Damaged 16GB USB Flash Drive from Allegro: Recover Lost Photos & Videos, Deceptive Software?
Avatar123 2745 2
  • #1 16745145
    Avatar123
    I recently bought a pendrive from Allegro.
    Stupid, I didn't check if the memory was working so I immediately uploaded some photos.
    Pictures and videos do not open, and re-uploading to PC has no effect.
    If the memory was damaged from the very beginning, it is possible to recover the data, is it already after the birds?
    What if the pendrive is actually less than 16 gb GB and was just deceived soft?
  • #2 16745249
    wojter40
    Rate: 18
    Try to make a disk image if you find it, then try to install the ISO image and then open it. If the soft was bad, he probably wouldn't just swallow the files (unless it's a Chinese crap that overwrites and deletes data alternately)
    You can try to recover your data, but I don't know which free software would be the best. I used Ashampoo Undeleter.
  • #3 16745849
    pidar
    Help: 1569
    Rate: 3590
    Just reading from ChipGenius to verify suspicions of FAKE. :idea:
