No Image from Dahua NVR-4104H & MW Power KIP30-1080P-MZ-RW-W IP Camera: DHCP & Connection Issues
infs 6669 6
  • #1 16760987
    infs
    Hello dear forum users.
    I bought the recorder a few days ago Dahua NVR-4104H and camera MW Power KIP30-1080P-MZ-RW-W . I came to the conclusion that since I already have the whole set, it would be worth to put it all together.
    Everything was going well, but now I have a slight problem with the connection ... Well, when I have selected in the DHCP configuration, I easily go to the page with the panel (internal network) of the recorder configuration, but in the recorder menu I can not connect to the camera IP - the system does not show it to me. However, when I turn off DHCP, I can easily watch recordings from cameras through the recorder, but I do not have access from the computer to the recorder (IP, of course, the same as in the configuration).
    Here is the network configuration in the recorder:
    Case - No. 1. (DHCP disabled)
    --- RECORDER SETTINGS ---
    MTU: 1500
    [_] LAN download
    IP version: IPv4
    MAC: 4c [...]
    IP address: 192.168.1.108 [_] DHCP
    Subnet mask: 255.255.255.0
    Default gateway: 192.168.1.1
    Preferred DNS: 223.5.5.5
    Alternate DNS: 233.6.6.6
    --- READING CAMERA DATA FROM RECORDER ---
    IP address: 192.168.1.168
    Port: 8999
    Case - No. 2. (DHCP enabled)
    MTU: 1500
    [_] LAN download
    IP version: IPv4
    MAC: 4c [...]
    IP address: 192.168.0.100 [v] DHCP
    Default gateway: 192.168.0.1
    After searching, the recorder does not detect any cameras.
    [_]
  • #2 16761149
    sosarek
    Help: 9320
    Rate: 15532
    Do cameras have IP from the same DHCP pool as the recorder?
    Z
    Pka, Poznań, 60-850
  • #3 16761185
    infs
    I do not know if we think the same, but the configuration on the router was under IP 192.168.0.1, so I understand that it is about the pool 0 , Yes? Now I changed to 192.168.1.1 and I will try to connect to DHCP again.
    I think right
    sosarek
    Help: 9320
    Rate: 15532
    Yes, that was it - set a fixed IP for the recorder and cameras.
    Z
    Pka, Poznań, 60-850
  • #5 16761419
    infs
    Managed to. :)
    One more question - can I connect the PTZ ORLLO IR ROTATION ZOOM IP camera to this recorder? I connect it in the same way as that of the MW Power, it appears on the list of cameras in my network, but after adding it a red "light" in the recorder configuration is lit (it means that the camera is not ready) and the image is missing. :(
  • #6 16761426
    sosarek
    Help: 9320
    Rate: 15532
    The camera supposedly supports Onvif so it should work, you entered the password correctly?
    Z
    Pka, Poznań, 60-850
  • #7 16761486
    infs
    And this is so ... I forgot that the camera password is 888888 and not admin. :)
    Thank you very much for your help :)
The discussion revolves around connection issues between a Dahua NVR-4104H recorder and an MW Power KIP30-1080P-MZ-RW-W IP camera. The user initially faced difficulties accessing the camera through the recorder when DHCP was enabled, although they could view recordings when DHCP was disabled. Suggestions included ensuring that both devices are on the same DHCP pool and setting fixed IP addresses for the recorder and cameras. The user successfully resolved the initial issue and inquired about connecting a PTZ ORLLO IR ROTATION ZOOM IP camera, which was not displaying an image due to a password error. The importance of correct password entry for camera access was highlighted.
