Passat 1.9 Turbo: Oil Flood in Pear - Causes & Solutions for Pressure Build-Up
Dawid19980511 9024 10
Why is oil collecting in the turbo vacuum actuator (“pear”) on my Passat 1.9 TDI, and where could it be coming from?
Oil in the turbo vacuum actuator should be coming from above, not from inside the vacuum system itself, because that actuator works under vacuum [#16719792] Check the engine after washing it to find the leak source, especially around the valve cover and nearby vacuum lines [#16719741] [#16719756] A cracked vacuum hose or oil running onto the intake/manifold area can also drip into the actuator housing [#16719782] The replies suggest the oil is pooling in the actuator’s depression, so the real fault is likely an external leak above it rather than the actuator itself [#16719770] [#16719794]
  • #1 16719666
    Dawid19980511
    Hello, I noticed that in my Passat 1.9 turbo pear is flooded with oil: / anyone has an idea where it flows from?
    Added after 35 [seconds]:
    Some pressure goes into this pear
  • #2 16719741
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Oil losses are. This pear controls the turbine blades. Check thoroughly after washing the engine where is the oil from?
  • #3 16719749
    Dawid19980511
    There is no shortage of oil, unless it is hardly visible.
  • #4 16719756
    Pedros050
    Help: 2471
    Rate: 3926
    Wash the valve cover and so on where it is flooded with oil. Check carefully where the leak is from? Alternatively, show some photos of this leak.
  • #5 16719770
    Dawid19980511
    There is a puddle of oil in the pear, a vacuum is in the middle and there is oil around the vacuum
    Added after 51 [seconds]:
    Pear has such a depression and there is a puddle in this depression
  • #6 16719782
    Pedros050
    Help: 2471
    Rate: 3926
    And you don't have a cracked pneumothorax hose and you pour oil on the suction manifold on the pear?
  • #7 16719785
    Dawid19980511
    There is a pool of oil here
    • Passat 1.9 Turbo: Oil Flood in Pear - Causes & Solutions for Pressure Build-Up IMG_20170925_112133_503.jpg (103.78 KB) You must be logged in to download this attachment.
  • #8 16719788
    Dawid19980511
    Sciagne plastic cover today and I will look through,
  • #9 16719792
    andrzej20001
    Help: 1578
    Rate: 6669
    There is no where the oil comes from because the system has a vacuum. Poured from above.
  • #10 16719794
    Pedros050
    Help: 2471
    Rate: 3926
    Yes, I understand you, but there must be oil there either from the lid or from pneumothorax. Which year is this Passat? And from that you had to start removing these covers on the engine.
  • #11 16719801
    Dawid19980511
    1.9 TDI 101 HP. The year of the engine is hard for me to say because it was replaced by someone and now I do not know, because I bought one from a guest.
The discussion revolves around an oil flood issue in the "pear" (likely referring to the turbocharger or related component) of a Passat 1.9 Turbo. Users suggest checking for oil leaks from the valve cover, pneumothorax hose, or the suction manifold. The presence of a vacuum in the system complicates the identification of the oil source. The author mentions a puddle of oil in the depression of the pear and indicates that the engine is a 1.9 TDI with an unknown year due to a previous replacement. Recommendations include washing the affected areas and inspecting for cracks or leaks.
