Connecting 3-Cable Chandelier with 4 Ceiling Wires, Two Switch System & 3 Light Bulbs
14331 2
  • #1 16618961
  • #2 16618993
    Alberciak
    Help: 41
    Rate: 60
    You have to change the cube into a four-chandelier and separate the brown wires so that there are two brown ones in one cube and one in the other one. Then you can use one switch to light one bulb and the other one to light one. If you turn both buttons on, all the bulbs will light up.
  • #3 16619078
    mawerix123
    Help: 482
    Rate: 951
    KarolKiniorski wrote:
    I changed the cube from 3 to 4 hooks but I do not know what to do next.
    So now out of these three brown ones with one lamp separate and put it into the free cube just like in the picture with the difference that in you one cube will be two brown wires and in the other one brown one.
