8GB Flash Drive Write-Protected After Fast Formatting: Diskpart Detection Failures & Solutions
xnylbx 16098 19
How can I restore an 8 GB flash drive that became write-protected and is no longer detected after a fast format?
Check first whether the flash drive has a physical write-protect switch, because that can cause the same symptom [#16173317] If it is an Alcor-based stick, use AlcorMP with the correct flash files for the controller; one suggested route was the older AlcorMP v12.02.13.03 D3/eD3, or AlcorMP 12.12.14.eD3 if the matching FLASH BIN is present [#16177028][#16177278][#16177370] If the drive disappears on all computers and is not seen by ChipGenius or USBFlashInfo anymore, the controller may already be permanently damaged [#16173606]
  • #1 16173285
    xnylbx
    Hello, I have a problem with the 8gb flash drive, which stopped working after the last format (I don't know why I marked it with fast formatting). You can't reformat it, step on it or anything .. I've read a lot of posts, but none of the programs helped me.
    Most often it does not detect the flash drive or says that it is write-protected. Diskpart also failed.
    I'm attaching photos for help. Thank you : ) 8GB Flash Drive Write-Protected After Fast Formatting: Diskpart Detection Failures & Solutions 8GB Flash Drive Write-Protected After Fast Formatting: Diskpart Detection Failures & Solutions
  • #2 16173317
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    So, maybe you used a security switch. Watch it carefully.
  • #3 16173347
    pidar
    Help: 1569
    Rate: 3589
    Let's check the latest soft (modified) for this ALCOR -and:
    • AlcorMP v16.11.01 MD.zip (14.03 MB) You must be logged in to download this attachment.
  • #4 16173363
    xnylbx
    @mczapski pendrive doesn't have any switch.
    @pidar I downloaded this program today, but I do not know if I can use it well, because I do not have any flash drives in it.
    edit: but it popped up, I missed it, because I downloaded the latest version today, but not the modified one. What now? Ordinary start on left click?
  • #5 16173392
    pidar
    Help: 1569
    Rate: 3589
    xnylbx wrote:
    however, it popped up, I missed it because I downloaded the latest version today but not the modified one. What now? Ordinary right-click start?
    Yes.
  • #6 16173482
    xnylbx
    It popped out: 8GB Flash Drive Write-Protected After Fast Formatting: Diskpart Detection Failures & Solutions
  • #8 16173571
    xnylbx
    As that popped up, the pendrive disappeared completely and is undetectable by the system or the usbflashinfo program. Not even chipgenius detects it anymore :| Only when I connect to a new socket, it pops up that it has not been possible to install the software and the red light that was on, as it was always connected, goes out.
  • #9 16173606
    pidar
    Help: 1569
    Rate: 3589
    Check on other computers, the same symptoms will indicate that the controller is already permanently damaged. :|
    Pendrive can be dismantled?
  • #10 16173613
    xnylbx
    He writes on the laptop that the driver installation was successful, and the pendrive is not detected in my computer.
  • #11 16173717
    pidar
    Help: 1569
    Rate: 3589
    AND ChipGenius , Flash Drive Information Extractor shows information about him :?:
  • #12 16176149
    xnylbx
    I do not know what is happening but I connected to another laptop and the removable disk G popped up, normally only it is so transparent. 8GB Flash Drive Write-Protected After Fast Formatting: Diskpart Detection Failures & Solutions
  • #13 16176208
    pidar
    Help: 1569
    Rate: 3589
    xnylbx wrote:
    I do not know what is going on but I connected to another laptop and a removable disk G popped up, normally only it is so transparent
    I repeat the question:
    pidar wrote:
    And ChipGenius, Flash Drive Information Extractor shows you information about it :?:
  • #14 16176341
    xnylbx
    This pops up: 8GB Flash Drive Write-Protected After Fast Formatting: Diskpart Detection Failures & Solutions
  • #16 16177173
    xnylbx
    AlcorMP 12/12/14.eD3 Should I use this version right? Sorry to ask but I just don't want to screw anything up and I'm green at it :)
  • #17 16177278
    pidar
    Help: 1569
    Rate: 3589
    xnylbx wrote:
    AlcorMP 12.12.14.eD3 Mam uzyc tej wersji tak?
    Jak są tam odpowiednie Flash-e , to tak. :idea:
    8CD7 10_8C_TOS_TLC_SZ.BIN
    13_8C_TOS_TLC_SZ.BIN Special
    Special ; D3/eD3
    ; D3/eD3
  • #18 16177339
    xnylbx
    No name pops up in these boxes. In Flash Drive Information Extractor he writes that the possible memory chip is toshiba tc58nvg6t2hta00. If I click setup, then alcormp.ini, then select this chip, nothing happens. Or I'm not getting on with it at all.
  • #20 16177447
    xnylbx
    What it pops up, because in the previous one it also popped up, but I clicked something and it was possible to get rid of it? Should I disconnect the USB? 8GB Flash Drive Write-Protected After Fast Formatting: Diskpart Detection Failures & Solutions
The discussion revolves around an 8GB flash drive that became write-protected and undetectable after a fast formatting attempt. Users suggest checking for a physical security switch, although the author confirms there isn't one. Various software tools, including ALCOR and ChipGenius, are mentioned for diagnosing the issue, but the drive remains unresponsive. The author experiences intermittent detection on different computers, indicating potential controller damage. Recommendations include using modified versions of AlcorMP software for recovery attempts, with specific chip identification (Toshiba TC58NVG6T2HTA00) noted for troubleshooting. The conversation highlights the challenges of recovering a malfunctioning flash drive and the importance of using the correct software versions.
