Krups EA8251 - Error 07, the piston is sticking against the grounds scraper
szwaldek 11613 2
  • #1 16661352
    szwaldek
    Rate: 8
    I am asking for help from colleagues who have more experience.
    The problem is that when the piston goes down, the coffee grounds scraper does not always retract and there is a collision :-) error 07 pops up.
    This happens when the machine is filled with water while it draws water.
    Moreover, I noticed that there is a constriction on the slider and I do not know if it is worked out.
    Does the scraper originally have a return spring, etc.
    Please let me know where you can get such individual parts?
    I post photos
    Krups EA8251 - Error 07, the piston is sticking against the grounds scraper Krups EA8251 - Error 07, the piston is sticking against the grounds scraper
  • #2 16661439
    koala106
    Help: 471
    Rate: 1240
    Parts on north.pl
  • #3 16665673
    szwaldek
    Rate: 8
    Problem solved.
    Mechanically bending the guide and after the problem, the replacement of seals + lubrication and the machine will continue to serve.
    I close the topic.
