How to strengthen the wifi signal on the ground floor next to the router on the
Lesyeux 8733 13
How can I improve the weak Wi‑Fi connection for an MXQ PRO 4K box on the ground floor when I cannot move the router or run a cable?
Do not rely on a Wi‑Fi repeater for streaming to the MXQ PRO 4K; it slows the link and is very sensitive to interference, so first check the signal with a WiFi analyzer at the TV place and any possible repeater location [#16995276][#16995331][#16995818] If you need the cheapest reliable fix, users recommended PLC/powerline adapters or pulling an RJ‑45 cable from the router to the TV/box instead of a repeater [#16995276][#16995393] One user reported that a wall-plug transmitter fixed YouTube and Netflix on the TV without problems, and another suggested the D‑Link DHP-W311AV as a powerline option [#16995444][#16995617] If you still want a repeater, one low-cost suggestion was a TP-Link TL-WR740N V4 with Gargoyle, but only after measuring the Wi‑Fi conditions first [#16995818]
  • #1 16995235
    Lesyeux
    Forgive me I am a layman and I do not know if the description is enough for you, so I am asking for a large dose of forgiveness. On the floor at the parents' stand is the TP-LINK TD-W8950N router, a stationary computer is connected to it. On the ground floor for Sharp tv I bought a box MXQ PRO 4K to tune the TV a little. Unfortunately, only the browser, facebook works, but in general it often loses connection in wi-fi and there is no option to use e.g. YouTube etc. I conclude that the signal in the place where the TV stands is too weak. I will add that I cannot move the router upstairs to another place, just like a TV on the ground floor. The diagonal distance from the router and box is not large, maybe 10 meters, but a ceiling and two walls. I would like to strengthen the signal and I wonder how to do it at a low cost so that the box fulfills its role and that the cash register on it is not thrown down the drain. I am asking for advice - not in a complicated language ;) , and so you know for the total rookie. I was thinking of buying an amplifier for the TP-LINK TL-WA854RE socket.
    I will add that wifi (Orange- via tel. Landline) is generally miserable and his parents have the highest power on the connection up to 10 mega, although it probably never is there.
  • #2 16995276
    jimasek
    Help: 3783
    Rate: 2681
    Take measurements and tests here - https://www.elektroda.pl/rtvforum/topic3158772.html
    Repeater is not the best solution for streaming data that you probably want to use when buying such a device. You'd better read about PLC transmitters or think about how to "pull" the cabling here.
  • #3 16995311
    Lesyeux
    I understand. So measuring when I'm at my parents' and then I throw in what came out. And why the repeater is not the best solution - too weak? I looked at the transmitters and I am starting to like it less and less because I did not plan such costs :( .
  • #4 16995331
    jimasek
    Help: 3783
    Rate: 2681
    Repeater slows down the link and is very sensitive to interference and must have something to strengthen. We will not leave without measurements.
  • #5 16995367
    Lesyeux
    I understand, thank you very much for your reply. I was reminded that I have a Tp-LInka usb adapter TL-WN822N, which is dusted somewhere in a box on the shelf. Is it a small system-network card, can you somehow use the system described above? So the next step is measurements.
    jimasek
    Help: 3783
    Rate: 2681
    Lesyeux wrote:
    I remembered that I have a Tp-LInka usb adapter TL-WN822N, which is dusted somewhere in a box on the shelf.
    I don't know if your MXQ PRO 4K supports USB network cards with an "no" indication of course.
  • #7 16995393
    LucekB
    Help: 143
    Rate: 137
    It's best to let go of the UTP LAN cable from the router under the TV,
    If there is no such option, use PLC adapters.
  • #8 16995437
    Lesyeux
    Probably not
  • #10 16995617
    makosuu
    Help: 369
    Rate: 370
    Lesyeux wrote:
    I looked at the transmitters and I am starting to like it less and less because I did not plan such costs.
    On Alegro, enter D-Link DHP-W311AV. I think these 100 + shipping is not a tragedy? Even WiFi will strengthen immediately. I have and recommend it very much.
  • #11 16995658
  • #12 16995727
    Lesyeux
    Pong.Chu wrote:
    You can always pull the RJ-45 cable from the router to the TV - it will only be impractical or pretty. Well, but it can be cheaper. I do not know why people complain about the price of wifi equipment, a few years ago any router cost a fortune and today you can have for about 50-60 PLN or the price of an average dinner for 2 people.
    Well, and instead of focusing on the merits, you will now judge me that I pay attention to the budget - so I pay attention to this is probably not a crime yet ?. I have not written anywhere that 50 or 60 PLN is too much, but the mentioned transmitters are nicely over 100 and it makes me less happy.
    I also wrote that I have no way of pulling the cable from the router to the TV - so why such writing, why it serves?
    Moderated By jimasek:
    I would like more culture for those who want to help.
    3.1.17. Do not send very basic questions that you can find answers in the user manual or publicly available sources. Don't take the attitude that I deserve. Keep the level of questions and discussions. Thank you.
    makosuu
    Help: 369
    Rate: 370
    You can buy a repeater but first you need to make some measurements. Download the wifi analyzer to your phone and take tests in the place of the TV set and where the repeater would stand. And as a repeater I recommend TP-Link TL-WR740N V4 with Gargoyle loaded. The cost is about PLN 20, because I can see that it should be cheap.
  • #14 16995845
    Lesyeux
    I'm sorry - what did I write? Well, forgive me, but I was offended by these money trips. He does not present the attitude that I deserve - I am looking for help from experts and I also expected help in not having to overburden my budget, not the assessments that I intend to save.
    Thank you for answering the topic, and I think the rest is completely unnecessary and please close the topic because I see that there is no equal treatment here - so it's a waste of nerves for each party. Best regards and thank you. And once again, I don't treat anyone in advance, I'm sorry that I lowered the level of discussion with my lack of knowledge, but if I had it I wouldn't need help.
    So, I close the topic, ladies, according to your will.
    We try to help and solve your problem by dedicating your free time and you have some grievances.
The discussion revolves around improving the Wi-Fi signal for a Sharp TV connected to an MXQ PRO 4K box, located on the ground floor, while the TP-LINK TD-W8950N router is situated upstairs. The user experiences frequent disconnections and weak signal strength, particularly for streaming services like YouTube. Suggestions include measuring the Wi-Fi signal strength, avoiding repeaters due to their potential to slow down connections, and considering Powerline Communication (PLC) adapters as a more reliable solution. Recommendations for specific devices include the D-Link DHP-W311AV and TP-Link TL-WR740N V4 with Gargoyle firmware. The user expresses budget concerns and the inability to run Ethernet cables directly to the TV.
TL;DR: Ground floor MXQ box is ~10 m from the router through a ceiling and two walls; "Repeater slows down the link." [Elektroda, jimasek, post #16995331]
Why it matters: This FAQ helps beginners decide between cable, powerline (PLC), or repeater to fix streaming dropouts in multi‑floor homes.
What’s the fastest reliable fix to stop TV buffering?
Run a UTP Ethernet cable from the router to the TV. If cabling is impossible, use a PLC/powerline kit to carry the link over electrical wiring. This gives a stable connection for YouTube or Netflix compared with weak Wi‑Fi across floors. [Elektroda, LucekB, post #16995393]
Why does the MXQ PRO 4K lose Wi‑Fi next to the downstairs TV?
The router is on the upper floor. The path includes a ceiling and two walls over about 10 meters. These barriers attenuate 2.4 GHz signals and cause dropouts at the TV location. Streaming apps fail first because they need sustained throughput and low jitter. [Elektroda, Lesyeux, post #16995235]
Are wall‑plug repeaters good for YouTube and Netflix?
Not for this layout. Repeaters slow the link and are sensitive to interference. That hurts continuous streaming. As the expert said, "Repeater slows down the link." Choose Ethernet or PLC for stable playback between floors. [Elektroda, jimasek, post #16995331]
How do I test my signal before buying anything?
Install a Wi‑Fi analyzer on your phone. 1. Measure at the TV spot. 2. Measure where a repeater could sit mid‑path. 3. Compare signal levels and stability, then decide on repeater vs. PLC. Share screenshots if asking for help. [Elektroda, makosuu, post #16995818]
Will a TP‑LINK TL‑WA854RE (repeater) fix my problem?
It may extend coverage but is a poor choice for streaming across floors. Use a repeater only after measurements show a strong feed at the repeater location and no PLC option. "Repeater is not the best solution for streaming data." [Elektroda, jimasek, post #16995276]
Will powerline (PLC) also improve Wi‑Fi downstairs?
Yes if you choose a PLC kit with built‑in Wi‑Fi. One user reports a wall‑plug TP‑Link powerline fixed YouTube and Netflix when Wi‑Fi was at the edge of range. PLC also gives an Ethernet port for the TV or box. [Elektroda, 3029369, post #16995444]
Can the MXQ PRO 4K use my TL‑WN822N USB Wi‑Fi adapter?
Unlikely. The box may not support external USB network cards. Before trying, confirm driver support for that chipset on your MXQ firmware. The forum advice here is a clear "no" for that model. [Elektroda, jimasek, post #16995380]
What’s the cheapest workable option to try first?
If your measurements look promising, a used TL‑WR740N V4 with Gargoyle can act as a repeater for about PLN 20. Place it where the upstairs signal is still solid. Expect lower throughput than PLC, but it’s low‑cost. [Elektroda, makosuu, post #16995818]
What measurements should I post when asking for help?
Provide Wi‑Fi analyzer screenshots from the TV location and the potential repeater spot. Include SSID, channel, RSSI, and stability over time. The helper requested following the forum’s measurement guide before choosing hardware. [Elektroda, jimasek, post #16995276]
I can’t move the router or TV—what’s the next best step?
Use PLC adapters to bridge floors without running cable. Plug one near the router, the other near the TV. Then connect the TV or MXQ via Ethernet or the PLC’s Wi‑Fi if available. [Elektroda, LucekB, post #16995393]
Is a long Ethernet cable ugly but worth it?
It can be the cheapest and most reliable fix, though impractical aesthetically. One participant notes cable may be cheaper than buying new Wi‑Fi gear, even if routing is awkward. [Elektroda, 3029369, post #16995658]
My plan is “up to 10 Mb/s.” Is that part of the problem?
Yes, low access speed limits stream quality and tolerance for retransmissions. Combined with weak Wi‑Fi, this causes buffering. Stabilize the local link first using Ethernet or PLC, then evaluate actual ISP speed at the router. [Elektroda, Lesyeux, post #16995235]
