Connecting 5-bulb Chandelier: 3 Unmarked Ceiling Cables, 80s Installation - Troubleshooting
szulczyk 3921 2
  • #1 16746390
    szulczyk
    There are 3 cables sticking out of the ceiling, unfortunately the colors are not marked, installation from the 80s without grounding.
    I have a chandelier with 5 bulbs. There are 3 brown cables in the first cube, 2 brown cables in the second cube, blue cables in the third cube, and grounding in the fourth one.
    If I did not connect these cables, then either I have 3 light bulbs or 2 light bulbs.
    And I would like to press both buttons on the switch, 5 bulbs would light up.
    What am I doing wrong :) ?
  • #2 16746405
    Pedros050
    Help: 2471
    Rate: 3921
    Hello. Blue Neutral (earth) Brown Phase. You dubbed it like this. Connecting 5-bulb Chandelier: 3 Unmarked Ceiling Cables, 80s Installation - Troubleshooting
  • #3 16746409
    kkknc
    Help: 1914
    Rate: 6688
    Very wrong. Call an electrician. It will be faster.
