Repair 220-240V LED Bulb: Burnt Component Diagnosis with Universal Meter & Soldering Tools
mitlex 4734 12
How can I find which component burned out in a 220–240V LED bulb using a multimeter and basic soldering tools?
Start by checking the eight components on the board with your meter; if they are all okay, the fault is usually in one or more LEDs, and less often in the electrolytic capacitor, rectifier bridge, SMD fuse, or SMD resistors [#16744824] [#16745046] [#16746278] [#16746321] The bridge can be checked with an ohmmeter like other diodes [#16745288] In this type of bulb it is not a real converter, but a capacitive dropper for 50 Hz, so the 400V CBB22 capacitor is part of the current-limiting circuit [#16746278] If the LEDs are visibly or electrically good and the bridge also tests good, inspect the SMD fuse and the nearby SMD resistors, including the one under the capacitor [#16746278] [#16746321]
  • Request for help identifying the burnt LED bulb component
    #1 16744810
    mitlex
    Rate: 39
    Hello, I have a question, the led bulb burned out recently, and since it's a led, it can also be repaired. I'm sending photos of the center. Hint what could have burned, I have a universal meter at my disposal, of course a soldering iron and a suction gun ;)
    Repair 220-240V LED Bulb: Burnt Component Diagnosis with Universal Meter & Soldering Tools Repair 220-240V LED Bulb: Burnt Component Diagnosis with Universal Meter & Soldering Tools Repair 220-240V LED Bulb: Burnt Component Diagnosis with Universal Meter & Soldering Tools
  • #2 16744824
    Piotr2608
    Help: 851
    Rate: 4488
    You have 8 elements crosswise on the board, just measure them with the meter.
    If they are in working order, look for damage on the LED module.
    ZimTech Piotr Zimny
  • #3 16744899
    mitlex
    Rate: 39
    Okay, I only know how exactly I can measure them, I'm really green in measuring the elements what values should they have and with what range to measure them
  • #4 16744950
    tomek5333
    Help: 13
    Rate: 57
    Enter in Google how to measure the resistor capacitor, read the meter manual because these are really trivial questions
  • #5 16745046
    398216 Usunięty
    Help: 3925
    Rate: 9453
    In 99% of cases, one (or several) of the LEDs fails. The remaining 1% is an electrolytic capacitor and a rectifier bridge. Nothing more.
  • #6 16745131
    mitlex
    Rate: 39
    The leds are working, how can I measure this bridge because the resistors are working
  • #7 16745288
    398216 Usunięty
    Help: 3925
    Rate: 9453
    mitlex wrote:
    how can i measure this bridge
    Ohmmeter. As usual, LEDs.
  • #8 16746045
    mitlex
    Rate: 39
    Okay, the bridge is working, I have a question because the only thing I do not know is how to measure this capacitor: cbb22 400v how to check if it is functional
  • #9 16746278
    Krzysztof Kamienski
    Help: 2033
    Rate: 5168
    It is not even a converter, but an adaptation of the LED current by capacitive impedance at 50 Hz. The electrolytic capacitor appears bulged and therefore compact. Check this SMD fuse first.
  • #10 16746319
    marian1981.02
    Unitra equipment specialist
    Help: 989
    Rate: 757
    Krzysztof Kamienski wrote:
    The electrolytic capacitor looks bulged
    I wonder from which side? It is only crookedly soldered, but I am not saying that it is working.
  • #11 16746321
    mitlex
    Rate: 39
    I suspect SMD resistors, one under the capacitor does not show value. Not even in the diode chart. The electrolytic capacitor is operational
  • #12 16746407
    cirrostrato
    Help: 286
    Rate: 959
    Once again I will give you a hint: a good source of obtaining damaged LEDs are containers for these spikes in supermarkets, of course you have to rummage 'unofficially' because protection chases seekers away, I recently pulled out three LEDs (E27 thread) each with one burned out of 48 LEDs (you can see visually burnt, all connected in series), shorted the defective and have been illuminating the driveway to the garage for a month. I will see how with the durability of such "repaired" ones, the biggest problem is cooling and the LEDs now work in a very cool (and winter is coming) environment.
  • #13 16746451
    mitlex
    Rate: 39
    This is how I have repaired the LEDs more than once, but this time SMD resistors were sowing
The discussion revolves around diagnosing and repairing a burnt 220-240V LED bulb. The user seeks advice on identifying burnt components using a universal meter and soldering tools. Responses suggest measuring the eight elements on the circuit board, focusing on the LED module, and checking the rectifier bridge and capacitors. Common failures include LEDs, electrolytic capacitors, and SMD resistors. Users share tips on measuring components and suggest sourcing replacement LEDs from discarded items. The importance of checking for bulged capacitors and SMD fuses is emphasized, along with practical repair experiences.
TL;DR: Most 220–240 V LED bulb failures trace to LEDs themselves (99%); “In 99% of cases, one (or several) of the LEDs fails.” Use a meter to check LEDs, bridge, SMD fuse, and electrolytic. [Elektroda, 398216 Usunięty, post #16745046]
Why it matters:** This FAQ helps DIYers diagnose and repair mains LED bulbs safely with a basic multimeter and soldering tools.
What usually burns in a 220–240 V LED bulb?
LED chips are the dominant failure point. One expert notes, “In 99% of cases, one (or several) of the LEDs fails,” with the remaining 1% split between the electrolytic capacitor and the rectifier bridge. [Elektroda, 398216 Usunięty, post #16745046]
How do I test the rectifier bridge with a universal meter?
Use diode-test or ohmmeter mode. Check each junction like testing diodes: forward conduction one way, block the other. Confirm no shorts between AC and DC pins. If any leg reads both ways or always zero, replace the bridge. 3-step: 1. Isolate board power. 2. Probe all four legs in pairs. 3. Compare readings symmetrically. [Elektroda, 398216 Usunięty, post #16745288]
What is a capacitive dropper LED driver?
It limits LED current using the reactance of a film capacitor (e.g., CBB22) at 50 Hz instead of a switching converter. These bulbs often include an SMD fuse and an electrolytic smoother after rectification. Start checks at the SMD fuse. [Elektroda, Krzysztof Kamienski, post #16746278]
How likely is the electrolytic capacitor to be the culprit?
It is an uncommon cause compared with LED failure. The reported split is 99% LEDs versus 1% for the electrolytic and rectifier bridge combined, so prioritize LED testing first. [Elektroda, 398216 Usunięty, post #16745046]
My electrolytic looks bulged—should I replace it?
Not always. A crookedly soldered capacitor can mimic bulging. Inspect from multiple angles, then measure or swap only if you confirm a fault, rather than judging by tilt alone. [Elektroda, marian1981.02, post #16746319]
Which protective part should I check first on a dead bulb?
Check the SMD fuse before deeper troubleshooting. In capacitive-dropper designs, a blown SMD fuse is a straightforward open-circuit failure that stops everything. [Elektroda, Krzysztof Kamienski, post #16746278]
The LEDs test fine—what should I probe next?
Move upstream. Verify the SMD fuse continuity, then test the rectifier bridge, and finally the electrolytic smoother. This sequence matches typical failures in capacitive-dropper bulbs. [Elektroda, Krzysztof Kamienski, post #16746278]
Can I bypass a single dead LED to bring the bulb back?
Yes, in series strings a single short can restore operation. One user shorted one failed LED in a 48-LED chain and it worked for a month. Use this as a diagnostic or low-stakes fix. [Elektroda, cirrostrato, post #16746407]
An SMD resistor near the capacitor reads open—what does that indicate?
It suggests a failed current-limiter or sense resistor. This open prevents current flow even when LEDs look fine. Replace the open SMD resistor after confirming identification and value. [Elektroda, mitlex, post #16746321]
How do I measure parts if I’m new to multimeters?
Start with your meter’s manual and basic guides for measuring resistors and capacitors. Knowing the correct ranges and modes prevents misreads and damage during diagnosis. [Elektroda, tomek5333, post #16744950]
How should I verify a film capacitor CBB22 400 V with basic tools?
With only a simple meter, in-circuit capacitance checks are unreliable in dropper designs. Focus on upstream checks: SMD fuse continuity, then bridge and electrolytic evaluation, before suspecting the film capacitor. [Elektroda, Krzysztof Kamienski, post #16746278]
If LEDs and bridge test okay, what else can fail?
Look for an open SMD fuse or resistors in the dropper network. These parts can silently open and mimic LED failure while all diodes test fine. [Elektroda, Krzysztof Kamienski, post #16746278]
Is there a quick way to confirm LED string health?
Inspect for visibly burnt LED chips and test continuity across each LED. A single open device in a series chain breaks the whole lamp. Replace or temporarily short the bad LED to confirm. [Elektroda, 398216 Usunięty, post #16745046]
Does a bridge rectifier ever fail partially?
Yes. A single shorted or leaky diode leg inside the bridge can cause flicker or no light. Your diode-test should show asymmetric readings; identical both-way readings indicate failure. [Elektroda, 398216 Usunięty, post #16745288]
Why does shorting one LED work in some repairs?
Series strings stop on a single open. Bridging the failed LED restores continuity, proving the rest of the circuit. “Shorted the defective and have been illuminating… for a month.” [Elektroda, cirrostrato, post #16746407]
Are skewed components a manufacturing defect or damage?
Often it’s just assembly misalignment. A skewed electrolytic can look swollen, but function fine. Confirm with electrical tests, not appearance alone. [Elektroda, marian1981.02, post #16746319]
