[Solved] OpenWRT: Best Router Recommendations for VPN, Log Collection & IDS/IPS (2017-2018, Under PLN 300)
StefanSamoZło 9180 8
  • #1 17135049
    StefanSamoZło
    Rate: 23
    Hello, I'm looking for a good router for Openwrt, it's mainly about VPN, Log collection, and collection of web browsing packages for up to 5 computers max, as well as IDS / IPS, routers for 2017/2018 to issue up to PLN 300.
  • #3 17136128
    StefanSamoZło
    Rate: 23
    Well, yes, I prefer something tried out and not from the list of something that others use such basic information I found myself but awaits opinions :)
  • #4 17137105
    jarek7714
    Help: 85
    Rate: 119
    Maybe I will narrow the search a little bit https://eko.one.pl/forum/viewtopic.php?id=12006.
  • #5 17138833
    kiko80
    Help: 67
    Rate: 163
    Add a pair of gold and buy Tp-Link AC1750 (Archer C7)
  • #6 17138860
    StefanSamoZło
    Rate: 23
    Hmm, and a mikrotika for PLN 100 with a 600-650 MHz processor and 32 rams ?.
  • #7 17138946
    Heinzek
    Help: 554
    Rate: 494
    32 framework
    Don't buy anything with less than 64MB of RAM and 8MB of Flash memory.
    Do you need 5GHz WiFi?
    Search for something on AR71xx. they are quite stable in nature.
    If you want something stronger then on mvebu or ipq80XX.
  • #8 17138982
    StefanSamoZło
    Rate: 23
    I don't need 5ghz wifi, and for this mikrotiku you can give more frame?
  • #9 17420454
    StefanSamoZło
    Rate: 23
    I made a small computer 1x 1.6GHZ atom, 1GB of RAM 16gb Ipfire SSD.
The discussion centers around recommendations for routers compatible with OpenWRT, focusing on features such as VPN support, log collection, and IDS/IPS capabilities, all within a budget of PLN 300 for models from 2017-2018. Participants suggest looking for routers with at least 64MB of RAM and 8MB of Flash memory, with a preference for models based on AR71xx, mvebu, or ipq80XX chipsets. The TP-Link AC1750 (Archer C7) is recommended as a solid option, while a user mentions a low-cost MikroTik model. The author expresses a preference for tried-and-tested models rather than generic recommendations.
