The radio internet does not work, no signal from the antenna on the roof
Rezunek 5805 2
  • #1 16307933
    Rezunek
    Hello, I have a problem with internet radio. Until recently it was working, but something happened to it during one night. Namely, if I connect the antenna cable with the power supply to the router, Wi-Fi works, but without the Internet, the "WAN" light is off. If I connect the cable from the antenna and power supply to the PC, then the computer does not see the cable at all, and there are no lights on the back of the computer near the Ethernet cable, and there should probably be 2, green and orange. From this information, I concluded for myself that either someone violated the cable at night while I was sleeping (I did not notice any visual breaks in the cable), or the antenna was damned. I wonder what could have happened with the antenna on the roof at night when there was no storm but light snow. The cable is several meters, but I do not know the antenna model, I do not see the model name on its housing. If her appearance is really important, I'll take a picture. Thanks in advance to everyone for your help.
  • #2 16307962
    jimasek
    Help: 3783
    Rate: 2681
    Report the problem to the provider, he is responsible for the infrastructure.
  • #3 16471152
    Rezunek
    The antenna was broken, I got a new one.
