TV + home theater + decoder + ps4 how to connect and set to sound on all sources
xpander11 4080 4
  • #1 16754597
    xpander11
    As in the topic of how to set up such a set of devices so that the sound on all sources comes from home theater? Tv Samsung j6370 cinema Samsung ht-5500, ps4, polsatu hd 7000 decoder
  • #2 16754685
    mariuszp19
    Help: 310
    Rate: 409
    In the cinema you have two HDMI inputs and one optical. So you can safely connect the decoder and ps4 to HDMI in to KD and HDMI out to TV. If you want to have TV sound from the KD, you connect the TV with an optical cable to the audio digital IN.
    Everything is described in the instructions.
    • 02438F_HT-E5500_EN2_00_0224.pdf (10.92 MB) You must be logged in to download this attachment.
    • POL_HMFDVBEUJ-1.308.pdf (6.86 MB) You must be logged in to download this attachment.
  • #3 16754693
    xpander11
    Where are these entrances? There is 1hdmi and 1 optician, if there were 2, I would not write
    The manual you attached is for the HT-E5500 model and I have the HT-H5500 model
  • #4 16754704
    mariuszp19
    Help: 310
    Rate: 409
    There are 2 HDMI inputs in the manual, I don't have this KD so I rely on the manual. If, however, it is as you write, you only have to connect the decoder optically with KD (audio only) and additionally HDMI with TV.
  • #5 16754752
    Polon_us
    Help: 1184
    Rate: 1280
    From what I can see the cinema has one HDMI socket (output) and an optical audio signal input.
    My connection suggestion:
    - connect all devices to the TV using the HDMI connections
    To get sound from the TV and devices connected to it, a colleague has two ways:
    A - use ARC - in this case, the HDMI cable between the TV and the cinema must meet the requirements of HDMI 1.4a
    or
    B - use the optical connection between the TV and the cinema.
    In both cases, some changes to the TV and cinema settings are necessary.
    The instructions describe it nicely.
