Is it possible to download Vordon GPS maps to an SD card and insert goclover 505
dibtonga 5265 5
  • #1 16717893
    dibtonga
    I wanted to download Goclever navio 505 Vordon GPS maps for navigation, but when I connected the navigation, it wrote that the device was not found. So I had an idea to put a memory card out of the navigation and upload Vordon GPS maps to it.
    Is it possible?
  • #2 16717965
    jajacekpl
    Help: 65
    Rate: 268
    Just copying the maps to the card will not do you anything - you still need to install a navigation program that supports them
    There is probably Mapfactor Navigator in Vordons (free), you can download it from the manufacturer's website, along with the maps:
  • #3 16717974
    dibtonga
    I downloaded the navigation program.
  • #4 16717977
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    And what's your navigation program there in this Goclever navio 505? Will these maps "fit" with this program. Because there is a difference between the concepts of "maps" and "navigation program", each program requires the appropriate type of maps to be able to work with them.
  • #5 16717981
    dibtonga
    It will definitely fit
    I just mean whether this program will see the SD card.
  • #6 16719498
    jajacekpl
    Help: 65
    Rate: 268
    The navigation program does not "see" the cards - the device takes care of "seeing", and the program must be indicated (by the appropriate configuration or a combination of folder names) where the map files are located.
    As if, a little tutorial:
    Added after 11 [minutes]:
    So which program - pre-installed on GoClever Mireo, or Mapfactor you have selected?
    And which one do you run (and can't see the card)
