Perfectel 16 Satel & KX15DD Detector: Connection Diagram Verification & Alternate Methods
gtrs11 16959 6
  • #1 16985039
    gtrs11
    I have a problem with connecting the detector, is the diagram in the attachment correct or should I connect it differently?
    Thank you in advance for your answer Perfectel 16 Satel & KX15DD Detector: Connection Diagram Verification & Alternate Methods
  • #2 16985139
    viper19861
    Help: 55
    Rate: 55
    If it is to be a 2EOL / NC (or NO) connection, there is a shortage of resistors, 2 pcs, value 1.1k
  • #3 16985149
    gtrs11
    Thank you for the answer, and these jumpers that I marked on the sides of 1K 1K do not replace resistors?
    suworow
    Help: 650
    Rate: 1278
    I don't think there is a shortage :)
    It seems that the author of the question used the built-in detector which he marked by circling them.
    Either way, both ways are correct so you don't use both at the same time ;)
  • #5 16985215
    gtrs11
    i.e. next (4 total) detectors I connect to the same + - and to the next com and z2?
    And how to connect the reed switch?
  • #6 16985290
    bhtom
    Help: 446
    Rate: 604
    Why do you take on something you don't have? pale idea ...?
    Greetings.
  • #7 16985299
    viper19861
    Help: 55
    Rate: 55
    suworow wrote:
    viper19861 wrote:
    If it is to be a 2EOL / NC (or NO) connection, there are no resistors, 2 pcs, 1.1k value
    Thank you for paying attention. I looked at the connection diagram and did not notice these jumpers. best regards
    Advertisement
    Also read:
    Satel Perfecta alarm control panel, configuration - selected issues A collection of topics
    Outputs (programmable and not only) for control panels
    How the control panel alarm outputs work
    Connecting any detector to any control panel - guide
    How to connect the siren to the control panel - guide
    We invite you to familiarize yourself with other guides, featured topics, articles on security systems such as intercoms, gate and barrier automation, alarm systems, cameras, access control:
    Guides on security systems
    If the above topics do not find the answer to your question, please visit the forum:
    Security Systems
    We also encourage you to visit the General Guides section, where you will find materials from other sections of the forum, including those starting their adventure with electronics:
    General Guides
The discussion revolves around verifying the connection diagram for the Perfectel 16 Satel and KX15DD detector. The original poster inquires about the correctness of their connection setup, specifically regarding resistor requirements. Responses indicate that there may be a shortage of resistors (1.1k ohm) for a 2EOL/NC or NO connection. Some participants clarify that the jumpers marked in the diagram may not replace the resistors, and both connection methods can be valid if not used simultaneously. Further questions arise about connecting multiple detectors and integrating a reed switch into the system.
