Recommended Routers with IPSec VPN Server Function for Small Branch Company - Budget up to PLN 1500
adrianic 10353 11
Which routers can run a full IPSec VPN server for a small branch office with a budget of up to PLN 1500?
With a budget of about PLN 1500, the most concrete recommendation is MikroTik RB1100AHx4 with hardware IPsec; it was quoted at about PLN 1200 and described as handling IPsec at 2 Gbit/s with a 128-bit key [#16734376] For smaller loads, MikroTik RB2011UiAS-2HnD-IN and RB3011UiAS were also mentioned, but the RB3011 may only help if the hardware acceleration path is available [#16733596][#16733652] If you want a more traditional VPN/security appliance, Cisco ASA5505 was suggested as a proven small-traffic option, and Zyxel ZyWALL devices were also recommended [#16733437][#16733601] The thread also emphasizes that there is no universal model for every branch, because the right choice depends on the expected VPN bandwidth, number of tunnels, and overall project requirements [#16733475][#16734969]
  • #1 16733404
    adrianic
    I would like to know which routers / modems you are using with the function of running a full IPSec VPN server.
    Maybe you have routers that you use every day and recommend? Budget up to approx. PLN 1500.
    The devices will be needed for a small branch company and each branch has a different internet provider.
    I am waiting for specific models of routers.
    Best wishes :)
  • #2 16733437
    tplewa
    Help: 222
    Rate: 1009
    Maybe not a router but, for example, Cisco ASA5505 ... as there is no big requirement for traffic should deal with it. Possible and some higher model (but here it will be difficult to put up a price) ...
  • #3 16733475
    bogiebog
    Help: 2569
    Rate: 1530
    We're waiting for VPN bandwidth specifics.
    What is your BPS up / down Internet connection?
  • #4 16733497
    adrianic
    Thank you for quick replies. PLN 1500 budget for one device. The bandwidth of the network depends on the location, unfortunately I have no information on this subject. I was asked to search for recommended devices with an IPSec VPN server. The move will not be big. I think that the basic devices will be able to manage with ease. I would like to find out only about a popular / recommended device with an IPSec VPN server for this price :)
    greetings :)
  • #5 16733596
    mick1
    Help: 47
    Rate: 118
    For a home-based specialist (only do not read this wrong - it's about support and cost - there must be someone with the concept, on the other hand does not provide such support as devices with purchased support) - eg mikrotik RB3011UiAS
    For a complete layman (nice interface, few configuration options) - ubiquiti (or unifi or edgerouter np infinity)
    For a small office without any great aspirations in terms of bandwidth - D-Link DSR250N
    More serious stuff (but at this price) - some haulers - either used, but faster, or new and weaker (but with support)
  • #6 16733601
    bogiebog
    Help: 2569
    Rate: 1530
    Take some zyxel, have a good opinion.
    zywall series.
  • #7 16733652
    tplewa
    Help: 222
    Rate: 1009
    Here, it will be difficult to buy something to service more tunnels (because I understand that they are to be site-to-site connections to one point, ie company headquarters, etc.) ... Another thing is buying a used Cisco you need to be legally invest in software as for cheaper hardware is not very profitable ... well, unless we load the content on the web as much as we like ;)
    In total, with this solution, it would be best to give "soap dishes" (ASA5505) and something bigger to the headquarters ... unfortunately, here the cost will increase and it will strongly :(
    I would like to let DLink off again as I do not want to restart the device every now and then ;) ... MT I think it's a good idea, and here, in total, if you choose Cisco or MT, you'll have to spend some time getting to know the hardware and software.
    Regarding this MT you would have to see what movement he would make at IPSEC ...
    At home I have RB2011UiAS-2HnD-IN and one VPN on it for the company ... I say so, there is not 50-60Mbps ... 3011 like a faster processor - I'm not sure if there is hardware acceleration available, because if not a large increase will ...
    Here it is worth to look at the MT offer, which is hardware acceleration, because it may turn out that it is better to choose a different model. But here I will not help because VPN on MT did not put on any bigger scales ...
    zywall series.
    Opinion opinion asked if someone was testing ;) I have heard good opinions about many equipment and in many cases it was not acceptable for me. Well, but as I say different are the requirements ... one will do a restarter and have a problem with the head, the other will prefer that the equipment works without such miracles ;)
    With the cheapest solutions, I can recommend the mentioned Cisco ASA with a clear conscience - I have done a lot of VPN solutions on this. On the other hand, it is also equipment with restrictions and you can choose something better ... but here the budget is not that ...
    On the other hand, there is still a bit of information to advise you because you do not know how it will be foiled, or VPNs are to be for users or to be able to rent branches from the headquarters ... to how many branches and what traffic ...
    Unfortunately, you have to do everything well so that you do not get the money in the blot ...
  • #8 16733747
    m.jastrzebski
    Help: 679
    Rate: 865
    The author wrote about small bandwidths, so I bet it would be enough for him.
    If not, then for some 1200PLN buy RB1100AHx4, there is hardware IPSEC.
    For a few more will be the first CR 9 port and this is already a small ISP willingly embracing the office so it is rather more ;-)
  • #9 16733754
    tplewa
    Help: 222
    Rate: 1009
    Well, this is not a relative term ;) That's why I wrote about it a little :)
    For this I do not know how many of these branches is to be and it is difficult to predict, as, for example, one of these branches will give some information to some of them (because a small company is also a relative term).
    RB1100AHx4 I think with a very good idea for this price ...
  • #10 16734108
    adrianic
    Hello!
    Thank you for your great interest, all models and reviews are noted in your file.
    I am waiting for further speeches.
    Greetings!
    Added after 7 [minutes]:
    One more thing, unfortunately I do not know all the details of this project.
    You can write and devices that will be able to handle large movements and those that will be better used with a small load.
    I collect reviews of the most interesting and best routers with the IPSec VPN function up to the amount specified.
    Best wishes ! :)
  • #11 16734376
    m.jastrzebski
    Help: 679
    Rate: 865
    adrianic wrote:
    Hello!
    Greetings!
    Best wishes ! :)
    Define this large movement and small number movements.
    The specified RB1100AHx4 has an encrypted 128-bit key in 2Gbit / s.
    It costs 1200 PLN.
    30-40 will get the cheapest microtik routers for 300PLN without hardware support.
  • #12 16734969
    tplewa
    Help: 222
    Rate: 1009
    And here the colleague makes the biggest mistake. It is impossible to design any network, the more difficult it is to find equipment. He has a colleague given example companies, among others, MikroTik and Cisco (do not confuse with Linksys by Cisco because it's rather a toy). You can add something from Juniper, Checkpoint, etc.
    However, it passes with the goal as you do not know the complex ... there is something universal that in the amount of up to 1500zl will work in every situation ...
    The above-mentioned companies can be easily used in more demanding applications without stress, something hangs, etc. Finally, playing with networks should be rather familiar :) There are also companies like Dix, etc. that make the equipment more for home use, but omit it. I practically abandoned such companies from a long time ago, even at home, and I use MT which has a great price / quality ratio. However, once I was building larger networks (several thousand users), I used Cisco and Juniper - sometimes Checkpoint ... hardware nice, unfortunately not too cheap ...
    I will say a gentle colleague takes a little from the side of the page so relentlessly putting it.
    First you need to make a project, check what bandwidth will be needed, eg what requirements puts the software used, etc. and then think what to buy - usually taking into account the whole budget, and not assuming that one device will cost about 1500 PLN ...
    For example, the mentioned Cisco ASA equipment as mentioned is not a router, it is basically a Firewall - but for Cisco routers, for example, it is better suited to applications such as VPN (in terms of performance) ... and here the question is whether it will be possible to use such equipment. In some cases this can be problematic, etc.
The discussion revolves around recommendations for routers with IPSec VPN server functionality suitable for small branch companies, with a budget of up to PLN 1500. Users suggest various models based on their experiences, highlighting the importance of bandwidth and the specific needs of the branches. Notable recommendations include the Cisco ASA5505, MikroTik RB3011UiAS, D-Link DSR250N, and Zyxel Zywall series. The conversation emphasizes the need for reliable devices that can handle VPN connections effectively, with considerations for both low and high traffic scenarios.
TL;DR: For small branches under PLN 1500, MikroTik RB1100AHx4 delivers about 2 Gbit/s IPsec; "RB1100AHx4 has an encrypted 128‑bit key in 2Gbit/s." [Elektroda, m.jastrzebski, post #16734376]
Why it matters: This FAQ helps small offices pick stable IPSec-capable gear and right-size throughput without overpaying.
Which specific routers under PLN 1500 include an IPSec VPN server for small branches?
Community picks include MikroTik RB3011UiAS, Ubiquiti (UniFi/EdgeRouter lines), and D‑Link DSR‑250N for simple use. These fit small offices with modest bandwidth and easier interfaces for non‑experts. Start with MikroTik if you want flexibility, or Ubiquiti for a simpler UI. [Elektroda, mick1, post #16733596]
Is MikroTik RB1100AHx4 worth it for heavier IPSec use at this price?
Yes. It’s cited around ~2 Gbit/s IPsec with 128‑bit keys and costs roughly PLN 1200, staying under budget. This headroom supports multiple tunnels and future growth. As one expert put it, “RB1100AHx4 has an encrypted 128‑bit key in 2Gbit/s.” [Elektroda, m.jastrzebski, post #16734376]
What IPsec speed should I expect from MikroTik RB2011 in practice?
Expect about 50–60 Mb/s for a single VPN, based on a user running RB2011UiAS‑2HnD‑IN at home to connect to work. Consider models with hardware acceleration if you need more throughput per tunnel. [Elektroda, tplewa, post #16733652]
Is Cisco ASA5505 a good budget VPN endpoint for branches?
Yes, when traffic needs are small. ASA5505 isn’t a router, but it handles low‑throughput VPN roles reliably for branch connections. Keep in mind licensing and support when comparing total cost. [Elektroda, tplewa, post #16733437]
Should I consider Zyxel ZyWALL for IPSec in a small office?
Yes. Zyxel’s ZyWALL series is recommended positively for small deployments. It offers straightforward IPSec features suitable for branch connectivity without complex tuning. Validate exact model specs against your tunnel count and speed needs. [Elektroda, bogiebog, post #16733601]
Do I need exact bandwidth numbers before choosing hardware?
Yes. You can’t design a stable VPN without clear requirements. One expert warns, “It is impossible to design any network… as you do not know the complex.” Define required throughput, users, and applications first. [Elektroda, tplewa, post #16734969]
Router or firewall for IPSec—what’s better here?
ASA is basically a firewall; Cisco routers often deliver better VPN performance in some cases. Match the role to your needs, budget, and support model. For branch links, firewalls can suffice; for high throughput, consider router‑class platforms. [Elektroda, tplewa, post #16734969]
How many tunnels and what topology should I plan for?
Decide if you want site‑to‑site links from branches to a central HQ and how many concurrent tunnels. Sizing depends on branch count and traffic patterns. Bigger hubs may need stronger hardware than branch endpoints. [Elektroda, tplewa, post #16733652]
I’m a beginner—what’s the easiest platform to administer?
Pick Ubiquiti (UniFi/EdgeRouter) for a friendly interface and fewer knobs. Choose MikroTik when you have expertise and want deeper control and features at low cost. [Elektroda, mick1, post #16733596]
Any reliability caveats with budget boxes?
Yes. One engineer advises avoiding certain D‑Link units due to stability complaints, like needing periodic reboots. For always‑on VPN, prefer platforms with proven uptime. [Elektroda, tplewa, post #16733652]
What higher‑end vendors are suitable if my needs grow later?
Plan for scalable options like Cisco, Juniper, or Check Point when moving beyond small‑office demands. They cost more but bring stronger performance and support contracts. Budget accordingly for licenses and maintenance. [Elektroda, tplewa, post #16734969]
How do I choose quickly when project details are fuzzy? (3‑step)
  1. Document must‑have metrics: tunnel count, min/max Mbps, users, and apps.
  2. Map roles: branch endpoints vs. a stronger HQ hub.
  3. Select within budget, prioritizing hardware IPsec acceleration where needed.
    “First you need to make a project… then think what to buy.” [Elektroda, tplewa, post #16734969]
What does “site‑to‑site VPN” mean in this thread?
It refers to permanent tunnels linking each branch to a central point, typically headquarters. Plan capacity for the hub and select lighter endpoints for branches as needed. [Elektroda, tplewa, post #16733652]
