Epson L655 Printer Offline Issue: Auto Goes Offline, Updated Drivers, No Admin Rights
Firstsannin 4275 6
  • #1 16714637
    Firstsannin
    I have a problem with the Epson L655 printer. It automatically goes offline after some time. Drivers have been updated. The printer itself scans and prints printer settings files. The problem appears when you have to ask her to print something from your computer. The printer is in a company, so I don't have administrator rights. If anyone knew how to get this online, I'd be grateful.
  • #3 16714697
    Firstsannin
    He certainly did not, because it would turn off cyclically, and here it turns off as the printer pleases. There is no such option on the printer itself, and no one has fiddled with it on the computer. She's offline for printing and that's it. I forgot to add that she is on wifi, but the network is ok.
  • #4 16715330
    pir0maniac
    Help: 7
    Rate: 30
    Check with the network administrator that the router does not disconnect 'idle' devices after some time. It can also be a damaged wifi module in the printer - it would be best if you could test it for some time on the USB cable.
  • #5 16715356
    fifek62
    Help: 66
    Rate: 289
    After what time? Epsons turn off on their own after not being used for 4 hours.
    What is the printer connected through? If via USB, check in the printer settings if the USB connection is active because it can be turned off so that the computer does not detect the printer.
  • #6 16715430
    Firstsannin
    If it was used at 4 p.m., it no longer works in the morning at 9 a.m. the next day. It is connected via wifi. It seems to me that the router does not disconnect idle devices, because the printer constantly shows that it is connected to the network, nothing changes here.
  • Stuck print job from card reader blocked printer
    #7 16716974
    Amcoranos
    Help: 48
    Rate: 57
    I don't know if it will help you but I had a similar problem with Toshiba. After turning on the computer, the printer connected to the network when I asked for a job to print, it went offline. First of all, check the ping, if it has long delays then you can try all possible programs that try to print something on the printer turn off and on. in my case it was some strange magnetic card reader from which you could print some reports. It must have had some print in the command that crashed and blocked printing from other programs. After all devices were turned off and on, the printer unlocked. The same case on 2 computers in one company windows 7 x64 if I remember correctly. (Try to connect the LAN to the printer if possible. In this way, it may be possible to eliminate the problem of a broken network card?)
The discussion revolves around an issue with the Epson L655 printer, which automatically goes offline after a period of inactivity, despite being connected to Wi-Fi and having updated drivers. The user, lacking administrative rights, seeks solutions to keep the printer online. Responses suggest checking if the network administrator has set idle device disconnection rules, testing the printer with a USB connection to rule out Wi-Fi module issues, and ensuring no other devices are interfering with the print command. One user shared a similar experience with a Toshiba printer, indicating that network delays or conflicts with other devices could cause the printer to go offline.
