Has Celma been sold and production is now located in China?
0ceanborn 36768 35
Has the Celma power tool brand been sold, and are new Celma tools now made in China?
According to the thread, the current Celma brand is associated with Z-Power Sp. z o. o., and users say the new tools sold as Celma are Chinese-made branded products rather than the old Polish production [#19613669] [#19616185] The consensus is that this is a case of putting a known name on cheap Asian hardware, with the company focusing on branding and marketing instead of actual production [#19616185] Several posters contrast that with older Celma tools from the 1970s, which they describe as solid, durable, and still working after decades of use [#19614347] [#19618704] The new Celma tools are described as much less professional and not in the same quality class as the old ones [#19616185]
  • Questioning Celma’s Chinese ownership and quality claims
    #1 19613656
    0ceanborn
    Help: 19
    Rate: 79
    Hi
    I have a question about the Celma brand. Is it true that it was sold to the Chinese and they produce it in China? I heard this from the seller as well as that they currently have poor quality. Maybe he lied because he wanted to sell something else, but I don`t know.
    If Celma was sold like this, I would be grateful for information about when it happened. I like some of this company`s power tools, so in that case I will hunt for used ones.
  • #2 19613669
    ay56
    Help: 192
    Rate: 487
    Hello, Z-Power Sp. z o. o
  • #4 19613732
    0ceanborn
    Help: 19
    Rate: 79
    Does anyone use Celma quite intensively? Is it quite durable, it won`t fall apart quickly like the "market" ones?
  • #5 19613736
    vorlog
    Level 40  
    Help: 527
    Rate: 2587
    I have a mixer of this "brand", apart from the sticker with the name Celma, the rest is a classic Chinese one, but it must be admitted that it mixed a ton of sand with cement and is still alive :P
    V
  • Old Celma drills seen as more durable than new branded ones
    #6 19614347
    Mobali
    Help: 1355
    Rate: 3925
    I use a few more, mainly a heavy slow speed drill. It has been working reliably for years and has done a lot of work. Well, it`s still an old, solid production from the 1970s. I doubt that today`s "Chinese" products branded as Celma will withstand even a few years of intensive and serious work.
  • #7 19614360
    krakarak
    Help: 681
    Rate: 1848
    I have the same experience as my friend Mobali - you can`t get there from the 1970s (unless someone really insists). The old drill drills like it did 50 years ago and still drills today.
  • Chinese-made Celma may still be durable enough
    #8 19614747
    0ceanborn
    Help: 19
    Rate: 79
    What I meant in this topic was not only whether Celma is Chinese - we already know that, but how it relates to quality.
    OK - Chinese - weak, falls apart quickly - this is the stereotype, although it doesn`t work that way. The Chinese can produce anything, both low-end products and good-quality equipment - it`s all a matter of ordering.
    It is quite likely that the Chinese Celma will not be as durable as those made in Poland, but if it can withstand a good few years of decent work without a major failure, that`s also good.
  • Brand dilution and low-end Chinese rebranding critique
    #9 19616185
    Mobali
    Help: 1355
    Rate: 3925
    0ceanborn wrote:
    OK - Chinese - weak, falls apart quickly - this is the stereotype, although it doesn`t work that way. The Chinese can produce anything, from low-end products to good-quality equipment - it`s all a matter of ordering.
    I also prefer to avoid stereotypes and I know perfectly well that the Chinese can easily make products of the highest quality. And he does them, but the principle applies here: "what you pay for, what you get." However, in this case, I assure you that this new "Celma" is definitely not professional and the best quality equipment from this "top shelf".
    It must be pointed out that this bad practice of spoiling brands is currently dominant in every field. And it applies not only to local Polish, but also to once solid, large European brands. The recipe is simple: "take a well-known brand and print a sticker to put on the cheapest Asian product." In this way, the company does not produce, and its activity is limited to practically costless (compared to the entire production cycle) branding and marketing. Works? Certainly yes, even brilliantly, generating very quick profits. No one is interested in the long-term effects of this damage in the form of reputation damage. Nobody cares about the emasculation of local industry or the slaughter of innovation. Not to mention the dependency of the economy or the piles of garbage. Today, only the bars that matter, growing here and now. And what`s after us? Even the flood ;-)
  • #10 19616204
    stanislaw1954
    Help: 2018
    Rate: 4686
    And who will buy more products if the old, good ones do not (won`t) spoil?
  • Cheap tools are fine for infrequent use
    #11 19616488
    kortyleski
    Help: 957
    Rate: 3860
    This is one side of the coin.
    The second one, as mentioned, is riding on the brand`s legend. The recipe is simple, buy the rights to the name, for example "junak". Download ten containers of the cheapest crap that looks like a motorcycle from China. Cover them or order them from your local dealer, already labeled with the name.
    A father will buy one for his son, or a grandfather will buy one for his grandson because he used to drive a speedster himself. And the fact that this new junk is a hundred times worse in quality than the old one, which wasn`t a revelation either? Price. If you can buy a new Moto from a showroom for an average salary?
    Some time ago, I happened to work in a showroom and service center of several brands where a Kingway or other gu o and the flagship Peugeot speedfight 2 WRC model were standing next to each other. Błgot 12 circles and Chinol below three. Guess what people bought? And later, what more was at our service center than was driven under the owner`s ass? But I tortured the Peugeot mentioned earlier, I literally tortured it for two years. And he was completely fine. The service (in the form of my hands) was only seen during operational service.
    Dear author, I apply certain rules when it comes to power tools.
    For example, a manual milling machine. It became necessary for one job, the next use may be in six months or maybe in a year.
    Here is the cheapest Chinol from the market. If it doesn`t fall apart right away, it won`t fall apart from lying down either.
    Second example. SDS. For one big job, insulating a cottage. Later, occasionally, a shelf or drilling for a cable. Castorama and their Performance Power brand. Of course, parameters such as the need, i.e. a strong impact, etc. are much more attractive in terms of price than a branded tool with these parameters, and when I break the tool during the warranty period, they usually replace it with a new one instead of repairing it.
    Third, tools that I use frequently and from which I require ease of use and precision. Angle grinder, screwdrivers, Dremel, jigsaw or others. Unfortunately, you have to look a little deeper into your wallet here. I just liked DeWalt, Makita and Metabo tools.
    Only... You can find the same brands in DIY stores. Don`t buy them there. I happen to have a nice store nearby that is a distributor of the above-mentioned brands. But there are also distributors on the Internet. You need to call your representative in Poland and find out where their distribution points are. Why so much trouble?
    From my backyard. Over a year ago I needed a new grinder. I bought it my way for about six hundred DeWalt. After discounts because it was more expensive in retail.
    Somehow, over a beer, my neighbor and I agreed that he, too, needed a grinder. I showed mine and recommended purchasing it.
    I told where I bought it and offered to help because I had a discount.
    During the next beer a week later, he laughed at me and said how foolish I was because he bought an identical one on sale at Casto for PLN 229. I brought mine and we compared it. They look very similar, the models are different. However, at work they are completely different tools. Switch operation, play, vibration. The boy got sad...
  • Questioning why durable products are no longer made
    #12 19617470
    Mobali
    Help: 1355
    Rate: 3925
    But there was a time when you bought solid products that lasted for years and did not fall apart in your hands. I bought it myself and I still have and use several such tools. Interestingly, this period of solid production happened to coincide with exceptional economic development in the West. So how? It used to be possible, but now it`s not possible?
  • #13 19617920
    gkwiatkowski
    CCTV and Stationary Alarms specialist
    Help: 650
    Rate: 1231
    Now it is also possible to produce good ones, but it is not profitable for producers.
  • #14 19618411
    0ceanborn
    Help: 19
    Rate: 79
    It depends on what you mean by good. For me, good ones, good enough, are those that will last for several years of intense work or 10-20 years of less intense work, while a commercially-owned Ciatronix that won`t keep the 2-year warranty until the end is not enough.
  • Modern lightweight drill preferred over old heavy model
    #15 19618562
    vorlog
    Level 40  
    Help: 527
    Rate: 2587
    There is another side of the coin.
    I wonder how long my colleagues can work with such an old, solid, uncomfortable and heavy single-speed drill.
    and how long should it be a relatively modern one, although perhaps not top-of-the-line, but light, multi-functional, and for a pittance?
    And I know what I`m asking because I have both - the first one is lying forgotten somewhere in the corner, the second one has been used quite frequently, although at home, for several years...
    V
  • Celma tools prove durable in heavy home use
    #16 19618704
    anaba255
    Help: 95
    Rate: 263
    I have a Celmy two-speed drill, a dozen or so years old, apparently the last one made in Poland, used at home, but quite intensively. Drilling, often in 10 mm steel, in a chuck, as a bench drill. It works as a mixer, I insulated the whole house with it, made several screeds, and did some home renovations. Recently I replaced the rotor and caliper, surprisingly the bearings still have no play.
    In addition, I have two Celma grinders, one probably 1000W (I don`t know exactly, because the sticker has already worn off) with speed regulation, the other 750W. The first one was still repaired under warranty, I think some thermal protection went wrong. So far they have worked flawlessly. Even though I use them at home, I do a lot of welding, for myself and some odd jobs, the tools are still working. One has a cutting disc, the other a grinding disc.
    The last Celma is a hammer drill, I`ve had it for 2 years, it didn`t work much, I rarely use it for forging, the largest drill bit I used was 20 mm, when I was drilling through the ceiling, previously I used a smaller one. Before I bought it, I read opinions, people complained about a weak stroke, I think 2.3J, for me it is enough.
    For me, Celma is OK for my needs, both in terms of quality and price. The only thing I can accuse these tools (apart from the hammer drill) is poor ergonomics. Grinders do not fit well in the hand.
    As for tools made in China, I have a Hilti screwdriver and an impact wrench, Made in China, and solid tools. When I asked the local service center about a possible repair, I was told that the Hilti does not break down, only the batteries wear out. Not everything from China is of poor quality, I have used a lot of power tools and branded ones, although bought in supermarkets and typically supermarket products, have had different experiences.
  • Celma tools were affordable and versatile despite weight
    #17 19619223
    Mobali
    Help: 1355
    Rate: 3925
    vorlog wrote:
    how long can my colleagues work with an old, solid, uncomfortable and heavy, single-speed drill and how long can they work with a relatively modern, although not top-of-the-line, light, multi-functional drill?
    You`re right, today`s tools are certainly different, probably more ergonomic, and above all - there is a huge selection. However, your comparison is not entirely fair. Well, how can you combine a multifunctional tool with a specialized one? And as for multitasking... I had almost the entire Celma EMA Combi set, so for those years I had no complaints at all. Nowadays, it would be difficult to find a multi-function drill, grinders for various jobs and various, sometimes very specialized, attachments in one box. Almost anything could be done with it.
    Comparing prices then and now does not make much sense. No matter what kind of drill you bought in the 1970s, it would probably be more expensive than it is now. However, this is mainly due to the purchasing power of one average salary in that period. But compared to the equipment offered in the West, Celma was many times cheaper. It could also compete on price even with power tools from the former Eastern Bloc. No matter what you do, it used to be useful equipment, of decent quality and affordable for the average person. Today? The cheapest one is of terrible quality and low durability. And you still have to pay a lot for a good or even decent one.
  • #18 19619230
    vorlog
    Level 40  
    Help: 527
    Rate: 2587
    Not what I meant.
    I meant long-term use of the tool, e.g. drilling hundreds of φ8 holes in, for example, 45x45 metallurgical angles, vertically.
    The heavy Celma made you sweat so much that the skin came off your toes...
    The modern ones are simply lighter, fit better in the hand, etc.
    V
  • #19 19621702
    0ceanborn
    Help: 19
    Rate: 79
    vorlog wrote:
    e.g. drilling hundreds of φ8 holes in, say, 45x45 metallurgical angles, vertically.
    What does vertical mean?
  • #20 19621785
    vorlog
    Level 40  
    Help: 527
    Rate: 2587
    Material in a vertical position, i.e. drill horizontally - e.g. holes in fence posts, garage structures/skeletons...
    V
  • #23 19778723
    ay56
    Help: 192
    Rate: 487
    you can`t buy new ones. because they do not produce e.g :( gear)
  • #24 19778773
    mczapski
    Level 40  
    Help: 468
    Rate: 1661
    I was surprised when in a DIY store I found products with the CELMA marking on the shelf (new, of course). I expect that according to decent rules there would be spare parts for them. But nowadays, counting on decency is simple naivety.
  • #25 19779560
    ay56
    Help: 192
    Rate: 487
    Unless you look for parts on AllieExpres.
    or to the guy from the link, you need to call and make an agreement, I bought parts in good condition and I am satisfied. just to Celma.
  • Most consumer electronics are now made in China
    #26 20158891
    wolff7
    Yesterday I looked through all the power tools at Leroy Merlin, OBI and Casto and found only one hammer drill made in Germany and two screwdrivers made in Malaysia. The rest are marked Made in China or have no country of production entered, so they are also made in China.
    Additionally, I looked at my iPhone 13PRO - Made in China
    My newest MacBook for PLN 13,000 - Made in China.
    And in addition, Elon Musk is intensively moving Tesla's production to China and 10% (i.e. the highest percentage) is sold in China
    I guess we overslept that in the meantime the world has changed and no production (except military) in Europe and the USA is possible anymore, much less the return of this production :)
  • Branded goods made in China can still be premium
    #27 20158986
    Tomek.K.
    Help: 255
    Rate: 537
    And in addition, Elon Musk is intensively moving Tesla`s production to China and 10% (i.e. the highest percentage) is sold in China
    A supervised production process with know-how or an own factory in China is one thing, and production outsourcing is another thing, which the client has no influence on because he has no control there. Therefore, branded goods produced in China will be more expensive, because the owner usually cares about quality and has cheap labor, although currently it is not that cheap in China.
  • Old Celma drill still excels at mixing mortar
    #28 20159015
    kris8888
    Help: 537
    Rate: 1935
    That`s why I use it occasionally only for mixing adhesive mortar, concrete, etc. It has worked perfectly in this role for years, it has the right speed and torque. There`s no chance of burning it.
    I do everything else with a handy Bosch which I wouldn`t mind using to mix concrete. Anyway, I don`t know if he could handle it.
  • China’s factory supervision and engineering capability praised
    #29 20159600
    wolff7
    It so happens that, to be honest, before the pandemic, I had the pleasure of visiting China in person and visiting several factories, so I also saw what the supervision of representatives of international brands in Chinese factories looks like. I must admit that such supervision is a great fiction, because Chinese engineers have 10 times more knowledge than our European and Chinese engineers, they have to supervise such supervisors themselves so as not to harm themselves. For example, to prevent the tie from getting caught in the rotor winding machine. This is what the supervision of companies from Germany, Japan, Great Britain and Poland looks like, producing their machines in the same factory only in two or three halls next to each other, and sometimes one production line of a global brand is located directly next to the production line of another global brand.
    Producing power tools is nothing.
    Almost all global smartphone brands are produced in China in only 4 factories, and 40% of the engineering comes from Chinese engineers. In a few years, it will surely turn out that Chinese technical thought is 70%.
    I was surprised how modern machine tools the Chinese have and how efficient their organization and work pace are compared to the modern factories I visited in Germany. In a few years, Europe will be a technologically backward place vs. China
    Our entire Western world exported all technical thought and production to China, and the reason for this was only one thing - the greed for greater profit through lower costs.
  • Chinese technology now overtaking Europe
    #30 20159911
    Tomek.K.
    Help: 255
    Rate: 537
    I agree that the Chinese have long overtaken us technologically, because it is not only the world`s factory, but also their projects. Maybe 30 years ago it was a backward economy, but for about 20 years they have been overtaking many European countries, and now they have overtaken them, maybe in some aspects Germany and the USA still have something to say, but it is a matter of time, because Chinese cars are not sold in Europe, only because the industry lobby is blocking them by not granting approvals, but they are already appearing and the Chinese are simply buying Western companies and doing their own thing.
The discussion centers around the Celma brand, questioning whether it has been sold to a Chinese company and if its production has moved to China, leading to concerns about quality. Participants share experiences with Celma tools, noting that older models from the 1970s are durable, while newer products, likely manufactured in China, are perceived as lower quality. Some users argue that the stereotype of Chinese products being inferior is not universally true, emphasizing that quality depends on production standards and pricing. The conversation also touches on the broader trend of established brands compromising quality by outsourcing production to cheaper markets, resulting in a decline in the reputation of once-reliable brands like Celma. Users express a preference for older, solidly built tools and discuss the challenges of finding spare parts for Celma products.
TL;DR: 97 % of power tools on Polish DIY shelves now read “Made in China” [Elektroda, wolff7, post #20158891] “What you pay for is what you get” [Elektroda, Mobali, post #19616185] Quality hinges on the purchase channel and model line. Why it matters: Shoppers can still find durable gear, but need to tell vintage Polish Celma from the badge-engineered imports.
• Current brand owner: Z-Power Sp. z o.o. [Elektroda, ay56, post #19613669] • Manufacturing: Outsourced to Chinese plants since early-2010s; retail units carry PRC marking [Elektroda, vorlog, #19613736; mczapski, #19778773] • Vintage Celma lifespan: 40–50 years and counting [Elektroda, krakarak, post #19614360] • Example new Celma hammer drill impact energy: 2.3 J [Elektroda, anaba255, post #19618704] • Spare parts availability: Mostly second-hand offers; no new gears produced [Elektroda, DiZMar, post #19778718]
Was Celma really sold, and to whom?
Yes. After the original Polish factory folded, the Celma trademark was acquired by Z-Power Sp. z o.o., which now licenses the name [Elektroda, ay56, post #19613669]
Where are present-day Celma tools manufactured?
Forum users report only PRC-marked stock on shop shelves, indicating full production in China [Elektroda, vorlog, #19613736; mczapski, #19778773].
Can I still buy Polish-made Celma tools?
Only second-hand. Production moved abroad; shops carry Chinese batches exclusively [Elektroda, 0ceanborn, post #19614747] Online classifieds and flea markets hold the remaining Polish units.
Do new Celma models come with spare parts and service?
Official parts channels are sparse; one user found only a used gear and drill online [Elektroda, DiZMar, post #19778718] For critical spares, buyers rely on dismantlers or generic Chinese components.
What impact energy does the current Celma hammer drill deliver?
The CHN-made ADP03 hammer drill provides a 2.3 J single-blow energy, adequate for home masonry [Elektroda, anaba255, post #19618704]
How long can I expect a new Celma mixer or drill to last?
One budget Celma mixer has stirred over one tonne of sand–cement and still works [Elektroda, vorlog, post #19613736] Still, absence of parts makes any major failure terminal; plan for 3–5 years of mid-intensity work.
Are Chinese-made tools always low quality?
No. “The Chinese can produce anything… it’s all a matter of ordering” [Elektroda, 0ceanborn, post #19614747] Brand owners that specify tight tolerances and audit factories sell durable gear, but bargain-line batches may skip those steps.
Why can the same premium brand feel different in a DIY chain?
Manufacturers create economy variants for retail chains. A neighbour’s PLN 229 DeWalt grinder showed more play and vibration than the distributor model costing PLN 600 [Elektroda, kortyleski, post #19616488]
Is it safe to mix mortar with a drill?
Occasional bucket mixes work, yet prolonged load can overheat lightweight drills. Use a low-rpm mixer for batches over 10 kg or viscous concrete [Elektroda, vorlog, post #20168365]
How can I verify a Celma tool’s origin before buying?
  1. Inspect the rating plate for “Made in…”.
  2. Check barcode: 590 = Poland, 690–699 = China.
  3. Weigh it—vintage drills exceed 5 kg; Chinese versions sit around 2 kg. If any step fails, assume import stock.
Where do users source replacement gears or rotors?
Most scour Polish classifieds, Aliexpress, or dismantle donor units [Elektroda, ay56, post #19779560] Edge case: No factory gears exist for some models, so repairs become impossible.
Why did so many brands shift production to China?
Lower labour cost raised profit margins, and the tool sector adopted a badge-engineering model—“print a sticker on the cheapest Asian product” [Elektroda, Mobali, post #19616185] The method delivers quick gains but erodes brand equity.
Is supervised Chinese production comparable to Western plants?
Visitors report state-of-the-art CNC lines and fast workflows in Chinese factories, sometimes outclassing German sites [Elektroda, wolff7, post #20159600] Quality hinges on the buyer’s specification, not the geography.
