2006 SEAT Ibiza 3 Right Windscreen Issue - Intermittent Function after Speaker Installation
qqwwee11 10353 7
  • #1 16768240
    qqwwee11
    Rate: 19
    Hello . I come to you with a problem, the car window does not open on the passenger side, the fuses are good, the current comes to errors on the computer, it does not show and, interestingly, if I turn the window off the engine for a moment and turn it on for 5 minutes, the window works for a maximum of 2 minutes and the wheel in this moment it staggers because the glass still does not work. Interestingly, on the driver's side, I can't open the passenger's window, but in that case there is no reaction. The problem arose after I mounted the loudspeakers in the car (Yes, the door casing was removed then) but I did not damage anything, I checked a dozen times Please help my mechanic without a councilor
  • #2 16768314
    spinacz
    Help: 1206
    Rate: 2658
    Since the beam is not damaged and all power and communication are coming, the module in the door is damaged, but for me, the power supply should be checked again.
  • #3 16768350
    qqwwee11
    Rate: 19
    I put in a module with a motor from another Ibiza seat and it behaved the same
    unless this one too would be as flawed as mine, I don't know I have no explanation for that anymore
    sk700
    Help: 173
    Rate: 420
    spinacz wrote:
    communication is coming
    Probably it is not happening because the passenger window cannot be opened from the driver's panel.
    The fact that after disconnecting the power supply you can temporarily control the glass from the local button is the typical behavior of the controller on the window motor when there is no communication with the comfort module and there is power. Unplug the plugs from the passenger engine and measure the voltage to ground on the twisted orange wires with colored stripes.
  • #5 16768675
    qqwwee11
    Rate: 19
    I will simply say briefly, I was with one mechanic, he sent me to an electro-mechanic, neither can the other one help but the other one proposes to buy a new electronic motor in which the module is, but I know that I have already tested these methods on another used motor nothing helped, therefore for me this electrician is not reliable and I just don't know what to do
  • #6 16768725
    robokop
    Help: 1763
    Rate: 6376
    It goes to control all windows from the level of the diagnostic device?
  • #7 16768742
    qqwwee11
    Rate: 19
    This method was certainly not used by this electronics. But what's interesting, when I wanted to open the glass both through the key in the door, the driver's side was opening and the other, unfortunately, not ...
  • #8 21687054
    Azrael323
    >>16768240 Czy udało Ci się rozwiązać ten problem? Mam ten sam błąd, który opisujesz.
The discussion concerns an intermittent right passenger window fault on a 2006 SEAT Ibiza 3 that appeared after speaker installation and door trim removal. The window motor/controller works only briefly after ignition reset, while the driver’s switch cannot operate the passenger window reliably. Fuses are intact and diagnostics show no obvious fault, but the behavior suggests a problem in the door module, window motor electronics, wiring, or communication with the comfort module. A replacement motor/module from another Ibiza showed the same symptom, and the suggested next checks were voltage measurement on the twisted orange communication wires and testing window control via diagnostic equipment.
