Electrolux EWS10410w Washing Machine: E40 Error, Burned Cord, Door Lock Mechanism & Repair
Jan Gdynia 17130 9
How can I fix an Electrolux washing machine E40 error caused by a burned door-lock connector, and do I need to replace the whole lock or cable?
Yes, a burned connector at the door lock can cause the E40 error, and the recommended fix is to cut off the burned section and crimp on new connectors rather than replacing the whole cable [#16720155][#16721063] If the original plug can still be used, clean the contacts and tighten the blades, but several replies recommend replacing the damaged plug with individual automotive-style connectors [#16719962][#16720155] After the connector was repaired, the error disappeared, but the lock was still very noisy, which pointed to a defective lock mechanism itself [#16722689] Replacing the lock still left the same buzzing and E40, so the next suspect is the control electronics [#16726596]
  • #1 16719725
    Jan Gdynia
    Good day.
    I would like to deal with the repair of the washing machine.
    The E40 error popped up in the washing machine mentioned above. After browsing the Internet, I found information that the cause of the failure could be related to the door lock or its control. I also found a guide on how to check the condition of the mechanism. I got inside and the end of the cord to the lock (ankle) on one joint is burned out. The question is whether this causes an error or should you also replace the entire mechanism? And will I be able to replace only this ankle or maybe I will have to replace the whole cord?
    I attach pictures of the wire and the mechanism itself. Electrolux EWS10410w Washing Machine: E40 Error, Burned Cord, Door Lock Mechanism & Repair Electrolux EWS10410w Washing Machine: E40 Error, Burned Cord, Door Lock Mechanism & Repair Electrolux EWS10410w Washing Machine: E40 Error, Burned Cord, Door Lock Mechanism & Repair
  • #2 16719962
    Loker
    Help: 575
    Rate: 721
    Clean the contacts, cut the blades in the plug for better contact, assemble and check if it works.
    If the plug can not be repaired then you can use four individual "car" connectors - just do not mistake the order of the wires.
  • #3 16720155
    luk_jag
    Home appliances specialist
    Help: 67
    Rate: 257
    Do not clean anything, just cut and put on connectors. Only troubles can wait for you from this burnt plug-in.
  • #5 16720795
    luk_jag
    Help: 67
    Rate: 257
    Exactly that.
  • #6 16721063
    zhudomel
    Help: 1280
    Rate: 3373
    Just cut out this burned out fragment and put a clip on the cut out cable.
  • #7 16722689
    Jan Gdynia
    After connecting the lock in the door with connectors, the error has disappeared, but the lock itself works terribly loud - you can hear loud loudspeakers. It looks like the blockade itself is defective. I will order a new one from the Internet.
  • #8 16724432
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Order and save the washing machine until the new lock comes. I remember putting the connectors in a thermocouple, which would not be surprising
  • #9 16726582
    Jan Gdynia
    I connected a new lock of the lock and the same as on the old one - a loud buzz, a little bit and again the error E40. I marked all plugs before connecting them with connectors, I also secured the plugs with insulating tape. Any ideas what's next? I was able to call in the repairman in nn, I went too ambitiously to repair myself ...
  • #10 16726596
    nares
    Help: 1515
    Rate: 3386
    Jan Gdynia wrote:
    what's next ?
    Damaged electronics, but a good service will overwhelm you.
The discussion revolves around the E40 error in the Electrolux EWS10410W washing machine, which is suspected to be caused by a faulty door lock mechanism. The user discovered a burned cord at the lock's connection and sought advice on whether to replace just the damaged cord or the entire lock mechanism. Responses suggested cutting out the burned section and using connectors for repair. After attempting the repair, the user reported that the error disappeared, but the lock operated loudly, indicating a potential defect. A new lock was ordered, but the E40 error reappeared, leading to speculation about possible damaged electronics. The user considered professional repair services after unsuccessful attempts at self-repair.
