Audi A4 B6 2002 1.9TDI Cruise Control Assembly: Delphi 150E Diagnostic Tester Coding Queries
dzigi1910 13377 4
  • #1 17162719
    dzigi1910
    !!!! Hello everyone, everyone !!!!
    I am writing about my car, namely it is as in the topic Audi A4 B6 2002. 1.9TDI 130Km engine (AWX)
    last Weekend I wanted to install the Cruise Control, I read a lot of guides and instructions, I decided to start the assembly
    however, the world would be too beautiful and the car too simple so that there would be no problems. So I installed the steering wheel module with the ending `` N '' that supports the cruise control, and added the cruise control lever. After this operation, after turning the key, my meter went crazy it didn't scare me to the point of coding with a diagnostic tester called `` Delphi 150E ''. Here I have a problem:
    1. Will the diagnostic tester `` Delphi 150E '' do coding / Adaptations of the ABS and the Steering Sensor and activating the Cruise Control
    2.Is there anything else I have to do so that I can enjoy the cruise control and the lack of errors in the ECU, maybe I missed something or did not do it?
    The displayed errors are:
    * ABS
    * ESP
    * Invalid ECU number
    * Yaw sensor error
    I am asking for help, if I can do something with this tester, I will be grateful if someone wise gives an instruction or tells me something.
    write here I know that the topic has been raised many times, but here it is more about coding and adapting this diagnostic device.
  • #2 17365243
    dziadek1977
    vag com + cable from viakena do the trick. if you don't have or can't, give it back to specialists
  • #3 17367182
  • #4 17367196
    szymitsu21
    Help: 342
    Rate: 1289
    zrachwal84 wrote:
    It is not possible to code and adapt with a pseudo tester from China
    And you'd be surprised.
    A pro for one of the better universal ones ...
    Generally, if ds can't handle it, you can easily find someone to do it for you.
  • #5 17367203
