #16714301]
Which return springs fit, and were they factory on Mk4?
Use add-on springs: left 1K0 615 295 and right 1K0 615 296. They were not factory equipment on the Mk4 but can be added to help the lever return after release. Adjust cables after installation to keep both sides even. [Elektroda, psilos1, post #16713995]
Is my handbrake cable the problem or the caliper itself?
Check lever free movement first. If the lever binds, the caliper’s lever shaft is corroded. If the lever moves freely but return is weak, inspect and adjust cables. A baked or seized cable is possible but less common than a stiff lever shaft. [Elektroda, 1 PAWEL, post #16713997]
Do Mk4 rear calipers have a built‑in return spring from the factory?
No. Mk4 calipers typically did not include external return springs. Owners successfully retrofit Mk5-style springs to improve lever return and reduce drag after release. Rebuilding the lever shaft remains essential if corrosion is present. [Elektroda, psilos1, post #16714014]
What does the internal screw/nut in the piston actually do?
It’s part of the self-adjusting mechanism that advances the piston as pads wear. When healthy, the mechanism turns with pliers with slight resistance. If it binds or freewheels, the caliper needs service or replacement. “It must be turned… with slight resistance.” [Elektroda, gregorius-up4, post #16716717]
Why is my right cable now ~1.5 cm longer and the lever stuck ~30°?
Those signs indicate the lever didn’t return home, leaving slack in the cable. The likely cause is corrosion on the lever shaft and sleeve. Restore movement by fully dismantling, cleaning, and resealing the lever mechanism, then adjust cables. [Elektroda, rsv6, post #16713928]
Could brake pads or mounting cause constant drag and heat?
Yes. Corrosion can separate pad friction material from the backing plate, causing constant contact and heat at the hub. Inspect pad faces and edges for lifting or cracks and replace as a set if any defect appears. [Elektroda, Staszek49, post #16714569]
What tools do I need to service the rear caliper correctly?
Use a rear brake wind-back tool, external circlip pliers, and quality brake grease. Special pliers are purchased, not improvised, for safe disassembly. Replace all rubber seals during the rebuild to prevent future binding. [Elektroda, milejow, post #16714301]
How should the parking-brake cables be routed and adjusted?
Suspend cables properly on the chassis and avoid sharp bends. After caliper service, set equal tension so both wheels lock evenly on a flat surface. Poor routing or uneven tension degrades parking-brake performance. [Elektroda, Staszek49, post #16714569]
Quick 3‑step: How do I get the lever snapping back again?
  1. Remove caliper, strip lever/shaft assembly, clean rust, and replace seals.
  2. Verify piston mechanism turns with steady, slight resistance.
  3. Refit with add-on return spring, then adjust handbrake cables evenly. [Elektroda, gregorius-up4, post #16716717]
Will adding the extra springs fully solve a sticky lever?
Springs improve return but won’t cure a corroded lever shaft. Rebuild the lever mechanism first, then use springs for consistent snap-back and to balance both sides after cable adjustment. This combo restored normal operation for users. [Elektroda, rsv6, post #16717935]
Any maintenance habits to reduce caliper lever sticking over time?
Keep the mechanism clean and inspect periodically. Environmental dirt accelerates corrosion; some owners note cleaner operation with regular washing. Still, mechanical cleaning and correct lubrication during service matter most for longevity. [Elektroda, omegolotC30NE, post #16714946]
