Programming Cabletech PIL0400 Universal Remote for Nice Mhouse: Step-by-Step Guide
paulo_1988 8604 5
  • #1 16761114
    paulo_1988
    I warmly welcome,
    I bought the PIL0400 Cabletech universal remote control, I am trying to program it from Nice Mhouse according to the instructions, but nothing comes of it.
    Maybe you can tell how to do it correctly?
    Regards
  • #3 16761405
    PROXIMA sj
    Radio controllers specialist
    Help: 103
    Rate: 220
    Continuing the slight sarcasm of colleague Marek216, it seems that colleague Marek216 has good eyesight.
    Your remote copies three variable coding systems - Ditec-, -Nice Flor-s- and -V2-.
    I do not copy the Nice MOOVO system.
    You must buy a Nica MOOVO remote control or its replacement.
    It may be useful to know that MOOVO coding is the same as MHOUSE coding - the remote controls are compatible with each other.
    Regards
    PROXIMILIAN
    PROXIMAsj
    Polna 23A, Toruń, 87-100 | Company Website: www.proxima.pl
  • #4 16763464
    Mstasik
    Help: 27
    Rate: 76
    The remote controls in this system are based on the HCS301 Microhipa processor, and the 64-bit Keeloq coding system, you can use, as already suggested by a colleague Proximilian pilot moovo or Nice Smilo or a replacement of the mentioned company PIL0401. You will not code others into the machine.
  • #5 16763544
    PROXIMA sj
    Help: 103
    Rate: 220
    Nice Smilo will not work.
    Regards
    PROXYMILIAN
    PROXIMAsj
  • #6 16765553
    Mstasik
    Help: 27
    Rate: 76
    In that case, I'm sorry for the confusion. In that case PIL0401 will not work either.
    For sure, in the offer of the "Proxima" company you will find a suitable replacement for you from the wide range of pilots. Personally, I recommend MINI - comfortable and durable.
    By the way, could NICE change the encryption code for this gateway when it has the very popular SMILO radio route? Is there any point in launching a separate range of remote controls and encryption for this type of solution? Generally, proven solutions are used, especially that SMILO is slowly disappearing. Now NICE promotes and develops a much better secured radio route and ERA series remotes.
