combination of Satel Perfecta and Pyronix KX15DT (2EOL) detectors
Pawel_kkk 8433 7
  • #1 16726757
    Pawel_kkk
    Hello dear colleagues,
    I am an amateur in the topic of alarms, I am currently building a house and I intend to make an installation on the basis of the Satel Perfecta 32 control panel myself. For the time being, only 2 or 3 Pyronix KX15DT dual detectors will be installed to protect the closed shell. Later, the installation will be expanded with more detectors and reed switches.
    I have a hot request to verify the connection diagram of the control panel and detectors in the 2EOL / NC configuration. In principle, I do not use resistors built into the detector (no jumpers), I will connect external resistors.
    In the diagram, the TAMPER terminals from the detector housing have been connected to one COM terminal of the control panel. It may stay this way or do they need to be separated into separate COM? Will the tamper detection work properly with such a connection?
    I will be grateful for your opinions.
    Paul
    Advertisement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues Collection of topics
    Outputs (programmable and not only) of control panels
    How the control panel alarm outputs work
    Connecting any detector to any alarm control panel - guide
    How to connect the siren to the alarm control panel - guide
    We invite you to read the other guides, highlighted topics, articles in the field of security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Security Systems Tutorials
    If you do not find the answer to your question in the above-mentioned topics, please visit the forum:
    Security systems
    We also encourage you to visit the General Guides section, where you will find materials from other forum sections, including those for people starting their adventure with electronics:
    General Tutorials
  • #2 16726815
    juan cabrillo
    Help: 127
    Rate: 242
    It will be fine. And all COMs are electrically equal.
  • #3 16726839
    pepe33
    Level 19  
    Help: 32
    Rate: 29
    Think what these jumpers are at the bottom of the sensor for.
  • #4 16726861
  • #5 16726887
    Pawel_kkk
    The control panel requires two 1.1 resistors. This value cannot be obtained with jumpers.
  • #6 16726898
  • #7 16726965
    Pawel_kkk
    fakerus wrote:
    If it is impossible, you have to put them on according to the instructions, you wrote that you do not have jumpers? You put a jumper on 1K on the alarm and tmp 1K and everything.
    So as instead of external resistors. I will put 2 x 1K jumpers in the detector, although the control panel requires 2 x 1.1, will the alarm work properly?
  • #8 16726977
The discussion revolves around the installation of a Satel Perfecta 32 control panel with Pyronix KX15DT dual detectors in a 2EOL/NC configuration. The user seeks clarification on the connection diagram, specifically regarding the use of external resistors instead of built-in jumpers for tamper detection. Responses confirm that connecting the tamper terminals to a single COM terminal is acceptable, as all COMs are electrically equal. However, it is noted that the control panel requires two 1.1k resistors, which cannot be achieved with jumpers alone. Suggestions include using 1k jumpers in the detectors, which should allow the alarm system to function properly if connected as per the provided diagram.
