Pocket retro emulator on Chinese FPGA by piotr_go.
piotr_go 29004 38
  • A pocket retro emulator on an Anlogic Chinese FPGA packs 8MB of 32-bit SDRAM and fits in 24x40mm.
  • A JDY-08 wireless module with CC2541 and custom firmware handles keyboard, mouse and pad communication, including Logitech Unifying devices.
  • FPGA configurations load from 16MB flash, while the SD card updates firmware and stores ROMs or other applications.
  • Test cores for NES and Amiga already run, although the Amiga core still has a sprite bug.
  • A custom pad is still in the case-design phase, and a C64 core may come later.
  • Pocket retro emulator on Chinese FPGA by piotr_go.
    Welcome back.
    This time I present a retro-emulator based on the Chinese FPGA by Anlogic.
    The emulator has 8MB of 32bit SDRAM embedded in FPGA. The JDY-08 wireless module based on the CC2541 chip, which I programmed with my own FW, is responsible for communication with the keyboard, mouse, pad ... FPGA configurations are loaded from 16MB flash on the board. The SD card is used to update FW, load ROMs or other applications depending on the loaded configuration. The emulator is compatible with the Logitech Unifying keyboard and mouse. Own Pad in the design phase of the case.
    At the moment I have run some test cores, NES and Amiga (there is still some bug in sprites). I will probably start with the C64 later.
    Dimensions of the emulator 24x40mm.
    Emulator:
    HDMI adapter and electronic circuit board Pocket retro emulator on Chinese FPGA by piotr_go. Pocket retro emulator on Chinese FPGA by piotr_go.
    Pad:
    Joystick:
    piotr_go
    DIY electronics designer
    piotr_go wrote 2910 posts with rating 3352, helped 94 times. Been with us since 2003 year.
  • #2 17812729
    eMCe2
    Rate: 15
    COOL!
    If there will be a version to buy, let me know :) I will gladly buy it!
  • #3 17813091
    SylwekK
    Level 32  
    Help: 82
    Rate: 2763
    You're crazy, Piotr :) Did I understand correctly, did you run the Amiga on it ??
  • #4 17813112
    Slawek K.
    Help: 259
    Rate: 1303
    As always, my friend is great, respect ;)
    Greetings
  • #5 17813190
    mipix
    Help: 495
    Rate: 1485
    Great, I take it!
  • #6 17813192
    KulawyR
    I would also like to buy this miracle.
  • #7 17813328
    szeryf3
    Level 30  
    Help: 12
    Rate: 674
    Cool miracle.
  • #8 17813493
    piotr_go
    Help: 94
    Rate: 3352
    High license costs for HDMI + Logitech support from reverse engineering = poor sales opportunities.
    SylwekK wrote:
    Did you run the Amiga on it ??
    Yes. I still have sprites to fix because there are some differences in the interpretation of veriloga by Tang Dynasty (soft Anlogica).
  • #9 17813640
    sosarek
    Help: 9321
    Rate: 15545
    Short and to the point - KOZAK !!!
    Something about costs, options?
    Z
    Pka, Poznań, 60-850
  • #10 17813694
    piotr_go
    Help: 94
    Rate: 3352
    sosarek wrote:
    Something about the cost
    The biggest cost is your time. Tiles + template is about PLN 200 if I remember correctly. FPGA I managed to get a few samples because I couldn't find it anywhere. The radio module is less than $ 2.
    sosarek wrote:
    additional possibilities?
    Whatever comes to mind.
    Oscilloscope / analyzer, hehe, a popular topic recently.
    For example, you can try your hand at creating a sling with your own set of instructions.
    The main menu is on a Cortex M0 compatible prock that I wrote.
    Instead of a radio module, you can connect a USB host and use any peripherals.
  • #11 17813810
  • #12 17813835
    sosarek
    Help: 9321
    Rate: 15545
    Which transmitter did you use in the joystick - I can see that it has RS232.
    I wonder what the emulation of e.g. PSX or N64 would look like on this one.
    Have you thought about introducing the option to scale to full screen?
    Z
    Pka, Poznań, 60-850
  • #13 17814033
    tronics
    Help: 359
    Rate: 845
    you can give a displayport (royalty free) and if someone wants to connect to the TV, he will buy an adapter for PLN 5 ;)
  • #14 17814261
  • #15 17814291
    piotr_go
    Help: 94
    Rate: 3352
    atari_robbo wrote:
    Is it some kind of documentation
    In Chinese.
    sosarek wrote:
    What kind of transmitter did you use in the joystick - I can see that it has RS232.
    In the new one, also reprogrammed CC2541 ($ 2 per module, I did not want to solder :) ).
    In the old nrf24l01 + proc.
    I do not use RS in them.
    No chance too small and too slow FPGA.
    NES? There is an option with full stretch, I did not include in the video.
    Minimum bitrate too high.
  • #16 17814728
    Macosmail
    Help: 227
    Rate: 863
    Well, I can't pass by indifferently. Concrete project. With a lot of commercial potential, I would say.
    What is the performance of the Amiga reproduced in such a way? Is it a version with AGA chips?
    I am still waiting for the Amiga in FPGA with HDMI with a graphics card and a performance of min. 68060 100MHz for the price of a Raspberry Pi. If the owners of the rights to Amiga OS 3.1 made it available along with the sources on some free license, there would be a chance for a wider promotion of this system.
    Congratulations.
  • #17 17814747
    piotr_go
    Help: 94
    Rate: 3352
    The performance and parameters of the 600ki so far, but it should fit a better core with AGA and a performance of 68030 ~ 40MHz.
    Not fast, you need a large FPGA for that.
  • #18 17817249
    leonow32
    Level 30  
    Help: 37
    Rate: 1232
    Impressive project !!! However, the most I wonder why did you choose such FPGA and not some Spartan or something more common? What is the price difference of these Chinese FPGAs compared to analogous chips from Xilinx or Lattice?
    You stole my heart by playing the lost vikings :) the last time i played this was about 20 years ago
    If you were wondering about the production of this miracle, I can advise you
  • #19 17817424
    piotr_go
    Help: 94
    Rate: 3352
    Integrated SDRAM, small form factor not BGA.
    Are there any with SDRAM?
  • #20 17817904
    leonow32
    Level 30  
    Help: 37
    Rate: 1232
    The Chinese will kill us all one day :) and how price is it? How much does this scalak cost?
  • #21 17818046
    piotr_go
    Help: 94
    Rate: 3352
    They will force a drop in prices.
    Prock programmer for 10gr. in preparation, also on a cheap Chinese microcontroller. :)
    The BGA version cost less than $ 10, I haven't seen this one.
    I suspect that the price in the Chinese market is below $ 5 module can be purchased for about PLN 50.
  • #22 17818164
    tmf
    Help: 2090
    Rate: 2206
    FPGA has been turning me on for a long time. What software are you using? There are also ready environments for the Chinese ones, or what does it look like?
    Full admiration for the implementation of these computers in FPGA - when did you manage to do it? After all, this is a processor implementation (half the trouble with 6510 from C64, but 68000, that's not just anything), plus all the Agnus, Denis, Paule, etc. from Amiga, all time dependencies ... in line :) I'd love to play some childhood games again.
  • #23 17818230
    piotr_go
    Help: 94
    Rate: 3352
    Soft to them is called "Tang Dynasty". ~ 150MB, not bloatware like Xilinxa or Altery.
    tmf wrote:
    Full of admiration for the implementation of these computers in FPGA - when did you manage to do it?
    Only the main one and some of the test ones were done by myself.
    The rest are modifications of commonly available cores that had to be adapted to different FPGAs and memory.
    There was a lot of work to do with it, but less than doing it from scratch.
    If I insisted, I would finish my own amiga core, I have some done - Lisa and Paul that I needed for another project.
  • #24 17818238
  • #25 17818259
    piotr_go
    Help: 94
    Rate: 3352
    atari_robbo wrote:
    In my opinion, they will not force too much - the vast majority of the cost of FPGA production goes to software.
    It is not only about FPGA but all kinds of scalers.
    If it is profitable, the producers will translate the documentation. Besides, you don't need proper documentation for everything, often a (terrible) google translation is enough.
  • #26 17818480
    tronics
    Help: 359
    Rate: 845
    FPGAs are used in niche small-lot applications
    Niche and small lot? Probably agreement with niche, absolutely not with this small series. It seems to me that too few devices were dismantled by my colleague to draw such far-reaching conclusions.
    Only how many generations of different chips do these environments support, how many additional tools do they have (which few people use and know what they are for)? :) Something for something.
  • #27 17819496
    John5MM
    Level 19  
    Rate: 402
    What will be the price with the C64 support version?
  • #28 17847058
    Tommy82
    Help: 455
    Rate: 1074
    And it would not be possible to socket an ordinary keyboard? PS2 / USB. It would be more universal.
    All in all, the question is why exactly such a keyboard? Is it wireless?
  • #29 17847680
    piotr_go
    Help: 94
    Rate: 3352
    In development. It will come down a little longer with this.
    - Because it's wireless
    - Because I have.
    - Because I figured out the pairing, key extraction and decryption.
  • #30 18012853
    ploty
    Thanks for share. i will get 1 next week
The discussion centers around a pocket retro emulator developed by piotr_go, utilizing a Chinese FPGA from Anlogic. The emulator features 8MB of 32-bit SDRAM and a JDY-08 wireless module based on the CC2541 chip for peripheral communication. It supports configurations loaded from a 16MB flash memory and utilizes an SD card for firmware updates and ROM loading. Initial tests have successfully run NES and Amiga cores, with plans to include C64 support. The compact design measures 24x40mm, and there are inquiries about potential commercial availability, performance specifications, and the choice of FPGA over more common alternatives. The project has garnered interest for its innovative use of integrated SDRAM and wireless capabilities.
TL;DR: 24 × 40 mm board integrates an Anlogic FPGA with 8 MB SDRAM and boots NES/Amiga; parts cost ≈ PLN 200; “HDMI licence fees kill margins” [Elektroda, piotr_go, #17812584; #17813694; #17813493].
Why it matters: It proves that sub-$10 Chinese FPGAs can power pocket-sized retro consoles without external RAM.
• Size: 24 mm × 40 mm (960 mm²) [Elektroda, piotr_go, post #17812584] • Memory: 8 MB 32-bit SDRAM integrated on FPGA die [Elektroda, piotr_go, post #17812584] • Boot storage: 16 MB SPI flash + microSD for updates [Elektroda, piotr_go, post #17812584] • Bill of materials: ≈ PLN 200 plus < $2 CC2541 radio module [Elektroda, piotr_go, post #17813694] • Dev-tool size: Tang Dynasty IDE 150 MB (≈ 97 % smaller than 6 GB Vivado) [Elektroda, piotr_go, #17818230; Xilinx, 2023]
Which retro systems already run on the prototype?
Stable cores include NES and Amiga 600; C64 is planned next. Test cores for other 8-bit machines also boot [Elektroda, piotr_go, post #17812584]
How fast is the Amiga core and does it support AGA?
Current build matches Amiga 600 speed; designer expects 68030 at ~40 MHz with AGA once optimized [Elektroda, piotr_go, post #17814747]
What does the hardware cost and which parts are scarce?
PCB + stencil costs ≈ PLN 200; CC2541 radio module is under $2; BGA version of the FPGA was <$10, but the QFN device used here is hard to find and may run < $5 in China [Elektroda, piotr_go, #17813694; #17818046].
Why use a Chinese Anlogic FPGA instead of a Xilinx Spartan?
It combines SDRAM on-die, fits a small QFN package (no BGA), and lowers cost/size simultaneously [Elektroda, piotr_go, post #17817424]
Is documentation and development software available?
Datasheets exist only in Chinese. The free Tang Dynasty IDE is a 150 MB download—much lighter than mainstream FPGA suites [Elektroda, piotr_go, #17814291; #17818230].
Will HDMI or DisplayPort output be offered?
Unlikely. HDMI licence fees are high and negate profit; DisplayPort is royalty-free but needs higher bit-rates than the small FPGA tolerates [Elektroda, piotr_go, #17813493; #17814291].
Can I connect a wired USB or PS/2 keyboard?
Yes, on the newer carrier board with four USB host ports; firmware support is in progress [Elektroda, piotr_go, #17847680; #18016142].
Is the board for sale, and what about a C64 version price?
No commercial release is planned due to licensing costs and Polish bureaucracy (VAT, ZUS). Therefore no fixed price for the C64 build exists [Elektroda, piotr_go, #17813493; #18306973].
Which wireless modules does the joystick use?
New pads and joysticks carry reprogrammed CC2541 modules (~$2); earlier prototypes used nRF24L01+ plus a microcontroller [Elektroda, piotr_go, post #17814291]
How do I update FPGA cores and ROMs from microSD?
  1. Copy the .bin core and game ROMs to the microSD card.
  2. Insert the card; the Cortex-M0 bootloader detects new files and flashes the 16 MB SPI memory.
  3. Reboot; the selected core auto-loads [Elektroda, piotr_go, post #17812584]
What current limitations or bugs should I expect?
Amiga core still shows sprite glitches; large 3-D consoles cannot fit; HDMI support is intentionally omitted due to cost [Elektroda, piotr_go, #17812584; #17813493].
Could the design drive an LCD instead of HDMI?
Yes. The creator already attached a parallel-RGB LCD; implementing 4-lane MIPI-DSI would be harder but feasible with additional logic [Elektroda, piotr_go, post #18306798]
