Fixing Car Antenna Plug & Improving Radio Reception: Broken Copper Wires & Noise Issues
wojtasek105 12501 2
  • #1 16754433
    wojtasek105
    Rate: 16
    Recently the car antenna plug has broken off. Yesterday I bought a new one, soldered, but something is wrong, there is such noise on the radio that you can't even listen to a station several kilometers away.
    Someone has instructions on how to make a cable for this system: https://multisort.pl/u/4/c/c/4cc4f05e214f815562fab72c0d03a2c0/640x_CAR-CON12.jpg
    I unwrapped the screen and it is clamped on these teeth. Tiny, copper wires are at the tip with quite a lot of tin. What can cause such noise?
    Can the radio receive poor reception if several of these copper wires break off and about half remain? Earning from scratch?
  • #2 16754522
    majsterek
    Help: 79
    Rate: 70
    wojtasek105 wrote:
    Tiny, copper wires are at the tip with a fairly large amount of tin
    You could specify. What does "are at the tip" mean? The screen should be clamped in "teeth" and the central wire should be soldered or tightened to the plug's pin. There must be no short circuit between them
    wojtasek105 wrote:
    if some of these copper wires are torn off and about half are left? Earning from scratch?
    I suggest you earn a new cable.
  • #3 16755060
    wojtasek105
    Rate: 16
    Photo understand you not to suggest completely? Because the copper wires are braided there.
