Iphone 5s Not Loading: Charging Issue, Screen Flickering, White Background with Black Apple
wwieslaw1 7482 7
  • #1 16769161
    wwieslaw1
    Help: 8
    Rate: 10
    Iphone 5 s. After connecting the charger it shows the charge (as seen in the example photo) for three seconds, then the image goes out and the charge is shown again for three seconds all the time. After attaching the charged battery, the phone normally turns on and works. After connecting the charger zero reaction but when the battery is charged and turns it off after connecting the charger appears a white background with a black apple and the phone turns on but still nothing is charging. I changed the batteries and the tape with the charging connector and then the same. Original charger. Someone had such damage? Have any ideas ?
  • #2 16769248
    DejoDejo
    Help: 35
    Rate: 75
    Have you checked the plug on both sides?
  • #3 16769324
    strucel
    Level 36  
    Help: 271
    Rate: 623
    The original charger but the cable too? For me it was so that 5s was charging only when it was turned off and in addition you had to press the switch for a while after connecting the cable but literally for a second so that the phone does not turn on. I have two 5s at home, a whole lot of cables and in both the same on all cables - in addition, the computer saw them only in dfu, normally an unrecognized device popped up. It looked damaged famous U2 but yesterday the wife bought a new 7 and cable from her
    both 5s work normally, the phones are not my plot but I talked to a friend who is a specialist in this field and according to him apple in the next installments of the system blocks non-original accessories so that they do not work properly so maybe check on a 100% sure cable because 2 of my cables too they were to be original and after cutting the lighting plug it turned out to be Chinese fakes.
  • #4 16769613
    wwieslaw1
    Help: 8
    Rate: 10
    Charger and original cable. I noticed today that when it is turned on on a charged battery, iTunes cannot see it either, but it appears that the disc is damaged.
  • #5 16770479
    DejoDejo
    Help: 35
    Rate: 75
    I don't know ... I'd check this cable first ;)
  • #6 16772867
    wwieslaw1
    Help: 8
    Rate: 10
    Do you read my friend? Charger and original cable.
    Ps. To a moderator who wants so hard to improve my spelling. Please read about dyslexia and, for example, the lack of a Polish keyboard.
  • #7 16775381
    DejoDejo
    Help: 35
    Rate: 75
    I did not mean that you would check if the cable is original. I suggested that you check the cable - the original ones also get damaged ;)
  • #8 16784990
    matrix5
    Help: 8
    Rate: 37
    You probably need to replace the U2 - 1601A1 charging system, if you feel up to it and you have the right equipment for it, you will do it yourself, if not for service
The discussion revolves around an iPhone 5s experiencing charging issues, characterized by a flickering screen and a persistent white background with a black Apple logo when connected to a charger. The user reports that the phone operates normally with a charged battery but fails to charge when plugged in. Various responses suggest checking the charging cable and connector, as even original cables can become damaged. One user mentions a potential issue with the U2 charging system, recommending replacement if the user has the necessary skills and tools. The importance of using genuine accessories is emphasized, as non-original cables may not function correctly with the device.
