VW Golf mk6 1.6 TDI 105km 2010 Model - Engine Instability at Low Revolutions
Kamil782 25935 7
  • #1 16761755
    Kamil782
    Hello!
    I have Golf mk6 from 2010 with a 1.6 tdi engine with a power of 105km.
    The problem is that at low revolutions when the car is standing, the engine sometimes starts to work strangely, so it is not even enough for a second to slightly add gas and everything returns to normal. (If we do not add gas, the engine will stabilize itself after a while and start to walk again normally.) The revolutions do not wave, they stay in one position.
    The car was with two mechanics but none found a cause. When the car was connected to the computer, the mechanic said that there are quite large fluctuations in fuel pressure on the rail. Do you have an idea what it can be?
    PS: Injections checked, everything in the best order.
  • #2 16761772
  • #3 16761773
    Kamil782
    Okay, I'll go to the weekend and check the whole system, thank you very much. If anyone had other ideas then please give :)
    Added after 15 [hours] 26 [minutes]:
    I will add that nothing happens on a cold engine at all.
    The longer the car is working, the more frequent this symptom is, and when the engine is cold it always goes normally
  • #4 17121187
    krukp
    Hello ,
    I have a similar problem - did you solve your problem?
  • #5 17620253
    Jacek Pac
    Rate: 8
    I have the same problem, did you manage to do it?
    Added after 54 [seconds]:
    krukp wrote:
    Hello ,
    Hello, I have the same trouble with how you dealt with it?
  • #6 17620965
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 489
    Most likely a pressure regulator for replacement. It is blurred. This can be seen in dependence between the activation of this valve and the pressure.
  • #7 18662618
    Pajda89
    Rate: 66
    I was looking for answers.
    I searched and it turned out that the same happens in golf 5 1.6tdi.
    I once had a peugeot partner 2.0 hdi.
    There was also a common rail there, the same symptoms. But no errors ... It turned out that the pressure regulator went crazy. After replacement, the fault has ceased. So I will try to replace the regulator in this 1.6tdi and let me know.
  • #8 18725204
    Pajda89
    Rate: 66
    So what was the reason?
    Did you get it
The discussion revolves around a 2010 VW Golf mk6 with a 1.6 TDI engine experiencing instability at low revolutions. The owner reports that the engine occasionally runs erratically while stationary, but stabilizes with slight acceleration or after a brief period. Mechanics have been unable to diagnose the issue, although fluctuations in fuel pressure on the rail were noted. Several participants suggest that the problem may be related to the pressure regulator, with one user sharing a similar experience with a Peugeot Partner, where replacing the pressure regulator resolved the issue. The owner plans to check the entire fuel system for potential faults.
