Ford Focus 1 1.8b - What oil for the engine and transmission with a mileage of 3
16287 9
What engine oil and gearbox oil should I use in a 1999 Ford Focus 1.8 petrol with LPG and very high mileage, when I don’t know what is currently in it?
Use Ford’s preferred engine oil 5W-30, with the listed alternatives 10W-40 or 5W-40 meeting ACEA A3/B3; the oil capacity is about 4.25 L with filter [#16750228] For the cheapest sensible option on an old, high-mileage engine, the replies lean toward a semi-synthetic 10W-40 rather than full synthetic [#16750129][#16750486] The original Ford oil mentioned for the gearbox is 75W-90 to specification WSD-M2C200-C, and the gearbox fill is about 2.3–2.8 L, roughly 2.5 L in one reply [#16750109][#16750228] One reply also notes that oil should normally be changed every 15,000 km or every year, so leaving the same oil for 3 years is not recommended [#16750109]
  • #1 16750020
  • #2 16750109
    mar-ilo
    Help: 9
    Rate: 35
    Originally recommended by the manufacturer is Ford Formula 5W30 and if nothing happens and nothing "takes" while I'm left, it probably was flooded 3 years ago ... - according to the manufacturer comes in 4.3l
    Generally, despite such a low mileage within 3 years, it is not advisable to wait so long with the replacement of oil - replacement after driving a specific number of kilometers is just one of the criteria for replacement - (oil should be replaced every 15,000km or every year) on one of the sites I found such info:
    The original Ford oil - 75W-90 (WSD-M2C200-C) - goes about 2.5 liters
  • #3 16750110
    keseszel
    Help: 54
    Rate: 558
    I would forget about the synthetics. It's a little bit like for year and LPG.
    Picassa, LPG, 2002, 1.8 - 15W40, mentioned 3 years ago, up-to-date refills. I think I will replace now, I drive a little, some 30,000 a year. Opel oil, inexpensive.
    BMW, 1.6, LPG, 1993 10W40, listed 2 years ago. About 15-20 thousand a year, the engine has 340 thousand driven. Only refills.
    As you can see, the type of oil for age is not affected. I would take the cheapest fivepacks. Unless the mechanic will give you a tap and replace yourself. Less work. Avoid oils intended for LPG engines, they are weak. My friend told me that once, a lamp of 3,000 lit on such oil caught fire. No one will be bullshit on my head so I pressed and bought oil for gas. He was right, a few thousand and a control at my place. I exchanged at 15W40 the cheapest and it was better. It sounds like a fairy tale, but from then on I avoid oil with an inscription to LPG. That oil was Orlen. 15W40 sounds like a mantra, but if I did not know what to pour my mechanic ordered Oplowski to buy and it's ok.
    The decision is yours.
  • #4 16750129
  • #5 16750172
  • #6 16750228
    moto-kord
    Help: 137
    Rate: 505
    Engine oil Preferred SAE 5W-30 Ford WSS-M2C913-A specification
    Engine oil Preferred SAE 5W-30 Ford WSS-M2C912-A1 specification
    Engine oil Alternative SAE 10W-40 ACEA A3 / B3 specification
    Engine oil Alternative SAE 5W-40 ACEA A3 / B3 specification
    Engine oil pan, including filter 4.25 (l)
    Gearbox 2,3-2,8l 75w / 90
    The engine will fill the semi-synthesizer well.
  • #7 16750281
  • #8 16750486
    moto-kord
    Help: 137
    Rate: 505
    Buy GM 10w / 40 about PLN 60 for 5 liters.
  • #9 16750578
  • #10 17162213
    morfe1983
    In spite of everything, I would pour 5w40 min - you can do something good - for a good price, for example: Total Energy 5w40 (about PLN 80 for 5L) or Gulf Formula G (similar price). Possibly, something like Lotos, ELF - cheap prices and engine parameters will not kill.
The discussion revolves around the appropriate engine and transmission oil for a 1999 Ford Focus 1.8 115HP petrol vehicle with a mileage of 330,000 km, of which 130,000 km were on gas. The user seeks advice on the original oil type and suitable alternatives after three years without an oil change. Recommendations include using Ford Formula 5W-30 or semi-synthetic oils like 10W-40 or 5W-40, with a preference for cost-effective options. The engine oil capacity is approximately 4.25 liters, while the transmission requires 2.3-2.8 liters of 75W-90 oil. Various brands such as GM, Total Energy, and Gulf Formula G are suggested for their affordability and compatibility.
