Connecting Hitachi AXS014BTU Soundbar to ADB 1721C Decoder & Manta 32LHN48L TV Setup
Salemz52 12357 5
  • #1 17175644
    Salemz52
    I have a question. Well, I'm going to buy a soundbar and connect it with an optical cable with a decoder, because my TV does not have such an input. Will this configuration work and will the TV speaker be off? The television is a manta 32lhn48l, while the soundbar is Hitachi AXS014BTU, and the decoder is the ADB 1721C model.
    Polon_us
    Help: 1184
    Rate: 1280
    Salemz52 wrote:
    The TV is a 32lhn48l manta
    In fact, this TV has a Coax type digital audio output. "Electrical".
    Salemz52 wrote:
    Will this configuration work?
    This will work, but only with a decoder. All other devices connected to the TV will not work with the sound bar.
    I reviewed the data of the devices owned by a colleague and there are a number of options here - a colleague will choose the one that suits him best:
    - obtain the Coax IN -> OPt Out converter and connect the TV with the sound-bar directly.
    - connect the decoder with the sound-bar with an optical cable - reservation as above.
    - this sound-bar also has analogue inputs and TV has headphone output. Appropriate cables are included in the sound-bar, as shown in the manual.
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    If the sound will be connected to the soundbar from the decoder then the sound on tv should be muted. In general, I do not recommend soundbars, unless it is used as a central speaker supported by separate front speakers where you can get the right base for stereo listening.
  • #4 17176157
    Salemz52
    Another question is whether the use of analog connection will significantly deteriorate the sound quality relative to the optical?
    nomudrek
    Level 36  
    Help: 406
    Rate: 471
    An analog connection will not degrade the sound quality, although it may be susceptible to interference from other devices under special conditions, so I recommend using an optical cable that is not susceptible to interference.
    Polon_us
    Help: 1184
    Rate: 1280
    This is relative. It all depends on the "ear quality".
    Many people can hear the difference in sound quality.
