Ryzen 5 1600, GTX 1060 6GB, 16GB DDR4, MSI B350, 600W PSU: 4K PLN PC Build for Adobe Suite & Gaming
sacrev 5208 15
Is this Ryzen 5 1600 + GTX 1060 6GB PC build suitable for Adobe work and gaming, and what should I change before buying?
Yes—the build is basically fine for Premiere, Audition, Photoshop, Lightroom, and gaming; keep the GTX 1060 and buy an SSD later rather than dropping the graphics card. [#16724361] If you plan to overclock, add a better CPU cooler such as the SilentiumPC Fortis 3 HE1425 v2, or the Grandis 2 XE1436 if you want the stronger option for OC. [#16724361] The MSI B350 Tomahawk should support the Corsair Vengeance LPX 3000 MHz kit, but on Ryzen the realistic target is often 2667–2933 MHz depending on the exact board and memory, so check the motherboard QVL/compatibility list. [#16727371][#16727814][#16736513] A 2667–2800 MHz result was described as enough for Ryzen, and the G.Skill Aegis 2x8GB 3000 MHz CL16 was considered a good fit for this board. [#16727576][#16736769] The SilentiumPC Vero L2 600W PSU is sufficient for this configuration; one reply even said a branded 500W unit would already be enough. [#16727371]
  • Recommend adding an SSD and stronger CPU for Adobe work
    #1 16724303
    sacrev
    I am thinking of buying a PC for up to PLN 4,000. I submitted this configuration:
    AMD Ryzen 5 1600, 3.2GHz, 16MB processor (YD1600BBAEBOX)
    Gigabyte GeForce GTX 1060 G1 6GB GDDR5 graphics card
    Motherboard MSI B350 TOMAHAWK, AM4, DDR4, 2xPCI
    Memory Corsair Vengeance LPX, DDR4, 16GB (2x8GB), 3000MHz
    SilentiumPC Vero L2 600W power supply (SPC165)
    SilentiumPC Regnum RG1 Pure Black case
    Toshiba P300 disk, 2T
    The computer will be designed to work on video and audio materials (Adobe premiere, Adobe Audition, Photoshop, Lightroom) and comfortable playing video games. My question is whether this set is ok or can you make any changes that will turn out to be a plus. You can opt out of this model kK instead of SSD. I intend to do OC in the future, so I will buy a cooler at the right time.
    Thanks in advance for any help!
  • #2 16724361
    atomic99
    Help: 171
    Rate: 338
    Rather, there is nothing to give up on the graphics because it is quite a nice set for the moment, and buy an SSD in the future.
    I recommend CPU cooling for example [SilentiumPC Fortis 3 HE1425 v2] around 130-150 PLN and it will be quiet and cool. Unless you write OC as you write, then [SilentiumPC Grandis 2 XE1436] (I recommend it) around 160-180 PLN.
  • #3 16725806
    Ationx
    Help: 9
    Rate: 322
    When will you buy this set?
    What is your monitor
  • #4 16725978
    sacrev
    Prices have changed dramatically, so I modified the set, what do you think about performance and components?
    Palit GeForce GTX 1060 Dual 6GB GDDR5 graphics card
    Memory Corsair Vengeance LPX, DDR4, 2x8GB, 3000MHz, CL15
    SilentiumPC Regnum RG1 Pure Black case (SPC143)
    Toshiba P300 Drive - (HDWD120UZSVA)
    I want to buy as soon as possible when I am sure that the components are 100% correct and there will be no loss of performance. My monitor is Samsung SyncMaster SM 2032BW.
  • #5 16726067
    Ationx
    Help: 9
    Rate: 322
    On October 5, Intel is to present Coffe Lake, it would not hurt to wait this week ...
  • #6 16726817
    sacrev
    Do you think prices will go down?
  • #7 16727371
    sokar78
    Help: 124
    Rate: 139
    Just check if the memory is compatible with this disc (on the disc manufacturer's website) because it may turn out that they are running on 2133 or the computer will not want to boot. The power supply is 500W and branded enough.
  • #8 16727576
    Zenek1988
    Help: 65
    Rate: 64
    These memories should easily go to 2666 or 2800 MHz. With 2933 and 3066 MHz can be a problem. Here, depending on whether the record can do it. For me on asrock, despite the latest bios, unfortunately above 2800 MHz, the computer does not start. I do not know how in msi but in asrock each bios update slightly improves computer performance so it's worth having the latest upload.
  • #9 16727583
    sokar78
    Help: 124
    Rate: 139
    HyperX 2666MHz at a colleague on B350 Tomahawk I set it to 2933 quickly and gave 1.25V for safety, I still did not have time to play but I think that over 3000 will also do what people write
  • #10 16727814
    atomic99
    Help: 171
    Rate: 338
    The above motherboard without any problem should support these memories and even faster: 1866/2133/2400/2667 (OC) / 2933 (OC) / 3200 (OC) + Mhz
  • #11 16727825
    Ationx
    Help: 9
    Rate: 322
    No. But I think that Intel can present a sensible if not more sensible alternative in similar money to that of Ryzen.
  • #12 16727836
    sacrev
    Supported Memory Type:
    DDR4-2933 MHz
    DDR4-3200 MHz
    DDR4-2400 MHz
    DDR4-2133 MHz
    DDR4-2666 MHz
    Also, the memory should be just right, what do you think about the card, worth the candle?
  • #13 16727973
    Zenek1988
    Help: 65
    Rate: 64
    This year, do not count on something sensible because the only plates for coffe lake that will come out now are z370 and so the most expensive ones. Plus, add tax on new products, so you can forget about a reasonable alternative to rydzen in similar money. Maybe at the beginning of next year when cheaper boards come out and the processors will stand slightly, but then a new generation of ryzins will come out so it can also be different.
    It should but it depends on the specific disc and memory. In principle, 2667 or 2800 is sufficient for ryzeens. Above this, you need better memories and the performance increase is not so great. Higher clocks can be obtained mainly on memory based on samsung bones, on hynixes in most cases it is possible to hit a maximum of 2800 MHz.
  • #14 16736513
    sacrev
    It should but it depends on the specific disc and memory. In principle, 2667 or 2800 is sufficient for ryzeens. Above this, you need better memories and the performance increase is not so great. Higher clocks can be obtained mainly on memory based on samsung bones, on hynixes in most cases it is possible to hit a maximum of 2800 MHz. [/ Quote]
    What do you think about these bones:
    G.Skill Aegis DDR4 memory, 2x8GB, 3000MHz, CL16?
    They seem to be just right for msi tomahawka b250
  • #15 16736769
    Zenek1988
    Help: 65
    Rate: 64
    According to MSI, these memories should fire up to 2933 MHz. For such a set, these memories will be just right.
  • #16 16747635
    sacrev
    Thanks to everyone for helping in the election, PC bought. subject to close
The discussion revolves around a proposed PC build for video editing and gaming within a budget of PLN 4,000, featuring an AMD Ryzen 5 1600 processor, a GTX 1060 6GB graphics card, and 16GB of DDR4 RAM. Users provided feedback on the configuration, suggesting the addition of an SSD for improved performance and recommending a CPU cooler for overclocking. Compatibility of memory speeds with the MSI B350 motherboard was also discussed, with users confirming support for various DDR4 speeds. The conversation included considerations about potential price changes due to upcoming Intel product releases and the performance of different memory brands. Ultimately, the author confirmed the purchase of the PC components after gathering insights from the community.
TL;DR: PLN 4,000 build with 16GB DDR4 and GTX 1060 6GB; “don’t drop the GPU—add an SSD later.” [Elektroda, atomic99, post #16724361] Why it matters: This FAQ helps creators and gamers validate parts, RAM speeds, cooling, and timing before buying.
Is the Ryzen 5 1600 + GTX 1060 6GB build balanced for Adobe and gaming?
Yes. The thread confirms a well-matched setup for Adobe apps and comfortable gaming at this budget. The poster finalized purchase without issues. Prioritize the GTX 1060 6GB now and add an SSD later for snappier workflows. “Don’t give up on the graphics.” [Elektroda, atomic99, post #16724361]
Do I need an SSD on day one, or can I add it later?
Add it later. Keep the stronger GPU now to protect gaming and GPU-accelerated workloads. An SSD upgrade improves boot, app launches, and cache scratch speeds. This staged approach fits a hard 4K PLN cap and was the recommended path in-thread. [Elektroda, atomic99, post #16724361]
Which CPU cooler should I choose if I plan to overclock?
Pick SilentiumPC Fortis 3 for quiet stock or light OC. Choose Grandis 2 for heavier OC headroom. Both were recommended with price bands around PLN 130–180, delivering better thermals and acoustics than stock cooling. [Elektroda, atomic99, post #16724361]
Will MSI B350 Tomahawk run 3000 MHz DDR4 reliably?
The board supports DDR4 up to 3200 MHz (OC). Many users achieve 2933–3000 MHz, but Ryzen benefits level off near 2667–2800 MHz. Treat 2933–3000 MHz as an optimization goal, not a guarantee. [Elektroda, atomic99, post #16727814]
What’s the safe RAM speed target for first‑gen Ryzen?
Aim for 2667–2800 MHz for stability and value. Gains above that shrink unless using particularly capable memory ICs. One user noted Hynix-based kits often top out near 2800 MHz, while Samsung ICs fare better. [Elektroda, Zenek1988, post #16727973]
How do I check if my memory kit is compatible with the motherboard?
Verify the vendor QVL on MSI’s product page and cross-check part numbers. If unsupported, the system may default to 2133 MHz or fail to boot, requiring manual tuning. This is a common first‑gen Ryzen edge case. [Elektroda, sokar78, post #16727371]
Quick how-to: set RAM to advertised speed on MSI B350 Tomahawk
  1. Update BIOS, then enter UEFI and enable the memory profile (A-XMP).
  2. Set target speed (e.g., 2933 MHz) and DRAM voltage per kit spec.
  3. Save, boot, and stress-test; if unstable, drop one step (e.g., 2800 MHz). [Elektroda, sokar78, post #16727371]
Is a 500–600W power supply enough for this build?
Yes. A quality 500W unit covers a Ryzen 5 1600 and GTX 1060 6GB comfortably. The thread explicitly states 500W branded is enough, giving thermal and transient margin. [Elektroda, sokar78, post #16727371]
Should I wait for Intel Coffee Lake before buying?
A short wait was advised because Intel’s Coffee Lake announcement was slated for October 5. This could influence CPU choices or value. However, expect initial Z370 boards only, often at higher launch pricing. [Elektroda, Ationx, post #16726067]
Will prices drop when Coffee Lake launches?
No immediate drop was expected. Early Coffee Lake required new, pricier Z370 boards, limiting near-term value shifts. The advice was to wait for information, not price cuts. [Elektroda, Ationx, post #16727825]
Is G.Skill Aegis 2x8GB 3000 CL16 a good match here?
Yes. MSI guidance indicated operation up to 2933 MHz for that kit on the Tomahawk. It aligns with the 2667–2800 MHz sweet spot and offers a practical balance of cost and speed. [Elektroda, Zenek1988, post #16736769]
Can incompatible RAM settings prevent the PC from booting?
Yes. If timings or frequency exceed what the board and IMC handle, the system can hang or boot at 2133 MHz. Clear CMOS and retry with conservative settings if this occurs. [Elektroda, sokar78, post #16727371]
Will the Samsung SyncMaster 2032BW limit gaming performance?
That monitor is 1680×1050, which is less demanding than 1080p. The GTX 1060 6GB will drive higher settings and fps at this resolution compared with 1080p. This helps sustain smooth gameplay within the budget. [Elektroda, sacrev, post #16725978]
Any closing outcome from the original buyer?
Yes. The original poster confirmed the PC was purchased and closed the topic. That outcome signals the parts list worked as intended for the stated Adobe and gaming needs. [Elektroda, sacrev, post #16747635]
