Vito 639 No Power & P0105 Error: 2006 Model, 220k, Loss of Power, Tried Sensor & Valve Replacement
solek_87 17646 16
Why does my 2006 Mercedes Vito 639 lose power and throw P0105 after warming up, even after replacing the boost pressure sensor, intercooler pipe, turbo vacuum valve, cleaning the turbo geometry, and checking vacuum?
The most likely remaining fault is in the turbo control system, especially blocked turbo geometry or the wiring/vacuum control to the turbine actuator, so the car needs to be diagnosed live while driving and the harness plus vacuum lines checked carefully [#17026138] One user later reported that after replacing all the pressure sensors, the real problem was a blocked geometry, and the issue was fixed only after renovating the turbo and sensors [#18669429] In the thread it was also suggested to test the three sensor wires in parallel and to check the valve wiring, because a broken or intermittent circuit can produce the P0105 fault [#16771149]
  • #1 16770751
    solek_87
    Hello, this is the situation: Vito 639 2006 220 thousand. Started up in the morning, traveled about 10 km, stopped on fire for about 5 minutes, I got on the gas and did not drive, i.e. no power. The check is not lit. I drive about 10 km, the check lights up and there is still no power.
    Off, on, turns high, after a while up to 3 thousand. the check does not go out.
    When I start right away, it turns high and goes nicely, after a while, about 700 meters of mussels and up to 3,000.
    Error P 0105, boost pressure sensor.
    I did the tests:
    Sensor replacement 3X replacement with other Vito and new.
    The new intercooler pipe because it had some slack.
    Replaced a new turbine valve, the one from the vacuum.
    The geometry of the turbine was cleaned, although the lever moved relatively.
    Exhausted cables from the sensor cube to the computer.
    Sensor cube replaced.
    The vacuum holds.
    What kind of bush crept in?
  • #2 16771149
    jurekk55
    Level 36  
    Help: 182
    Rate: 1580
    Test these 3 cables in parallel
    What about the valve cables?
  • #3 17015553
    Fokus1981
    Hello . The post is from that year, but I have a question, did you solve this problem? After reading your post I found that the same bush crept into my vito. I checked and replaced the same as you. If you can, please reply.
  • #4 17026064
    solek_87
    unfortunately no, the car was at the painter's place for a while, and now it is trying to resuscitate it again
  • #5 17026105
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    There are probably 2 pressure sensors, one on the pipe from the inercolera, access from the bottom.
    It must be original because replacements are often stained.
  • #6 17026118
    solek_87
    inserted from a second working Vito
    What else can I say about the defect, I don't know if it's related, but maybe before the defect arose, the car put on Friday on Monday was burned with cables, not always but a few weeks before the breakdown. after the breakdown, it can take a week and it is approx.
  • #7 17026124
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    With what description - out of range, open circuit ect?
  • #8 17026126
    solek_87
    the beginning of the story takes about 30 minutes from firing with cables. Is it possible that the computer spilled out?
    I don't remember exactly the description of p0105, but I think high pressure or something like that
  • #9 17026131
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    You write about the sensor and there are 2 of what I remember?
  • #10 17026132
    solek_87
    this sensor at the bottom
  • #11 17026138
    diodabg
    Level 30  
    Help: 133
    Rate: 627
    You need to diagnose while driving, check the harness for adjusting the turbine and vacuum.
  • #12 17026143
    solek_87
    the wiring harness to the valve is checkable, i.e. there is a transition. negative pressure also approx
    while driving, i.e. what do you mean? I am not a mechanic, but I have already sat in the workshop for 3 days, maybe I do not know what and how
  • Webasto fault likely caused boost sensor error
    #13 17029983
    Fokus1981
    Hello, thanks for the answer. For me, the problem was solved after trying to run the faulty WEBASTO. The problem started when one evening I tried to turn on webasto, which I used often. Unfortunately, this time without success. From that moment, problems with the lack of power began, error code 0105 too high voltage of the boost sensor, etc. I have tried to turn on the heating many times. It ended up chirping the fuse. On Wednesday I started trying to turn on the webasto almost fired again. From that moment on, everything was back to normal. Perhaps there was a problem with the webasto that could have affected the voltage on my boost sensor. Maybe something was blocked. I don't know, but after this attempt to turn on the parking heater, the car flashes, no errors, the emergency mode indicator does not turn on. Try to blow out the webasto fuse, if you have one. Not much work and the fork knife is the same problem that was in my vito. best regards
  • #14 17032682
    solek_87
    I don't have a webast
  • #15 18214908
    tomas0507
    Hello . P0105, unfortunately, also popped up for me. Would you help me - tell me which sensor it is and where I can find it. Thank you for the suggestion VITO 111CDI 2005.
  • #16 18669295
    wierzba123
    Rate: 78
    Hello. I'll dig up the topic a bit. I have the same symptoms and error. Someone dealt with the problem?
  • #17 18669429
    tomas0507
    Hello - I replaced all the pressure sensors with me - but it turned out that the geometry was blocked - so the turbine and sensors were renovated. Now everything works as it should. best regards
The discussion revolves around a 2006 Vito 639 experiencing a loss of power and displaying a P0105 error, indicating a boost pressure sensor issue. The owner reported that after driving a short distance, the vehicle lost power, and the check engine light illuminated. Multiple attempts to resolve the issue included replacing the boost pressure sensor, intercooler pipe, and turbine valve, as well as cleaning the turbine geometry and checking wiring. Suggestions from other users included diagnosing the wiring harness and checking for additional pressure sensors. One user resolved similar symptoms by addressing a malfunctioning Webasto heater, which may have affected the boost sensor's voltage. Others noted that blocked turbine geometry could also lead to similar issues.
TL;DR: Mercedes Vito W639 power loss with P0105 often traces to the boost/MAP circuit; this van uses 2 pressure sensors, and as one expert notes, "It must be original." Check sensor, wiring, vacuum, actuator, or turbo geometry. [Elektroda, diodabg, post #17026105]
Why it matters: This FAQ helps Vito 639 owners quickly pinpoint no‑power + P0105 causes and safe fixes.
What does code P0105 mean on a Vito 639?
P0105 flags a boost/MAP sensor circuit fault. Owners report “too high voltage” with limp mode. Expect reduced power and limited revs. Clear the code only after fixing the cause. Inspect sensor, wiring, vacuum control, and turbo actuation before replacement. [Elektroda, Fokus1981, post #17029983]
Where is the Vito W639 boost/MAP sensor located?
One pressure sensor sits on the charge pipe near the intercooler with access from underneath. The Vito uses two pressure sensors, so verify you are testing the correct unit and use an original‑quality sensor to avoid bad data. [Elektroda, diodabg, post #17026105]
What are classic symptoms when P0105 appears?
Drivers report sudden power loss, no acceleration, and revs capped near 3,000 rpm. Some note the issue starts after about 700 meters, then persists with a check light. Restarting may temporarily restore power before the fault returns. [Elektroda, solek_87, post #16770751]
How should I start diagnosing P0105 on the road?
“Diagnose while driving.” Log boost request vs. actual, then check the turbo control harness and vacuum lines under load. A short drive with live data quickly narrows sensor, wiring, or actuator faults without guesswork. [Elektroda, diodabg, post #17026138]
Which quick checks have owners already tried and should I repeat?
Repeat these basics: swap the boost sensor with a known‑good one, inspect/replace the intercooler hose, verify vacuum supply and the turbo control valve, clean variable‑geometry linkage, and continuity‑test the sensor wiring and connector. Document results after each step. [Elektroda, solek_87, post #16770751]
Could a parking heater (Webasto) trigger P0105 and limp mode?
Yes. One owner’s P0105 and power loss began after repeated Webasto start attempts. After the heater nearly started successfully, the engine returned to normal and the errors cleared. Pulling the heater fuse is a quick isolation test. [Elektroda, Fokus1981, post #17029983]
What if my Vito doesn’t have Webasto—should I still chase that?
No. If the vehicle lacks a parking heater, skip heater‑related tests and focus on the boost sensor circuit, vacuum, and turbo hardware. The original poster confirmed no Webasto was fitted, making that path irrelevant in their case. [Elektroda, solek_87, post #17032682]
Can turbocharger geometry cause P0105 and low power?
Yes. A blocked variable‑geometry assembly can miscontrol boost and set P0105. One fix involved refurbishing the turbo and replacing pressure sensors, after which power and operation returned to normal. “Now everything works as it should.” [Elektroda, tomas0507, post #18669429]
How do I test the MAP sensor wiring correctly?
Test the three MAP wires in parallel end‑to‑end for continuity and load, not just open‑circuit checks. Also verify wiring to the turbo control valve. This finds hidden resistance or breaks that upset sensor voltage. [Elektroda, jurekk55, post #16771149]
Could a jump‑start or cable start precede this fault?
Yes. One case noted symptoms starting about 30 minutes after a cable start attempt. That timing hints at stress to electronics or wiring, so inspect connectors and grounds before condemning the ECU. [Elektroda, solek_87, post #17026126]
Is using aftermarket boost sensors risky on the W639?
Yes. Owners warn that replacements often read wrong. “It must be original.” Poor readings can keep the van in limp mode and waste diagnostic time. Use an OEM or proven OE‑quality unit. [Elektroda, diodabg, post #17026105]
What 3-step road test can isolate sensor vs. turbo control?
  1. Log requested vs. actual boost during a third‑gear pull.
  2. Inspect vacuum lines and confirm the turbo control valve actuates.
  3. Wiggle‑test harnesses to the sensor and valve while monitoring data. If data drops or spikes, fix wiring first. [Elektroda, diodabg, post #17026138]
What if swapping sensors and hoses didn’t help?
Escalate to actuator and turbo checks. Clean or refurbish the variable‑geometry mechanism and verify the actuator stroke. One success followed turbo refurbishment plus new sensors, restoring full performance. [Elektroda, tomas0507, post #18669429]
Which real-world fixes actually resolved P0105 in this thread?
Two outcomes: 1) Turbo geometry refurbishment with sensor renewal fixed the fault. 2) Webasto issue cleared, removing the high‑voltage P0105 and restoring power. Both were durable solutions afterward. [Elektroda, tomas0507, post #18669429]
