Adjusting Flow Meters in Distributor with Wilo Pump & Setting WILO-Yonos PARA RS 25/6 to AUTO Mode
Meon 70743 6
  • #1 16767037
    Meon
    Rate: 41
    I have a problem - I do not know how to adjust flow meters in a distributor with a Wilo pump, exactly like this:
    Pytan, how do I adjust the upper flowmeters? If I unscrew, they are all twisting. Tomorrow I plan to flood the system, and I do not want to damage anything.
    Another question, the pump I have: WILO -Yonos PARA RS 25/6 as in the picture, I can not find instructions on how to set it to AUTO mode.
    Greetings.
  • #2 16767049
    irus.m
    Heating systems specialist
    Help: 122
    Rate: 453
    You turn the white knob on the bottom bar and look at the flow at the top of the appropriate rotameter.
  • #3 16767125
    Meon
    Rate: 41
    So the rotameters at the top are not regulated at all?
    Do you know how to set this pump to automatic mode?
  • #4 16767496
    ziomekorko
    Level 19  
    Help: 32
    Rate: 176
    Hello. Turn the white knobs to the max, then remove the red caps from the rotameters, underneath there is a place for turning the rotameter. Flows are pre-set to 1.5-2 liters on each cycle, you wait calmly a day or two until it starts to heat up, or you regulate when you heat it too low, where you get too cold. Of course, the adjustment is to proceed smoothly, no sudden changes in flows. You set the pump so that its capacity is sufficient to ensure adequate flows. The thermostat under the pump sets the temperature to 25-35 degrees depending on how the floor heating is made.
  • #5 16767518
    Meon
    Rate: 41
    Ok, unscrew them during flooding, before or after?
  • #6 16768640
    ziomekorko
    Level 19  
    Help: 32
    Rate: 176
    During filling, all flow meters have been turned on the max and white knobs. After filling with water, we completely vent the heating system, start the pump and set the flows.
  • #7 16772135
    Meon
    Rate: 41
    Thanks, everything is blown and it's going to be nice.
✨ The discussion revolves around adjusting flow meters in a heating system using a Wilo pump, specifically the WILO-Yonos PARA RS 25/6 model. Users inquire about the proper method to adjust the upper flow meters, which are not directly adjustable, and seek guidance on setting the pump to AUTO mode. It is advised to turn the white knobs to maximum, remove red caps from the rotameters, and adjust the flow settings gradually after filling the system with water. The importance of venting the heating system and ensuring adequate flow rates is emphasized for optimal performance.
