NC+ Decoder Issue: No TVP1 & TVP2 Channels on 90cm Antenna & Octo Converter 8 Outputs
DarekRz4 14208 3
  • Missing only TVP1 and TVP2 on NC+ decoder
    #1 16709866
    DarekRz4
    Help: 20
    Rate: 163
    Yesterday I installed an antenna with an NC + decoder on a recreational plot (Black decoder without disk). New 90cm antenna and Octo converter 8 outputs (because this one was definitely functional because it worked at my house - I connected only one cable). After setting up the antenna (I have done it many times myself and my family) I have - Signal strength 86 and quality 71. Everything works perfectly with one exception. No TVP1 and TVP2 with the message Check the Hot Bird antenna system or something like that. As I check on these channels, strength and quality are the same as on operating channels, which is very high. I was stupid and I returned to the city leaving it all on the plot. Can any of my friends advise you about what a prime rule this? If I go on a weekend I would fight. I flipped through the channels from 1 of what I saw, reaching Eurosport, 113 or 115, all channels were without exception. Only these two are missing.
    greetings.
  • #3 16709916
    DarekRz4
    Help: 20
    Rate: 163
    So far, I have always succeeded without problems, but of course I am far from smarting because I am not RTV from antennas. Thank you so much mate for your help and best regards.
  • #4 16723599
    DarekRz4
    Help: 20
    Rate: 163
    After reinstallation are all programs.
    Thank you for your help.
