How to Program UNIQUE 125kHz RFID Transponder Keychain for Laskomex CD-2502 Interphone
emimik 19356 6
  • #1 16756245
    emimik
    Rate: 13
    Colleagues have such a problem
    Grandma lives in the block has a Laskomex CD-2502 interphone, the keyring to open the door has been damaged and my grandma has her years and eyesight not the memory I will not mention to drive the code.
    I bought a keyring UNIQUE 125kHz RFID transponder
    but I can not program it even with the instruction manual
    contact with fitters it was impossible for some visitors a long time ago
    is it possible to program it so that my grandmother can freely enter?
    Moderated By jimasek:
    corrected
    3.1.18. Do not send links that will cease to be active after some time. This will make the discussion lose any sense.
  • #2 16756355
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    Yes, but only by service technicians who know the service code necessary to enter the programming mode.
  • #3 16756367
    WIESU
    Rate: 32
    It is possible to program the keychain by the user if the registration option (P-2 ida) has not been blocked by the service. It is a bit complicated but to do.
  • #4 16756400
    emimik
    Rate: 13
    any tutorial or tutorial?
    what magical factory code?
  • #5 16756405
    WIESU
    Rate: 32
    I can send a procedure to the priv
  • #6 16756411
    emimik
    Rate: 13
    please send
The discussion revolves around programming a UNIQUE 125kHz RFID transponder keychain for a Laskomex CD-2502 interphone. A user seeks assistance after their grandmother's original keyring was damaged, making it difficult for her to access the building. Responses indicate that programming the keychain may require a service code, typically accessible only to technicians. However, if the registration option (P-2 ida) is not blocked, users can potentially program it themselves, albeit with some complexity. A link to a user manual was provided for further guidance.
