Title: Connecting Hikvision DS-2CD1741FWD-IZ IP Camera to BCS-P-SNVR0401 Recorder: No Link Issue
pavloalpin 11346 9
Why do Hikvision DS-2CD1741FWD-IZ cameras show "NO LINK" on a BCS-P-SNVR0401 recorder, and how can I make them connect?
The cameras are likely not connecting because ONVIF is disabled or mismatched, so enable ONVIF on the Hikvision camera and verify that the recorder’s ONVIF support matches the camera’s version [#17435688][#17436997][#17432970] If the Hikvision firmware is above 5.5.5, ONVIF must be turned on manually because it is disabled by default [#17435688] Check the recorder software/firmware too, since the BCS-P-SNVR0401 support was noted as ONVIF 2.4 and firmware updates may be needed [#17432970][#17434795] If ONVIF still fails, create an additional user account on the camera and add it via RTSP instead of relying on the admin login [#17435730] Users reported Hikvision cameras working with BCS recorders once ONVIF/RTSP was configured correctly [#17435688][#17436997]
  • #1 17432845
    pavloalpin
    I have the following problem:
    I want to connect cameras from hikvision DS-2CD1741FWD-IZ to the BCS-P-SNVR0401 recorder.
    Everything is clear on paper and in theory - compatible parameters in the network, requirements of the recorder and cameras are compatible, cable connections have been checked.
    The recorder detects cameras, but the preview says "NO LINK".
    For comparison, cameras of the same brand as the recorder work flawlessly.
    I am asking for advice on the subject.
  • #2 17432920
    suworow
    Help: 650
    Rate: 1278
    I understand that from a computer, for example, through a browser, it is possible to enter this camera? Probably both devices compatible with ONFIV and a colleague chose this interface?
  • #3 17432970
    gradek83
    Help: 930
    Rate: 2103
    Unless I am mistaken, the BCS-P-SNVR0401 recorder supports ONVIF 2.4
    As for the DS-2CD1741FWD-IZ camera, you can check which ONVIF version supports the ONVIF Device Manager program, log in as admin admin
    In the first upper Identification tab you have information about ONVIF version
    version 2.40 and 2.04 is not the same.
    Alternatively, if you have not already done it, you can update the camera and recorder firmware firmware, if it does something. Anyway, sometimes they just don't want different branded equipment to cooperate with each other.
  • #4 17433465
    pavloalpin
    Unfortunately, thanks to the ONVIF manager program, I am not able to check the protocol version in the camera. The program sees the hardware but is unable to spit out a response (Error).
    The firmware update for the recorder is available on the manufacturer's website, but after all possible actions (including renaming the .bin file, the recorder spits out "wrong filename".
  • #5 17434795
    BCSCCTV
    Level 19  
    Help: 40
    Rate: 114
    This is a Point series recorder and here we do not change the file name, but upload it as it was downloaded from the ftp server.
    Please check if possible pick up onvif versions in camera.
    BCS Sp z.o.o
    Modularna 11, Warszawa, 02-285 | Company Website: https://www.bcs.pl
  • #6 17434860
    pavloalpin
    Both files from D19 and D20 directories do not update the recorder in the original (program.bin) or after changing the name (update.bin).
  • #7 17434878
    BCSCCTV
    Level 19  
    Help: 40
    Rate: 114
    Please provide the software version that is in the recorder
    BCS Sp z.o.o
  • #8 17435688
    luk9753
    Help: 63
    Rate: 147
    In the hik camera, if the software is above version 5.5.5, you have to manually enable onvif, because it is disabled in this version of the software from the start. The next thing is the recorder software. I have a lot of installations where hik cameras work with BCS recorders and it flies without problems.
  • #9 17435730
    kood
    CCTV and Stationary Alarms specialist
    Help: 259
    Rate: 443
    I rarely mount hika cameras, but from what I remember, when there were problems with onvif, I added an additional account on the webcam (the admin did not want to move) and added the camera on the rtsp port.
  • #10 17436997
    Gutek1512
    Help: 39
    Rate: 37
    Check on the camera if onvif is turned on, and rtsp. I'm worried why you can't login and was the camera activated ??? Maybe a stimulant and ports changed. You have to force yourself to login to the camera.
The discussion revolves around the issue of connecting Hikvision DS-2CD1741FWD-IZ IP cameras to a BCS-P-SNVR0401 recorder, where the recorder detects the cameras but displays a "NO LINK" message. Participants suggest checking the ONVIF compatibility, as the BCS-P-SNVR0401 supports ONVIF 2.4, while the camera's ONVIF version needs verification. Firmware updates for both devices are recommended, with emphasis on ensuring the camera's ONVIF feature is enabled, especially if the firmware is above version 5.5.5. Additional troubleshooting steps include checking RTSP settings, ensuring the camera is activated, and possibly creating a new user account for the camera.
