Yamaha HTR-2067 - HTR2076 + PS4 + TV how to connect correctly ??
strusiu44 6831 3
  • #1 16657282
    strusiu44
    How to properly connect this yamahe with ps4 and tv?
    Currently I have connected like this:
    Ps4 ------ hdmi ------> HTR2076 -------- hdmi --------> TV ---------- optician ---- ---> HTR2016
    When I turn on the consoles, the TV and the cinema start up with no voice.
    I only have a voice after turning off the cinema and restarting it.
    The TV does not have HDMI ARC. I don't know if this connection is good.
    Come on today I tried various methods and only those above worked.
    While rummaging around and re-arranging the cables, I had to mess up something because the word Decoder off appears each time the decoder is turned on.
    Anybody knows what's going on ?
    Previously, this inscription was not there - it seems to me that it happened after I took out the optical cable with the equipment on.
    I have Linear PCM audio set in the console and in order for me to hear 5.1 sound from the game, I need to have STRAIGHT on the receiver?
    Thank you in advance for your help .
  • #2 16660135
    Polon_us
    Help: 1184
    Rate: 1280
    Please specify what the principles are.
    PS4 sound in the cinema?
    Sound from TV in the cinema?
    The cinema will always be on when the TV is on?
  • #3 16661209
    strusiu44
    Hello and thank you for your interest in the topic.
    And so :
    1 - Yes
    2 - Yes, via optical cable because the TV is older and lacks HDMI ARC
    3 - No TV does not raise Cinema (I have to turn on the cinema separately)
    Whereas ps4 turns on the amplifier. And vice versa, I press BD-DVD on the amplifier turned on, the console turns on, while the TV button does not wake up the TV.
    I connected one more HDMI cable to TV with the Cinema, the sound changed and now the TV button on the cinema wakes up TV but TV does not raise the Cinema.
  • #4 16661934
    Polon_us
    Help: 1184
    Rate: 1280
    Hmmm,
    Ad.3 - I did not mean how it turns on, wakes up or works.
    Basically, is the idea to always have cinema sound when the TV is on?
    This is my case. When the TV is on, the cinema is also on, ie the sound always passes through the cinema.
    Besides - my friend has total chaos with controlling these devices.
    And please turn off the HDMI control !!!
    They are not the most important at the moment.
    Also, disable all HDMI-CEC (HDMI Control) settings on the TV, amplifier and console, if it has such settings.
    It is recommended to disconnect the device from the power supply for a few minutes after each change of the HDMI settings.
    The effect to be obtained - each device turns on from its remote control. No "wake-ups" after HDMI - so far.
    If your colleague will get it, please switch the console to the TV set and check how the sound works, i.e. in the cinema or TV.
    strusiu44 wrote:
    I connected one more HDMI TV cable with Cinema z
    Please expand it - any additional connection?
