Samsung J7 2017 Dual Sim: LED Flashlight Intensity Control, Adjust Levels 1-5, Troubleshooting
vivawojtek 6249 4
  • Hidden flashlight intensity control on Samsung J7 2017
    #1 16738703
    vivawojtek
    Hello, I bought a Samsung J7 2017 Dual sim and I have such an adventure that I downloaded the notification bar from the top of the screen and switched on the flashlight and somehow grabbed the phone that popped my control from the intensity of the LEDs. I passed on 1, I'll add that on the scale it was from 1 to 5, I think so because the whole procedure lasted a fraction of a second and I closed this setting. The effect is that when I turn on the flashlight it is rubbish, but so weak that it does not fulfill its function.
    Has anyone already had such a situation and can help me?
  • #2 16738782
    yanes
    Help: 210
    Rate: 609
    Give it now for 5, or tap the word "flashlight" again
  • #3 16738793
    vivawojtek
    As I pressed the flashlight again, it simply turned on.
    As he holds it, nothing happens either.
  • #4 16738807
    gracjan55
    Level 36  
    Help: 315
    Rate: 242
    You need to get right in the above-mentioned inscription because there is no other way out.
  • #5 16738816
    vivawojtek
    Ok, I managed to ? Thanks
