Daf 105 xf - ebs error in red and transmission error in yellow
erwin2000 9507 1
  • #1 16908705
    erwin2000
    Hello all.
    I decided to write about my problem because I got into it a bit and it cost me a few zlotys unnecessarily.
    After pressing the brake pedal to the limit, an ebs error appeared - engine brake system in red, and a transmission error in yellow.
    The first time I put the car for a week to a mechanic who claimed that he had let go of a wire somewhere, but he did not know where and how at the end (probably such a small fake), in any case, the error popped up regularly and when the car came to the mechanic, a mistake for China folk did not want to pop out. in any case, 500 or 600 PLN cost me a visit to the doctor.
    Everything was fine from August and then suddenly my old friend (ebs) remembered about himself. I decided to have fun. First I saw through the beam, everything ok. I thought that in the end, the wheels were removed, the sensors from the abs, on the right hub on the rear axle, everything used was leaking, I cleaned the sensors, and the abs crown and the car recovered.
    I am writing it with this because it might help someone, I was looking on forums and found nothing.
    Daf 105xf, slot machine from 2013
  • #2 16909477
    kisiol
    Help: 36
    Rate: 469
    He's a poor mechanic, probably a diagnosis of coffee grounds. If you're leaking from the rear hub, check the bearing, these are the symptoms.
