Eliminating Mouse Presence in a Toyota Avensis T25: Strategies and Techniques
Matyjass16 13245 12
How can I stop mice from getting into my Toyota Avensis T25 and find where they are entering?
Check and seal the car’s entry openings, especially the trunk inlets, because that is where the mouse is likely getting in, and do not rely on ultrasonic repellers alone since they were reported to have no effect [#16720594][#16720600] One suggestion was to move the acoustic transmitters into the cabin, but the same user later said it still did not help [#16720585][#16720594] For deterrence, forum users suggested anti-marten spray (ANTY KUNA) sold in motoring stores for about PLN 14 and scents mice dislike, such as lavender and mint [#16741709][#16720926] One warning was that rodent poison can leave a bad smell if the animal dies hidden inside the car [#16720650]
  • #1 16720304
    Matyjass16
    Level 4  
    Rate: 24
    As in the subject, I have a pest in the car from time to time, I set the trap and there is peace for some time. I can't locate which ones are entering, please give me a hint how to get rid of this problem
  • #2 16720316
    DiZMar
    Help: 2887
    Rate: 6615
    Scatter food (such pink granules) in places not available on a daily basis to buy in garden stores. After him, the mice lose their lives and dry without smell.
  • #3 16720417
    Matyjass16
    Level 4  
    Rate: 24
    I have scattered poison and so from time to time I feel in the car with mice, I'm fed up with buying air conditioning refreshers because it only fights this stench. In addition, a rodent repellent is installed under the hood which does not help
    romuald-f
    A/T specialist
    Help: 406
    Rate: 1546
    The only place the mouse can get in: Eliminating Mouse Presence in a Toyota Avensis T25: Strategies and Techniques Eliminating Mouse Presence in a Toyota Avensis T25: Strategies and Techniques
  • #5 16720585
    kot mirmur
    Help: 206
    Rate: 560
    Hello, maybe try to move the acoustic transmitters of this repeller to the vehicle cabin.
  • #6 16720594
    Matyjass16
    Level 4  
    Rate: 24
    Tomorrow I will look into the trunk and see these inlets. The repeller was in the cabin and in the trunk now is under the hood, unfortunately it does not bring any results, that is simply pulling the customer at the expense.
  • #7 16720600
    DiZMar
    Help: 2887
    Rate: 6615
    Matyjass16 wrote:
    ... Repeller ... does not bring any results, it is simply pulling the customer at the expense.
    Of course it's a pic for water and photomontage. This also applies to other repellents, e.g. electronic mosquitoes or as a candle. These are one-season products. In the next season, no one (or almost no one) will buy them anymore and they are not even on the same offer.
  • #8 16720623
    kot mirmur
    Help: 206
    Rate: 560
    A hedgehog would be useful, or a weasel. But the smell would be bigger. These mice probably get there after the pheromone smell. I suggest a visit to a good veterinarian or rodent expert, maybe he will advise you on something interesting.
  • #9 16720650
  • #10 16720926
  • #11 16721256
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1006
    Small mouse, small stench. Please imagine Skoda owner came to Skoda website in autumn who said that something in his car stinks terribly. After lifting on the car lift it turned out that the cat who liked heat from the engine so located the cat in a warm engine that he could not to get out of such a trap. In the morning the driver started the car and grinded the unfortunate. That was a problem.
  • #12 16741709
    kierbedz4
    Level 36  
    Help: 307
    Rate: 1006
    At the moment, in large-area stores in motoring departments, you can buy a specific agent to scare uninvited guests from your car by buying an anti-liquid spray called ANTY KUNA at a price of around PLN 14.
  • #13 16741727
    Ireneo
    Help: 747
    Rate: 2465
    Give the cat to the garage.
✨ The discussion revolves around strategies to eliminate mouse presence in a Toyota Avensis T25. Users suggest various methods including scattering rodenticide, using acoustic transmitters, and employing natural repellents like lavender and mint. Some participants express frustration with ineffective electronic repellents and recommend inspecting potential entry points in the vehicle. Additionally, a specific anti-liquid spray called ANTY KUNA is mentioned as a deterrent. Concerns about the odor from dead mice and the potential for other animals, like cats, to become trapped in the engine compartment are also raised.
TL;DR: In a Toyota Avensis T25, rodenticide can take about 5 days to work; “dies after 5 days.” Check trunk vents, use traps, and expect odor if poison is used. [Elektroda, 139534, post #16720650]
Why it matters: This FAQ helps Avensis T25 owners stop mice fast, prevent re-entry, and avoid lingering smells.
How do mice get into a Toyota Avensis T25?
Owners report a key entry path through the rear trunk ventilation inlets. Remove trim, inspect the flap vents, and fit mesh. Check for gnaw marks and droppings to confirm activity. Sealing this area reduces re-entry dramatically because it connects to the cabin paths. Focus first on the vents behind the bumper and side panels. Document findings with photos before reassembly for future reference. [Elektroda, romuald-f, post #16720546]
Do ultrasonic rodent repellers actually work in this car?
Forum experience calls them ineffective. One expert noted these devices are “a pic for water and photomontage,” and classed them as one-season gadgets. If you already have one, do not rely on it as a single solution. Pair physical exclusion with traps and cleaning. Prioritize blocking vents and removing attractants. This approach addresses cause, not symptom. [Elektroda, DiZMar, post #16720600]
Should I move the repeller’s acoustic transmitters into the cabin?
Some advise relocating the emitters inside the cabin to target where mice settle. If you try this, place units low and near suspected paths, and avoid soft materials that dampen output. Combine with sealing trunk vents for best effect. Re-test weekly and adjust placement. This is an add-on tactic, not a cure. [Elektroda, kot mirmur, post #16720585]
Will poison make the car smell, and how long until it works?
Yes. A mouse that consumes rodenticide can die after about five days, and the carcass can smell strongly. The odor persists until removal. Source location can be difficult in vehicles due to hidden cavities. If you choose poison, plan for inspection and cleanup. Use targeted trapping to avoid inaccessible deaths. [Elektroda, 139534, post #16720650]
Are there scent-based deterrents that actually help?
Users report that lavender and mint can reduce mouse presence. Place sachets near entry routes and the spare-wheel well. Refresh them regularly as volatile oils dissipate. Use them alongside traps and vent screening. Scent alone rarely solves active infestations but can support prevention after cleanup. [Elektroda, Anonymous, post #16720926]
What off-the-shelf spray can I try, and what does it cost?
Look for an anti-marten spray labeled “ANTY KUNA” in auto departments. It’s reported at around PLN 14. Apply to wiring looms, vents, and wheel wells per the label. Reapply after heavy rain or washing. Treat it as a deterrent layer, not a standalone fix. [Elektroda, kierbedz4, post #16741709]
Are traps still worth it if mice keep returning?
Yes. The original poster notes traps restore short-term peace, which confirms activity and reduces numbers. Use multiple snap traps along travel edges. Bait lightly to prevent theft without trigger. Keep trapping until catches stop for a week. Then focus on sealing the entry points to prevent recurrence. [Elektroda, Matyjass16, post #16720304]
Why does the smell persist even after I use air fresheners?
Air fresheners only mask odors. If poison was used, the smell indicates a hidden carcass or contaminated nesting. The poster was buying AC fresheners repeatedly without solving the source. Locate and remove the cause, then clean surfaces. Replace any contaminated soft trim if needed. [Elektroda, Matyjass16, post #16720417]
Where should I inspect first for nests or carcasses?
Start at the trunk side cavities and ventilation inlets, then inspect under trunk trim and spare-wheel well. Check engine-bay corners too. One cautionary case involved severe odor after an animal died near the engine. Hidden spaces trap smells, so remove panels methodically and document. [Elektroda, kierbedz4, post #16721256]
Can keeping a cat in the garage help deter mice?
A pragmatic suggestion is to keep a cat in the garage space. Predatory presence can deter rodents from approaching the vehicle. Ensure humane care and safety. Combine with sealing vehicle entry points for lasting results. Do not rely on pets to fix structural access issues. [Elektroda, Ireneo, post #16741727]
Do pheromones attract mice back, and who can advise professionally?
One user notes mice follow pheromone scent trails. Clean thoroughly to remove residues. For tailored strategies, consult a veterinarian or rodent-control specialist familiar with vehicles. They can advise on safe baits and exclusion methods specific to car interiors. [Elektroda, kot mirmur, post #16720623]
Quick 3-step: how do I block the Avensis T25 entry point?
  1. Expose the rear trunk ventilation inlets behind interior trim.
  2. Inspect flaps; clean, then add fine mesh that resists chewing.
  3. Refit trim and re-check after a week with traps as monitors. [Elektroda, romuald-f, post #16720546]
Are ultrasonic repellers under the hood better than in the cabin?
The poster tried both cabin and trunk placement, then under the hood, without results. This suggests placement alone won’t solve ingress. Use repellers only as a supplement while you seal entry points and trap actively. Prioritize exclusion. [Elektroda, Matyjass16, post #16720594]
Could bringing in other animals like hedgehogs or weasels help?
A user suggested predators such as a hedgehog or weasel, but warned of more odor issues. Wildlife introduction is impractical and risky in a garage. Focus on exclusion, cleaning, traps, and optional deterrent sprays instead. [Elektroda, kot mirmur, post #16720623]
