Krups EA8160 Espresso Machine: Cleaning Program Issues - Tablet Not Dissolving Properly
adakris 75027 13
Is it normal for the Krups EA8160 cleaning tablet to come out of the machine almost intact after the automatic cleaning cycle, or does that indicate a fault?
No, a tablet coming out almost intact does not by itself indicate a fault. In this model the tablet is mainly there to create foam that cleans the brewing chamber, so it may be ejected only slightly dissolved and the cleaning cycle can still be successful [#16764752] Even if the tablet is only a little deformed, that is described as the natural symptom of a completed cleaning procedure [#16765183]
  • #1 16764044
    adakris
    Rate: 10
    Hello!
    I’d like some advice on how to use the cleaning programme on my Krups EA 8160 coffee machine correctly. Whenever the machine indicates that maintenance is required, I carry out all the maintenance steps in accordance with the instruction manual. Before starting the automatic cleaning cycle, I place a cleaning tablet in the container and then start the programme. For some time now, there has been a problem whereby, once the cleaning process is complete, the machine ejects the cleaning tablet – practically untouched (or perhaps slightly worn) – into the coffee grounds container, meaning the cleaning programme ran without using the tablet. I’ve repeated this process and even tried different tablets, but the problem persists. Could you please advise whether these symptoms indicate a fault with the coffee machine? I should add that I took the machine to the warranty service centre, describing this situation. However, they concluded that everything was fine, which I cannot entirely agree with.
  • #2 16764270
    ssss
    Help: 471
    Rate: 1824
    The tablet should only be injected when the machine asks for it. Please read the instructions.
  • #3 16764668
    adakris
    Rate: 10
    I do not know how the program would ask for a tablet. When the signal for the need for cleaning with the tablet appears behind the display, I follow the instructions:
    Cleaning program - total duration: about 13 minutes
    When the device announces the need to perform a cleaning program, you do not have to do it right away, nevertheless
    however, the program should be executed as soon as possible. If the cleaning is postponed, the message
    The warning message will be displayed until cleaning is performed.
    ? If a pictogram is displayed, the automatic cleaning program can be started. Including
    press the maintenance and settings button. Choose a pictogram. Function indicator
    located above the maintenance button.
    ? The automatic cleaning program consists of 2 parts: the correct cleaning cycle and the rinsing cycle.
    Cleaning can be carried out at any time. To do this, press the button
    maintenance and settings, and then select the cleaning pictogram using the navigation button
    ? A 0.6-liter vessel will be needed to carry out the cleaning program
    can be placed under the coffee outlets and the steam nozzle. The pictogram is flashing.
    ? Lift the drip tray (28).
    ? Insert the KRUPS cleaning tablet into the container (29).
    ? Fill the water container to a maximum of 1.7 liters (2).
    ? Empty the grounds container, drip tray and wash the coffee drawer (23-24-25).
    ? Place a 0.6 liter container under the coffee and steam jets (30).
    ? Press START. The pictogram stops flashing. The first stage begins (about 10 minutes).
    After completing this stage empty the drip tray. The pictogram flashes. Put the elements in place.
    ? Press START. The pictogram stops flashing, the final stage begins (about 3 minutes). After
    completing this stage empty the container and the drip tray. The cycle has ended, the menu appears
    "Choosing coffee".
    I do not know in what other way the device should signal the necessity of throwing a tablet, if not just in this one. In addition, as is clear from the instructions, the cleaning program can also be called alone, although the device does not report such a need.
  • #4 16764752
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3338
    Yes, it's natural ... These pills do not dissolve only because of their effect is foam which cleans the brewing chamber.
    Relax ... Despite the ejection of the tablet, the cleaning procedure was successfully carried out.
    Kawa i Naprawa - Serwis AGD
  • #5 16765071
    adakris
    Rate: 10
    Thanks for the answer, finally someone has specifically answered the question bothering me. By the way I am wondering, that earlier the tablet dissolved in its entirety, and now falls out almost unaffected, the fact looks like "dried", but apart from minor defects it is almost whole. I also have an additional question, is it possible to read the number of coffees made up to date, is there any instruction, how to read this parameter without visiting the website? Perhaps the quantity of coffees made has an impact on the course of the purification process.
  • #6 16765183
    nioop
    Help: 503
    Rate: 3338
    I totally agree. Sometimes it's the case that the tablets dissolve to half, but it's more a question of the tablets themselves.
    If the tablet is thrown only a little deformed, it is the most natural symptom and the brew chamber has been cleaned.
    Unfortunately, it is not possible to check the amount of coffee for the user in this model. The menu is very thin.
  • #7 18246835
    AdiEjcz
    Let me ask Expert because he has not exhausted the thread:
    How do you trigger additional cleaning and descaling?
    In fact, the manual mentions this, but does not describe the procedure.
    best regards
  • #8 18247288
    nioop
    Help: 503
    Rate: 3338
    best regards
    It is not possible.
  • #9 18839215
    BC313
    Help: 17
    Rate: 208
    Hello. I have the same problem with the tablet not dissolving. The tablet is thrown away completely slightly dissolved because only the first moment the water passes through the chamber with the tablet, then everything goes to the drip tray without foam because it bypasses the tablet and the piston chamber in which it is located. Any advice ideas?
  • #10 19030341
    Robsonmb
    Rate: 9
    Hello, I have similar problem. When I start cleaning cycle, water does not come out. It runs directly in container on bottom, and on the end whole tablet is ejected. What can I do?
  • Dual-pressure valve replacement fixes tablet bypass
    #11 19030602
    nioop
    Help: 503
    Rate: 3338
    BC313 wrote:
    Hello. I’m having exactly the same problem with the tablet not dissolving. The tablet is ejected whole, only slightly dissolved, because initially the water flows through the chamber containing the tablet, but later everything flows into the drip tray without any foam, as it bypasses the tablet and the piston chamber in which it is located. Any advice or ideas?
    The dual-pressure valve needs replacing.
  • Replacing all gaskets fixed the water leak
    #12 19351012
    BC313
    Help: 17
    Rate: 208
    I bought a set of gaskets for my model. Originally, I was supposed to replace the seals of the valve itself, but my coffee machine, apart from the impossibility of cleaning, dumped a lot of water and coffee residues into the tray. I replaced all the seals. The problem is gone. A set of gaskets PLN 62. There is a little bit of work, but it can be done with a bit of free time ???.
    My set of old gaskets looked like this. They didn't look bad, but so as not to wonder which and what they all went to.
    • Krups EA8160 Espresso Machine: Cleaning Program Issues - Tablet Not Dissolving Properly 20210331_201830.jpg (1.34 MB) You must be logged in to download this attachment.
    • Krups EA8160 Espresso Machine: Cleaning Program Issues - Tablet Not Dissolving Properly Screenshot_20210330-220106.png (2.77 MB) You must be logged in to download this attachment.
  • #13 20402959
    tomadanmihai
    I have the same problem with my machine, when I want to use the cleaning tablet, only the first jet of water comes through the coffee pipes the rest goes into the tray for residual water. Did anybody find a fix for this problem? I searched all the internet and all of Google and no answer until this forum.
    Thanks in advance!
  • #14 20604660
    tadeuszglasek
    Hello, I am struggling with the same problem, has anyone of you finally dealt with it? It seems to me that this may be due to the blocking of the old pill during application inside the coffee maker (below the drawer). I am going to unscrew the coffee machine and see, unless someone of you already has a specific answer on how to fix it.
The discussion revolves around issues with the cleaning program of the Krups EA 8160 espresso machine, specifically regarding cleaning tablets not dissolving properly during the automatic cleaning cycle. Users report that the tablets are ejected almost intact after the cleaning process, indicating potential malfunction. Some suggest that the problem may stem from the tablets themselves or from blockages within the machine. Others have experienced similar issues, with water bypassing the tablet and flowing directly into the drip tray. Recommendations include checking for blockages, replacing seals, and ensuring proper tablet usage as per the machine's instructions. However, some users express frustration over the lack of clear solutions and the machine's warranty service response.
TL;DR: Krups EA8160 uses one tablet per cleaning; “the effect is foam which cleans the brewing chamber.” [Elektroda, nioop, post #16764752] Why it matters: If your tablet looks unused or water bypasses, this FAQ shows what’s normal vs what needs a fix, and how to run cleaning correctly for EA8160 owners solving tablet-dissolving issues.
Why is my Krups EA8160 tablet not dissolving during cleaning?
That can be normal. The tablet’s active foam cleans the brew chamber, and the puck may eject slightly deformed. If the cycle completed, cleaning likely worked. “These pills do not dissolve… the effect is foam.” Check only if water entirely bypasses the chamber. [Elektroda, nioop, post #16764752]
How do I run the EA8160 cleaning cycle correctly?
Follow the on‑screen prompt. How‑To: 1. Place a 0.6 L vessel under coffee spouts and steam nozzle, lift drip tray, and insert one KRUPS tablet in the container. 2. Fill water tank to max and empty grounds/drip tray. 3. Press START for stage one (~10 min), then START for stage two (~3 min). [Elektroda, adakris, post #16764668]
Can I start an extra cleaning or descaling cycle on demand?
No. This model does not allow users to trigger additional cleaning or descaling beyond what the machine requests via the maintenance menu. The service reply in the thread is definitive: “It is not possible.” [Elektroda, nioop, post #18247288]
What does it mean if water goes straight to the drip tray during cleaning?
That failure indicates bypass in the hydraulic path. A common culprit is the two‑bar valve. Community fixes cite replacing that valve when water skips the tablet and heads to the tray. Result: tablet ejects whole and no foam forms. [Elektroda, nioop, post #19030602]
What is the two‑bar valve on the EA8160?
It is a pressure‑control valve that routes flow during brewing/cleaning. When it sticks or its seals fail, water can bypass the brew chamber and dump into the drip tray. Replacement restores proper flow through the tablet path. [Elektroda, nioop, post #19030602]
My machine asks for cleaning—when exactly do I add the tablet?
Add one KRUPS cleaning tablet only when the display prompts the cleaning cycle and after lifting the drip tray and opening the tablet container. Then press START to begin stage one. [Elektroda, adakris, post #16764668]
The tablet used to dissolve fully but now ejects almost whole—should I worry?
Not always. Tablets sometimes dissolve only partially, yet cleaning completes because the foam did its job. If coffee or water also overflows to the tray abnormally, inspect valves and seals. Otherwise, continue normal use. [Elektroda, nioop, post #16765183]
Water and coffee residues fill my drip tray; could seals be the issue?
Yes. One user resolved bypass and cleaning failures by replacing all seals, not just in the valve. Cost reported: 62 PLN for a gasket set. Replacing seals reduced tray dumping and restored cleaning. [Elektroda, BC313, post #19351012]
How long does EA8160 cleaning actually take?
About 13 minutes total: roughly 10 minutes for the first cleaning stage and 3 minutes for the final rinse. Have a 0.6 L container ready and a full tank. [Elektroda, adakris, post #16764668]
Can I see how many coffees my EA8160 has made?
No. The EA8160 has a limited user menu and does not display a total shot counter. Service tools might, but users cannot access it in this model. [Elektroda, nioop, post #16765183]
What should I do if only the first jet passes the tablet, then everything bypasses?
This pattern suggests a failing two‑bar valve or its seals. Replace the valve assembly to restore constant flow through the tablet chamber so foam forms for the full cycle. [Elektroda, nioop, post #19030602]
Is a nearly untouched tablet proof the cleaning failed?
No. If the machine completed the cycle and you saw foam early on, the detergent likely acted. The tablet core can remain and still be ejected. “Relax… the cleaning procedure was successfully carried out.” [Elektroda, nioop, post #16764752]
What container and water fill levels do I need before cleaning?
Place a 0.6 L vessel under the outlets and steam nozzle. Fill the tank to its 1.7 L maximum. Empty the grounds and drip tray before pressing START. [Elektroda, adakris, post #16764668]
Could an old stuck tablet block new tablets from dissolving?
Yes, if a tablet fragments below the drawer and obstructs the chute, new tablets may not seat right. Inspect and clear the tablet path when access is safe and power is disconnected. [Elektroda, tadeuszglasek, post #20604660]
What’s the fastest way to confirm if cleaning is flowing correctly?
Watch the first minute. You should see detergent foam at the spouts before any significant tray dumping. No foam plus early tray flow points to a bypass fault, often the two‑bar valve. [Elektroda, nioop, post #19030602]
What’s an expert’s one‑line tip for EA8160 cleaning issues?
“These pills do not dissolve only because of their effect is foam which cleans the brewing chamber.” Focus on flow and foam. [Elektroda, nioop, post #16764752]
