Seeking Router Recommendations for Easy Nord VPN Configuration Within 500 PLN Budget
Eric Clapton 5175 12
Which router can I buy to easily configure NordVPN, ideally with Ethernet WAN and SIM support, for about 500 PLN?
For easy NordVPN setup, a Ubiquiti EdgeRouter plus a separate Wi‑Fi access point is a solid pick; if you want an all-in-one WAN/LTE router, MikroTik RouterBOARD Chateau LTE12 was also suggested [#19400656][#19413730][#19416099] The main caveat is network topology: VPNs can break or behave badly behind multiple NAT layers, so check whether you can replace the operator’s box or switch it to bridge mode, and make the Wi‑Fi unit work as an access point on LAN-to-LAN [#19400656][#19413805] MikroTik was specifically mentioned as supporting NordVPN, and the Chateau LTE12 has Ethernet WAN plus an LTE Cat12 modem, which is a more reasonable LTE class than older Cat4 devices [#19416099] DrayTek was described as refined and stable but expensive, while the Teltonika RUT950 you found was criticized as only LTE Cat4 and therefore not a great match for current networks [#19413805][#19414179] In the end, the thread starter reported that an ASUS 4G-AC68U worked after a firmware update, and NordVPN/OpenVPN configuration on it was simple [#19445040]
  • Need router with easy NordVPN setup and PPPoE support
    #1 19400493
    Eric Clapton
    I am currently working abroad and would like to come to Poland more often - unfortunately, the employer looks reluctantly at such trips due to tax issues. I thought I would install Nord VPN on the router and then I could rather freely drop in from time to time for a week in the bosom of my homeland.
    Could you recommend me a router on which I can easily configure Nord VPN (I already have an account, of course) or which will already have Nord VPN configured? As far as cash is concerned, let's say up to 500 PLN, but as if there is some miracle more expensive, and for some reason worth the price, I'd rather for the extra (for that peace of mind :) ).
    At home I've been tinkering with something lately, but on an old router, I installed some firmware on the dd.... generally without success, the problem was with the login credentials: connection to the network was by login and password, and the connection type was something on P.... PP... I do not remember exactly.
    Thank you very much for your help,
    Eric Clapton.
    Multiple NAT can break VPN router setups
    #2 19400656
    IC_Current
    Help: 1499
    Rate: 2521
    Ubiquiti Edge Router
    https://support.nordvpn.com/Connectivity/Rout...dgeRouter-and-Ubiquiti-setup-with-NordVPN.htm
    However, it's a matter of what you already have and what your Internet connection parameters are because, first of all, you may not be able to replace the operator's device with your router and, secondly, if you connect two routers in cascade (the operator's and your own) then nothing may work. VPN connections (and any slightly more advanced network service) strongly dislike multiple NAT.
  • #3 19413688
    Eric Clapton
    Thanks for the answer. I have an RJ45 cable for output with the net - I see that this router is without WIFI - will it work for me such an arrangement:
    cable I connect to this router - there I configure VPN with nord vpn and connect another router already with WIFI with a regular network cable?
    Thanks in advance for your help!
    Tymek
    Access point mode required behind operator router
    #4 19413730
    IC_Current
    Help: 1499
    Rate: 2521
    Eric Clapton wrote:
    I connect to the net with an RJ45 cable
    But what kind of device do you have from the operator, possibly do you have a public IP address, because without this VPN may not work at all or work with problems.
    Eric Clapton wrote:
    I connect another router already with WIFI with a regular network cable
    Yes, but the additional device must work in access point mode and not router mode, meaning that you connect it to the LAN port. The WAN port on a device with WiFi DOES NOT have to be used. Here's a tutorial: https://www.tp-link.com/pl/support/faq/417/
  • Clarifying LAN-to-LAN AP setup behind SIM router
    #5 19413750
    Eric Clapton
    Thanks a lot. With this AP clear - that is, normally from LAN to LAN I will connect.
    I don't know exactly - because I would like to use this routeraz in 2 places: when we visit my house and the wife's house. At the wife's house may be harder - because as far as I know they have SIM card internet. In the sense that there is a router with a SIM card. So here I would have to do the same:
    router with SIM --- > our router with network cable ---> router with WIFI (as AP with LAN->LAN)
    connection between router with SIM and ours also like Access Point?
    I will read this guide :) .
    Double NAT can hinder VPN operation
    #6 19413805
    IC_Current
    Help: 1499
    Rate: 2521
    Yes, just be sure to change the IP address and disable the DHCP server on the device with WiFi.
    Eric Clapton wrote:
    I would like to use this routeraz in 2 places: when we visit my house and my wife's house.
    This is possible, however, you will need to change the WAN port settings each time (or you will need to have two configurations that you will upload interchangeably).
    You'll only find out after testing if it works. Alternatively, before buying a router you can upload the OpenVPN client to your PC and test the connection.
    Eric Clapton wrote:
    Connection between the router with SIM and ours also like an Access Point?
    There are two solutions. Either switch the LTE router to bridge mode and connect the UBQ to the WAN port, then there will be only one NAT at the operator and a better chance of VPN operation. You can not switch the LTE router into bridge mode but leave it as a router with NAT, the UBQ router here must also be connected to the WAN port. Unfortunately, with such a connection there are as many as two (or even three) times NAT is done (at the operator, on the LTE router and on the UBQ router). This can effectively hinder the operation of the VPN.
    If you are targeting devices with WiFi. Then you can also look at Draytek. Very refined and stable, unfortunately they cost their own:
    https://www.draytek.co.uk/support/guides/kb-vpnservice-nordvpn
  • Suggesting a Teltonika router with OpenVPN support
    #7 19414154
    Eric Clapton
    Hey, it's still me! :)
    it appears that probably the easiest way would be to have one router: with WLAN input (at my place in the block), SIM input (at my wife's) and with VPN. :)
    I found something like this - what do you think about it, because I see that you are a bit in networks? :)
    https://voip.world/Teltonika-RUT950-Dual-SIM-LTE-Router-WLAN-OpenVPN
    If it would be reasonably ok then I will buy. It's not about power and range, the most important thing for me is that it's possible to connect and that the VPN will laugh (I have a NordVPN account, but I guess it's just a matter of configuration in OpenVPN).... I would also take the wireless one there, well, but that would not solve the issue of VPN at the wife's...
    thanks again for your help!
  • LTE cat 4 router is too slow for current networks
    #8 19414179
    IC_Current
    Help: 1499
    Rate: 2521
    Not a WLAN input (because it is otherwise Wi-Fi - Wireless LAN) and with a WAN input.
    This router what you propose is in terms of LTE network electrosmash cat 4. Completely unsuitable for the current capabilities of the operators' transmitters. Speeds you will achieve on it tragic (yes, I know a lot of people still use such monuments :-) )
    Otherwise, there will be work anyway - either change the configuration you change the SIM card.
  • Considering DrayTek Vigor 2620Ln for LTE and NordVPN
    #9 19415880
    Eric Clapton
    Thanks a lot! I'm the one who is green, I would immediately buy thinking that good, because more expensive than a router for 100 zł. I have a question, because I'm already focusing only on these LTE (possibly I'll buy this EDGA, but that's later), because with LTE router in total I'll be able to work everywhere. What do you think about this:
    I guess even NordVPN is supported on it - a big advantage.... Thanks in advance!
  • Recommend checking LTE bands and considering MikroTik Chateau LTE12
    #10 19416099
    IC_Current
    Help: 1499
    Rate: 2521
    LTE 4G/3G Modem - Up to 150Mbps
    Integrated LTE 4G/3G (Category 4) modem, with speeds up to 150Mbps Downstream and 50Mbps Upstream.
    Compatible with EE, Vodafone, O2 and Three mobile networks and any MVNOs on those networks.
    Benefits: High speed Mobile Broadband. Versatile Connectivity.
    Also an old-school cat 4 modem.
    If you want to select a decent LTE router and possibly an antenna, first of all you need to write what device you are currently using and know on what bands the operator transmits (in Poland there are bases with transmitters for this, abroad probably also but I do not know). You can check this by forcing a band on some routers and checking the signal parameters. Sometimes you can also check roughly the bands with some modern smartphone with Android and the NetMonster app.
    Added after 12 [minutes]:
    There is something like this MIKROTIK ROUTERBOARD CHATEAU LTE12 (RBD53G-5HACD2HND-TC).
    It has Ethernet WAN ports and LTE cat 12 modem, which is already quite reasonable. Mikrotik itself supports NordVPN.
    Whether this particular model has a full RouterOS or somehow truncated I don't know, nor do I know how this model performs in practice. Generally with old Mikrotiks there were problems sometimes, now they seem to have removed the diseases of adolescence. You can always order from the online store for 14 days and possibly send it back.
  • #11 19416410
    Eric Clapton
    Thanks again for your help. Currently at my in-laws they have internet from plusa and they are using a model: Huawei B315s-22 (something like this: https://routery.pl/?p=238).
    I'll look for this Microtronic - may I find it then I'll solve all my problems! :)
    Thanks!
  • Force LTE band tests with HuaCtrl and evening speedtests
    #12 19416426
    IC_Current
    Help: 1499
    Rate: 2521
    Akurat link from Plus is the last possible choice. Plus invests very little in the network and does not expand it on an ongoing basis due to which the results are often tragic. This B315 is also just a cat 4 router.
    When you are at your in-laws, download the HuaCtrl app on your android. Log into the router from it and force specific bands (B1, B3, B7. B20). Give the forum the results of signal parameters measurements and speedtest from the evening hours for each band. Do the measurements for each of the four networks. You may find that you will be matched with an operator providing a much higher level of service.
    Also give the location of your in-laws' house, then we will roughly check what capabilities the transmitters of each operator have.
  • ASUS 4G-AC68U works with NordVPN after update
    #13 19445040
    Eric Clapton
    I had to let you know how the problem was solved. I'll remind what I wanted:
    router:
    - with Ethernet WAN input,
    - with SIM input,
    - with VPN - preferably with Nord VPN configuration
    Finally I bought ASUS 4g-ac68u.
    Finally everything worked! At my in-laws necik from the SIM card worked nicely - I just had to zupdate the software to make the VPN work using OpenVPN NordVPN configuration simple as a wire.
    In my house necik with RJ45 input - also played and trumpeted.
    LTE admittedly category 6, but for work purposes everything worked, which I wanted to achieve.
    Thank you very much for your help!
The discussion revolves around seeking router recommendations for easy Nord VPN configuration within a budget of 500 PLN. The user aims to set up a router that can handle both Ethernet WAN and SIM card inputs, allowing for VPN use in different locations. Various routers were suggested, including the Ubiquiti EdgeRouter, DrayTek Vigor 2620Ln, and Mikrotik Routerboard Chateau LTE12. The user ultimately decided on the ASUS 4G-AC68U, which supports Nord VPN configuration and functions well with both SIM and Ethernet connections. The conversation also highlighted the importance of network settings, such as using access point mode and managing NAT issues for optimal VPN performance.
TL;DR: LTE Cat 4 peaks at 150 Mbps, and "Also an old-school cat 4 modem." For easy NordVPN, choose OpenVPN-ready routers (e.g., MikroTik) and prefer Cat 12 LTE. This FAQ helps remote workers set up NordVPN on routers with Ethernet or SIM uplinks. [Elektroda, IC_Current, post #19416099]
Why it matters: The right hardware and topology prevent double NAT and keep NordVPN stable across home and LTE links.
Will Ubiquiti EdgeRouter work with NordVPN, and what should I watch for?
Yes. NordVPN provides a setup for EdgeRouter’s OpenVPN client. Replacing the ISP router may be impossible. If you must cascade routers, expect problems. "VPN connections strongly dislike multiple NAT." Plan a single NAT topology when possible. [Elektroda, IC_Current, post #19400656]
How do I set my second Wi‑Fi router as an Access Point behind a VPN router?
Use an access‑point style setup. How‑To:
  1. Change the Wi‑Fi device’s IP to your LAN and disable its DHCP server.
  2. Leave routing and NAT off on the Wi‑Fi device.
  3. Connect VPN router LAN to the Wi‑Fi device’s LAN port; ignore its WAN port. This keeps one subnet and preserves the VPN tunnel for all clients. [Elektroda, IC_Current, post #19413805]
Will my VPN work behind an LTE/SIM router?
It can, but bridge the LTE router if possible. Then connect your VPN router to its WAN port. Without bridge mode, you add two or even three layers of NAT. That often hinders or breaks VPN connectivity and performance. Test before buying. [Elektroda, IC_Current, post #19413805]
Do I need a public IP address for router‑based VPN to work?
A public IP from your ISP helps. Without it, the VPN may not establish reliably. The author warns, "without this VPN may not work at all or work with problems." Confirm your ISP plan and equipment capabilities first. [Elektroda, IC_Current, post #19413730]
Is Teltonika RUT950 a good all‑in‑one NordVPN router?
Avoid it for performance. The RUT950 uses LTE Category 4, which the expert calls outdated. Expect disappointing speeds versus modern networks. Seek newer LTE categories if you want comfortable VPN throughput. [Elektroda, IC_Current, post #19414179]
Is DrayTek Vigor 2620Ln fast enough for LTE VPN?
It uses an integrated Cat 4 modem. That supports up to 150 Mbps down and 50 Mbps up. The expert labeled it “old‑school Cat 4.” Consider higher categories for sustained VPN performance. [Elektroda, IC_Current, post #19416099]
Which MikroTik model was suggested, and why?
MikroTik Chateau LTE12 was suggested. It offers a Cat 12 LTE modem and Ethernet WAN. RouterOS supports NordVPN’s OpenVPN client. Performance varies, so order and test. Retailers often allow 14‑day returns. [Elektroda, IC_Current, post #19416099]
What actually worked in this thread?
The OP succeeded with an ASUS 4g‑ac68u. A firmware update enabled OpenVPN with NordVPN files. It worked both on SIM‑based LTE and an RJ45 Ethernet WAN. For work tasks, Cat 6 throughput proved sufficient. [Elektroda, Eric Clapton, post #19445040]
How should I wire things when I already have an ISP router and want Wi‑Fi?
Run the Wi‑Fi device as a simple access point. Connect the main router’s LAN to the Wi‑Fi device’s LAN. Do not use the Wi‑Fi device’s WAN port in this role. This avoids creating another NAT layer. [Elektroda, IC_Current, post #19413730]
Can I use one VPN router in two homes with different uplinks?
Yes. Prepare to change WAN settings when you move the router. Alternatively, maintain two saved configurations and swap them as needed. That keeps each site’s parameters correct and avoids downtime. [Elektroda, IC_Current, post #19413805]
How can I check LTE bands and pick a better operator?
At a Huawei B315, use the HuaCtrl Android app. Log in, force bands B1, B3, B7, and B20. Measure evening signal and run speed tests on each band and operator. If results are poor, consider changing operators. [Elektroda, IC_Current, post #19416426]
Is Plus a good LTE choice for VPN?
Expect weaker results. The expert calls Plus the last choice due to limited network investment. Test alternatives at your location first. Performance differences can be dramatic. [Elektroda, IC_Current, post #19416426]
Do I need a router with WAN or WLAN to plug in my internet?
You need a WAN port for the uplink. WLAN refers to Wi‑Fi, not the wired internet input. Choose routers with Ethernet WAN and, if needed, LTE SIM support. [Elektroda, IC_Current, post #19414179]
